1.6.2025 (Sunday) 07:01 - All running AOK
Disruption is expected until the end of the day.
Now 20:00
Agreed.
Interesting point?
Fair comments, Timmer.
UPDATE:
Till the end of the day....
UPDATE:
A special treat for Easter!
Radley, unfortunately.
Appleford.
8178B - Southall East
8336 - Maidenhead East
8326 - Slough West
8296 - Dolphin Junction
8334 - Maidenhead East
8301 - Dolphin Junction
8335 - Maidenhead East
8027 - Royal Oak
Project Brunel anyone?
would be better as
Posted by grahame at 09:33, 19th March 2025
Owing to urgent repair work required on a small section of track in the Ealing Broadway area fewer train services are able to operate between London Paddington and Reading in both directions
Posted by GBM at 09:37, 17th March 2025
Alterations to services between Reading and Maidenhead
Due to a points failure between Reading and Maidenhead some lines are closed.
Train services running to and from these stations may be delayed or revised. Disruption is expected until 11:30 17/03.
A problem with some points (the means by which trains move from one track to another) in the Twyford area means that we have to reduce the number of train services operating over that section of line.
As a result, train services between London Paddington, Reading and Oxford will operate to a reduced frequency in both directions. Any customers travelling between London Paddington and Oxford (and vice versa) may utilise Chiltern Railways services between London Marylebone and Oxford (in both directions) as an alternative. GWR tickets will be accepted on those services and also on London Underground services between Paddington and Marylebone in order to facilitate this.
Train services between London Paddington and Newbury will not operate between London Paddington and Reading. Customers to / from these services will be required to change trains at Reading.
Please accept our apologies for any inconvenience this may cause.
Posted by TaplowGreen at 06:19, 15th March 2025
Due to a broken rail between Reading and London Paddington some lines are blocked.
Posted by TaplowGreen at 20:36, 11th March 2025
......and again.....
Following a points failure at Twyford the line will be reopened shortly. Disruption is expected until 21:30 11/03.
Train services between London Paddington and Reading may be delayed by up to 40 minutes or terminated at Reading.
Problems caused by a points failure near Twyford have now been resolved, and trains can run normally again. However this has caused significant delays and will take a while for the train service to recover.
Posted by a-driver at 19:59, 10th March 2025
TfL have publicly stated how un8mpressed they are with Network Rail previously.
Their public statement of unhappiness clearly achieved a lot!
It achieved a fair bit in securing additional resource, acknowledgement of shortcomings and undertakings that there would be improvements, but unfortunately this has yet to be delivered.
https://www.theguardian.com/uk-news/2024/feb/27/140m-rail-plan-to-tackle-elizabeth-line-and-great-western-problems
And 12 months on from that article there’s been no improvement.  It was all predictably bluff and bluster from Network Rail.
Posted by Ollie at 01:49, 10th March 2025
I’m on the 19:04 EL train from TWY (I’m going to Hayes) which left from P2 (which I was fortunate to aim for as according to RTT the previous one ran 13 minutes late and didn’t call there). This particular train is non-stopping Taplow and Burnham as indeed all EL trains are doing this evening with no advice that I’ve seen or heard so I don’t know what passengers to and from those stations are meant to do.
Burnham and Taplow was still able to be served by the Elizabeth line services that start/terminate at Maidenhead. It was only those to/from Reading that were unable to call.
Posted by BBM at 19:22, 9th March 2025
Also all the GWR trains on the PAD-DID route are shown on the screens at TWY as cancelled - from RTT it looks like they’re running but not stopping at TWY or MAI as in the message posted above.
Posted by grahame at 18:49, 9th March 2025
How would you describe that piece of hard-coded text then?
* An apology.
* An expression of care in acknowledging it is not as it should be.
I'm not sure it even needs a title though
Posted by ChrisB at 18:45, 9th March 2025
Posted by grahame at 18:42, 9th March 2025
Is it just me - or is that really NOT customer advice?
I would expect "Customer advice" to be something like "People who normally use GWR trains to Maidenhead or Telford should allow an extra  half hour and will need to change at Reading if coming from further west" . It actually advises the customers what to do!
Posted by grahame at 18:34, 9th March 2025
Alterations to services between Reading and Slough
Due to a points failure between Reading and Slough some lines are blocked.
Train services running to and from these stations may be delayed or revised. Twyford and Maidenhead will not be served. Disruption is expected until 21:00 09/03.
Due to a points failure at Twyford, GWR services cannot call at Twyford and Maidenhead. Elizabeth line services can still call at these stations.
Posted by TaplowGreen at 07:09, 9th March 2025
Posted by a-driver at 17:50, 8th March 2025
Posted by ChrisB at 15:03, 7th March 2025
TfL are a direct customer of Network Rail
GWR are a customer of the DfT, and a secondary customer of Network Rail of which Network Rail is a get-out clause within their DfT contract.
Posted by TaplowGreen at 14:37, 7th March 2025
Reading elsewhere that TfL are seriously unimpressed with the constant failures between Paddington and Reading (points, signal, track etc) which are affecting the Elizabeth Line and are taking a robust line with NR at a senior level, asking for details to be set out as to what is being done to address it.
A refreshing contrast with the apparently rather more quiescent GWR it would seem.
Whether it'll have any effect of course remains to be seen!
Posted by nickswift99 at 09:12, 6th March 2025
Except passengers struggled to go that way either. Passenger taken ill (which was unfortunate) meant that there were no trains to Waterloo from 0609 until 0728. I was lucky yesterday - didn't need to be in London until later so was able to get one of the first fasts from Reading at about 0835 - Reading station was pretty much deserted.
Posted by Wizard at 04:29, 6th March 2025
The Evening Standard reported that
Some trains were re-routed to London Waterloo.
Did that really happen?
Not a chance. Passengers were via SWR, the trains themselves weren’t.
Posted by ChrisB at 19:46, 5th March 2025
Check Real Time Trains?
Posted by Surrey 455 at 19:44, 5th March 2025
Posted by TaplowGreen at 05:15, 5th March 2025
Breathtakingly hopeless...............
Due to a fault with the signalling system between Slough and Twyford all lines are blocked. Disruption is expected until 09:00 05/03.
Train services between London Paddington and Reading will be cancelled.
Due to a fault on the signalling system between Slough and Twyford, the trains that run from London Paddington to Reading in both directions are unable to leave the depot. This means we have had to suspend the train service.
Posted by TaplowGreen at 04:46, 5th March 2025
Cancellations to services between Slough and Twyford
Train services running through these stations may be cancelled or delayed. Disruption is expected until 05:00 05/03.
Due to a complete loss of signalling between Slough and Twyford no trains can run.
Posted by TaplowGreen at 07:41, 2nd March 2025
From National Rail - Journeycheck still asleep.
between Ealing Broadway and Slough
Overrunning engineering works between Ealing Broadway and Hayes & Harlington means that some lines between between these stations are blocked. As a result, trains running through these stations will be cancelled or delayed by up to 10 minutes.
Trains are currently unable to run between Ealing Broadway and London Paddington.
Disruption is expected until 08:15.
Posted by TaplowGreen at 09:05, 1st March 2025
Hard to believe I know but yep, here we go again (from National Rail this time)
Services at Slough
A points failure at Slough means that some lines are blocked.
As a result, services at this station may be cancelled, delayed or revised.
Disruption is expected until 11:00.
