| Re: Off peak ticket, travel involves a connection, peak time services Posted by grahame at 16:02, 1st August 2026 | ![]() ![]() ![]() |
Onto Eurostar, you need to purchase a ticket to London Terminals CV, I think only from ticket offices or on-train if no ticket office available.
https://www.railfuture.org.uk/CIV-tickets
A CIV ticket is a ticket sold under the CIV conditions (Convention Internationale pour le transport des Voyageurs) for cross border rail travel. In the case of London, this means that, in the outward direction, if the UK train arrives into London late, Eurostar must honour the ticket and place the passenger on the next available Eurostar train. In the homeward direction, should the Eurostar arrive into London late and the connection onto the booked onward UK train is missed, the UK operator must accept the ticket on their next service. CIV tickets also include the underground connection to St Pancras where needed. They are normally slightly more expensive than the advance fare to / from London at the time of booking, but significantly cheaper than an open ticket.
On price - I have seen them substantially lower cost than the equivalent any time tickets, and indeed best value if your Eurostar times are such that you need to travel to or from London in the peak.
| Re: Off peak ticket, travel involves a connection, peak time services Posted by ChrisB at 14:44, 1st August 2026 | ![]() ![]() ![]() |
It applies from Eurostar, mind.
Also, I *think* it does apply if your bus or tube is cancelled, certainly n London.
| Re: Off peak ticket, travel involves a connection, peak time services Posted by Mark A at 12:47, 1st August 2026 | ![]() ![]() ![]() |
Thanks, both. That's all sensible.
| Re: Off peak ticket, travel involves a connection, peak time services Posted by grahame at 12:40, 1st August 2026 | ![]() ![]() ![]() |
I am reading the question a little differnt to ChrisB - hence my answer is a little different.
If you are travelling on an off peak ticket and a National Rail service goes wrong such that your connection, or one of a series of connections, drops you into the peak then you are allowed to travel on the first available peak train rather than having to wait for the peak to be over. Whether or not that's written into the conditions of travel or is somewhere else or is an unwritten rule, I know not.
If the error is yours such that the miss the last off peak train, or the connecting service that fails is not a national network one, I dont think the dispensation applies - so if you are delayed from Chesham or Brussels or Ryde, tough?
| Re: Off peak ticket, travel involves a connection, peak time services Posted by ChrisB at 12:26, 1st August 2026 | ![]() ![]() ![]() |
Hmm. There are different answers for different scenarios.
If your train is late, you have to wait for it unfortunately.
If it is cancelled, you can travel on the service afterwards, and indeed, if you are aware early enough, the train before.
If you are on multiple connections, If any train is late, you have to still travel on it & catch the next available service(s) of later connections. If you suffer a cancellation, the above applies to that journey & later connections can be made as you arrive for them.
| Off peak ticket, travel involves a connection, peak time services Posted by Mark A at 12:18, 1st August 2026 | ![]() ![]() ![]() |
In the scenario that someone's travelling on an off-peak ticket and their intended train is cancelled/runs late resulting in the next train available is a peak time departure, do terms and conditions allow them to travel on the peak time service?
This might also involve a cross-London journey, where their inbound train is late/cancelled and they find themselves at a London terminal after the evening peak is under way.
