Thames Valley infrastructure problems causing disruption elsewhere - 2025
As at 22nd February 2025 17:16 GMT
Posted by TaplowGreen at 11:03, 22nd February 2025
Alterations to services between Reading and Slough
Due to a points failure between Reading and Slough:
Train services running to and from these stations may be delayed by up to 20 minutes or revised. Disruption is expected until 11:30 22/02.
As consistent as Wales.
Posted by TaplowGreen at 06:02, 21st February 2025
Delays to services between Slough and Reading
Due to a points failure between Slough and Reading some lines are blocked.
Train services running to and from these stations may be delayed by up to 15 minutes. Disruption is expected until 10:00 21/02.
A set of points on one of the lines between Slough and Reading has failed.
Posted by NickB at 07:19, 19th February 2025
Bust track at both Hanwell and Ealing Broadway.
Everything is delayed. Yay.
Posted by TaplowGreen at 06:00, 19th February 2025
Train services running to and from these stations will be delayed or terminated at and started back from Reading. Disruption is expected until 09:00 19/02.
We are sorry for the delay to your journey today. Due to a section of faulty track in the Hanwell area, our trains have to run at a reduced speed over the fault. Network Rail are trying to fix the fault, but in the meantime we are going to have to cancel some of our trains between Reading and London Paddington. This is necessary to prevent a traffic jam of trains building up as they slow down over the faulty track.
Our trains that run between Newbury and London Paddington will only run between Newbury and Reading.
Posted by NickB at 22:30, 12th February 2025
Ah Southall was it?!
2hrs to get home to Maidenhead tonight via Elizabeth Line tonight including getting retrained at Slough so that the empty train could arrive at Reading faster.
Interesting to see how the timetabling and track priorities shift over the evening. During rush hour the Didcot services were running fine and the Elizabeth Line trains ran slow with 40min delays. Now, at the end of the day, Didcots are cancelled and tfl is running ok(ish)
Posted by TaplowGreen at 21:44, 12th February 2025
Delays due to defective track. Non-specific location.
Specifically Southall!
Cancellations to services between London Paddington and Newbury via Reading
Due to a broken rail at Southall fewer trains are able to run on some lines. Disruption is expected until the end of the day.
Train services between London Paddington and Newbury via Reading may be cancelled.
Due to a broken track in the Southhall area, only a limited number of trains are able to run on this line. As a result, some train services may be cancelled or delayed
.....also affecting Didcot services.
Posted by NickB at 18:11, 12th February 2025
Posted by UstiImmigrunt at 10:31, 9th February 2025
This may be due to a very late start to the engineering work as the stop board was placed on the wrong track and destroyed by an IET.
https://www.realtimetrains.co.uk/service/gb-nr:G68678/2025-02-08/detailed#allox_id=0
was the train involved I believe.
And some interesting decision making being done as well, the driver was happy to keep going but others decided he wasn't fit to continue.
Posted by TaplowGreen at 07:19, 9th February 2025
Cancellations to services between Ealing Broadway and London Paddington
Due to urgent repairs to the track between Ealing Broadway and London Paddington all lines are blocked.
Train services running to and from these stations will be cancelled or revised. Disruption is expected until 13:00 09/02.
We are sorry for the disruption to your journey today.
Network Rail have declared a possession overrun for this morning whilst carrying out essential track maintenance.
Owing to this, GWR services will not be able to run past Reading on journeys towards London Paddington and no services can depart London Paddington heading towards Reading. Some Elizabeth Line services will run but only as far as Ealing Broadway.
Posted by grahame at 23:04, 8th February 2025
Gonna be fun at Paddington ...
Sun, 9 February 08:44 London Paddington to Penzance due 14:06
Sun, 9 February 08:46 London Paddington to Great Malvern due 11:14
Sun, 9 February 09:00 London Paddington to Bristol Temple Meads due 10:43
Sun, 9 February 09:16 London Paddington to Oxford due 10:15
Sun, 9 February 09:28 London Paddington to Carmarthen due 13:17
09/02/25 09:28 London Paddington to Carmarthen due 13:17 will be cancelled.
This is due to urgent repairs to the track.
Sun, 9 February 07:36 London Paddington to Great Malvern due 10:15
Sun, 9 February 07:38 London Paddington to Didcot Parkway due 08:57
Sun, 9 February 07:47 London Paddington to Penzance due 13:32
Sun, 9 February 07:57 London Paddington to Exeter St Davids due 10:57
Sun, 9 February 08:28 London Paddington to Swansea due 11:22
Sun, 9 February 08:48 London Paddington to Didcot Parkway due 09:53
08:48 London Paddington to Didcot Parkway due 09:53 will be started from Reading.
It will no longer call at London Paddington, Slough, Maidenhead and Twyford.
Sun, 9 February 09:45 London Paddington to Penzance due 15:06
09/02/25 09:45 London Paddington to Penzance due 15:06 will be starting late from London Paddington and is expected to be 30 minutes late.
This is due to urgent repairs to the track earlier today.
Posted by Chris from Nailsea at 10:03, 8th February 2025
I'll prepare another new topic, ready for 2026.
Posted by TaplowGreen at 09:47, 8th February 2025
And again today - after a reasonably good start to the year, slipping back into the old routine
Due to a speed restriction over defective track between Reading and London Paddington fewer trains are able to run on all lines.
Posted by TaplowGreen at 16:35, 7th February 2025
Train services running to and from these stations will be cancelled, delayed or terminated at and started back from Reading. Some stations between Reading and London Paddington will not be served. Disruption is expected until the end of the day
Posted by TaplowGreen at 12:38, 5th February 2025
Alterations to services between London Paddington and Didcot Parkway via Reading
Due to a points failure between Slough and Hayes & Harlington some lines towards London Paddington are closed. Disruption is expected until 14:15 05/02.
Train services between London Paddington and Didcot Parkway via Reading will be suspended between Reading and London Paddington. All stations between Reading and London Paddington will not be served.
........also affecting services towards Newbury.
Posted by Marlburian at 20:07, 29th January 2025
From National Rail
Urgent repairs are needed to the track between London Paddington and Acton Main Line. Trains running between London Paddington and Heathrow Airport / Reading may be cancelled, revised or delayed by up to 20 minutes.
A friend of mine boarded the 1023 at Paddington which, she texted was "going nowhere" for 12 minutes,eventually she got to Reading and waited for the 1123 to Tilehurst/Didcot, which was progressively "delayed", eventually being announced as running fast to Didcot. By then I was waiting in the car at Tilehurst Station, where the concourse was jammed with vehicles of contractors working on the lists - and an ambulance making a rare appearance in its dedicated parking space; I was half-blocking the entrance and advised my friend to take a taxi and returned home. When I got there, I reflected that she might as well have waited for the next local service and she came to the same decision, opting to walk to my house. BTW nowadays the station car park seems almost as full as it was pre-Lockdown.
Posted by NickB at 19:18, 29th January 2025
And the Elizabeth Line was bust this evening too.
My gripe for this evening is with (one of) the gateline crew at Paddington. There must have been 1000 people queuing for the 18.20 to Didcot.  The gateline team were checking all paper tickets and turning away anyone with a TFL ticket. That included a woman ahead of me who had a 2/3 year old child in that throng.
Where is the sense or humanity in turning that woman and child away, who arguably had a valid ticket, and who then had to battle through the ongoing masses to wait god knows how long for a TFL service.
I’m off to complain to GWR on her behalf.
Posted by TaplowGreen at 07:33, 29th January 2025
From National Rail
Posted by TaplowGreen at 11:17, 28th January 2025
Due to failure of the electricity supply between London Paddington and Reading trains have to run at reduced speed on some lines.
Train services running to and from these stations will be delayed. Disruption is expected until 08:00 28/01.
Due to a fault with the overhead electric supply tripping affecting the UP and Down relief lines, trains in this location will be delaye
d.
Disruption now expected till 1600
Posted by TaplowGreen at 07:24, 28th January 2025
Due to a fault with the overhead electric supply tripping affecting the UP and Down relief lines, trains in this location will be delayed.
Posted by TaplowGreen at 08:45, 12th January 2025
From National Rail - Journeycheck having a lie-in.
Elizabeth line between London Paddington and Heathrow Airport / Reading
Great Western Railway services to / from London Paddington
Heathrow Express services to / from London Paddington
Overrunning engineering works between Ealing Broadway and Hayes & Harlington is causing disruption to services. This means that trains between London Paddington and Heathrow Airport / Reading may be cancelled, delayed by up to 40 minutes or revised.
Posted by Chris from Nailsea at 19:25, 10th January 2025
Sadly, yes.  From the Richmond & Twickenham Times:
Hanwell station Elizabeth line incident: Person dies
A person has died after an incident on the Elizabeth line at a busy west London train station.
A casualty on the tracks was reported at Hanwell station at around 1.15pm today (January 10).  Officers and London Ambulance Service crews attended, and the person was pronounced dead shortly after.  The incident is not being treated as suspicious and a file will be prepared for the coroner.
All lines between London Paddington and Reading have been closed as the incident is being dealt with.  Major disruption is expected until 4.30pm.
If you need someone to talk to, Samaritans are available to contact any time day or night on 116 123.
A spokesperson for British Transport Police said: “Officers were called to Hanwell railway station at around 1.15pm today (10 January) following reports of a casualty on the tracks.  Paramedics also attended, however sadly a person was pronounced dead at the scene.  The incident is not being treated as suspicious and a file will be prepared for the coroner.”
My highlighting - hopefully helpful.  Chris.
Posted by IndustryInsider at 14:30, 10th January 2025
Phew, thank goodness for that!  New Year, TG!
I think perhaps you tempted fate...................
Due to the emergency services dealing with an incident between Ealing Broadway and West Ealing all lines are blocked. Disruption is expected until 16:00 10/01.
Fatality at Hanwell by the looks of it.  The ultimate unhappy new year for somebody then.  Thoughts to friends, family and all involved.
Sadly, we are now ‘in the season’ for such incidents.
Posted by TaplowGreen at 14:19, 10th January 2025
Train services between Reading and London Paddington may be cancelled, delayed or revised.
Due to emergency services currently dealing with an incident in the Ealing Broadway area, all trains are temporarily on stop. We apologise for the disruption and any inconvenience this may cause.
Posted by IndustryInsider at 14:08, 10th January 2025
Posted by TaplowGreen at 07:42, 10th January 2025
TaplowGreen must be in hibernation.
My apologies - normal service resumed.
Cancellations to services at Slough
Due to a points failure at Slough fewer trains are able to run.
Train services running through this station may be cancelled or delayed. Disruption is expected until 08:30 10/01.
Posted by IndustryInsider at 15:39, 9th January 2025
Posted by UstiImmigrunt at 15:36, 9th January 2025
So what's gone wrong? January 9th and nothing reported!
Posted by IndustryInsider at 20:13, 19th December 2024
I'm merely preparing the ground here, ready for member TaplowGreen to develop this topic, in due course.
Let somebody else have a go, TG!
Posted by Chris from Nailsea at 18:50, 19th December 2024
No, I haven't lost the plot!
Rather, I'm sharing member ChrisB's view that this sort of problem won't suddenly go away on New Year's Eve:
And the first for 2025....New Thread please!
