GDPR / Cookie acceptance [about our cookies] • • • Cookies expire in a week!
Making sure the information you might need is easily available
Re: Making sure the information you might need is easily available
Posted by Chris from Nailsea at 17:41, 26th December 2025
Supporting grahame's message - that Network Rail Emergency number, 0345 711 4141, is programmed in to my mobile phone.
To be used only in times of emergency - but with immediate results - if required.
Posted by grahame at 17:12, 26th December 2025
Coming back to confirm the emergency number of  03457 11 41 41 for Network Rail and that should be prominently displayed.
This confirmation come from Network Rail today ... a video of gravel / pebbles / sand washed over the main line at Dawlish shared with the question "who do I report to".  Confirmation it's Network Rail, and a follow up from Network Rail to say that it has been called in, to confirm that was the right thing to do and to say "Thank you" and it will be looked at / dealt with / handled before trains resume in the morning.
Posted by Hafren at 20:44, 17th December 2025
The toilet door thing is quite a common scene on the TfW Flirts. The actual open button is in the middle (with an 'extra time' door for wheelchair users et al below - not sure if it is interlocked with something or triggers an indicator, but staff also seem able to trigger it with a key on the outside)... if the open button pressed early and nothing happens, the next step is to open the toilet door. One could ask why the toilet door button isn't on the other side, as seen on some stock, but that would mean going into a narrower area to find it so it's a non-starter.
I do wonder what people think the door release sounds and visuals are when they press the button and then do nothing when the door is released!
Posted by Oxonhutch at 18:53, 17th December 2025
On in-train door open buttons, I will admit (not sure what the stock was) to opening the train loo door on one occasion rather than the door to get off ...
Been there and got the T-shirt - IET stock, Carriage K or E and open the disabled toilet to attempt an exit to platform. Ooops!
Posted by CyclingSid at 16:44, 17th December 2025
explaining how to open train doors, given the number of times I've seen people struggle.
It would help if there was a national standard so the same button is always at the top. I have been found wanting pressing the button to open the doors when all the other trains on the journey it has been the other way round.
Posted by Chris from Nailsea at 08:13, 17th December 2025
Years ago I, too, suffered a momentary lapse of concentration: see https://www.firstgreatwestern.info/coffeeshop/index.php?topic=6742.msg67229#msg67229
Posted by grahame at 06:13, 17th December 2025
The 'fixed' information seems too much sometimes; meanwhile, the 'in the moment' information is severely lacking at times.
Perhaps this is where some instructional stickers are needed!
I would agree the occasional issues here ...  I recall in the final days of slam door HSTs at Swindon watching a couple of young ladies not realising these was a handle (level) to operate to open the door to get on the train.  Immediate problem fixed, of course.
Posted by PrestburyRoad at 06:09, 17th December 2025
having not located the button
A problem that's not unique to Britain.  A few months ago I travelled on the brand new trains between Brindisi and Bari (in the heel of Italy), and very swish and comfortable they are.  On these trains the doors are double leaf, and there is a button on each door panel, located at the central opening rather than on the door frame at the side.   I noticed that a big plastic sticker has been added on each panel, with a big arrow pointing to the buttons, which are themselves normal size and quite unobtrusive.  I guess that the manufacturer provided trains that worked perfectly in terms of the mechanics and electrics - then joe public found this usability problem, and it was fixed with a simple patch.
At least a  door button - once you've found it - is easier to use than the latch that needed two hands and two strong thumbs on the inside of the slam-door trains that we grew up with.
Posted by Hafren at 23:33, 16th December 2025
Re the 'fixed' information, it does seem that Joe Public needs a little hand-holding from time to time. I'm surprised there aren't stickers explaining how to open train doors, given the number of times I've seen people struggle. I note that when the 'who opens the doors' debates and union disputes pop up, the 'bottom half of the internet' comments produce assumptions that the passenger can do it; I think some genuinely think the doors aren't consciously released at stops.
Hence sometimes, the train comes to a stop and the person presses the button. Nothing happens, of course (although apparently the new Merseyrail trains can remember the press). Then the doors are released – the light comes on and some sounds blare out these days. Despite this (statistically these people aren't all going to be hard of hearing!) the person doesn't press the button again after release. I sometimes wonder if they think they set an alarm off by pressing the button! And this seems to play out frequently – at least in my anecdotal experience! Even worse, I've seen situations (only once or twice, this time) on 197s where it appears that people are don't make it off the train before it leaves, having not located the button – on 197s the vestibule is quite wide, and the button is set back, and on one side only, and thus I think the button isn't in people's line of sight.
Posted by Trowres at 22:18, 16th December 2025
The Scandinavians have a reputation for quality design. Quite something, then, for the British Rail Design Manual to be translated into Danish: https://designreviewed.com/artefacts/british-rail-design-danish-design-council-1986/
That photo of Melksham is shocking.
Posted by grahame at 06:56, 16th December 2025
That would be 999 then.
Not necessarily, ChrisB.
Many of the railway station platform help point machine's 'Emergency' buttons simply go into the local 999 system. However, even the Office of Rail and Road themselves acknowledge that that can be rather flaky.
I would prefer to follow the guidance from Network Rail themselves.
Please call our emergency 24 hour helpline on 03457 11 41 41 if there’s a safety threat to you or to others
Yes, Chris (fN) - that was the number I had in mind.
I have used it - once - from Melksham and found in very effective in getting the trains stopped / line closed in an emergency. Once in my life I did also dial 999 - not public transport related but where one of my neighbours's two boys had stuck a knife into the head of the other and it was still sticking out.  Their mum was freaking.  An extra loop while I explained to the emergency operator it was medical, accidental, we needed an ambulance and, no, not the police to lead on a knifing.
The past three weeks of reaching out to the public with new timetables has been a fascinating opportunity to look and listen at NaPTANs (National Public Transport Access Nodes) and at shops and events and venues.   We have a system which is a very complex one, and in my view much of it is set up by people who may have some understanding of the issues, but are not in the mind and informational starting point space of the people using or potentially using the services.     I'm only seeing that starting point second hand too - but at least I feel I am seeing it and can make some suggestions and valid comment, and some suggestions might even be able to go somewhere next year.   The world of electronic connectivity and AI adds layers and changes bias, and there is a need to avoid dumbing down to the extent of loosing data access for the knowledgable / repeat customer who makes good use of it.
Posted by Chris from Nailsea at 23:34, 15th December 2025
What extra would I like to see? ... for starters ...
* An emergency number to call in addition to the "Emergency" button on the help point
Posted by ChrisB at 20:30, 15th December 2025
- and I have counted that it takes seventeen button presses to persuade the ticket machine at Trowbridge to provide it.  Anyone looking for this fare in the machine needs to know what they are doing.
Or just a couple of key presses on your smartphone app (which I know you have)
Posted by grahame at 08:02, 15th December 2025
The Trowbridge fare looks a little out of place cost wise when Westbury, further down the line is 70p less and Bradford on Avon is just 20p more. Sure, we’re not talking large sums of money here, but a little strange.
There are no off peak fares between Melksham and Trowbridge, but there are between Melksham and both Westbury and Bradford-on-Avon.   So if you're travelling to Trowbridge on the 06:29, you buy a Trowbridge ticket, otherwise you buy a Westbury one.  Simples!
Every 2 months for the WWRUG committee meeting, I take the b-u-s to Trowbridge because there's a gap in the trains from 15:40 to 18:00 and return by train.  For that train journey, I buy an off peak single from WESTBURY to Melksham with discount for my disabled card - and I have counted that it takes seventeen button presses to persuade the ticket machine at Trowbridge to provide it.  Anyone looking for this fare in the machine needs to know what they are doing.
Posted by Sixty3Closure at 22:51, 14th December 2025
And most of them are bilingual here in Carmarthen so twice the information
Posted by Timmer at 22:25, 14th December 2025
Posted by grahame at 21:52, 14th December 2025
I am going to start with some answers to my own questions
Nice to tell us - except it's wrong.  Rail Replacement buses call at the rail replacement bus stop on Station Approach
There is no ticket office here.  There is no Permit to Travel Machine. There is no smart card system here.  With a big "Penalty Fare £100" in big text above this, it's over complex and frightens the bajeebers out nervous potential customers.
There are no Cross Country of Transport for Wales services anywhere near - so why say this?  And in any case Transport for Wales do have Penalty Fares.
The Glee Club and Cafe closed several years ago
Now this is excellent advice - but if you drop something onto the track, are you really going to read into the text of a big poster?  I don't know the alternative but ...
But there is a toilet ... installed with a grant from the Town Council and others for the use of passengers while the cafe is open. It would be correct to say, sadly, that "No toilet is available"
There's a coin slot ... but nothing behind it and coins fed in here just fall to the bottom of the inside of the machine
"Cheaper off peak fares may be available ... etc.  Except that it's already the off peak fare being offered and the super off peak fare - if you know the various buttons to press - will get you a London return for £71.20.  But that is seven button presses for the knowledgable.
* A simple sheet of train departures / line of route to include the times of direct trains back
* An advice button on the ticket machine where you can speak to someone to explain the various fares on offer
Posted by Chris from Nailsea at 20:05, 14th December 2025
Are there too many signs at our stations - even the smallest ones?
Wow!
Thanks for posting that pictorial detail from ... well, Melksham station, unless I'm much mistaken.
I'm not convinced we have that many posters and signs, in total, at Nailsea & Backwell station - which has two full working platforms, being on the main line between Bristol and Taunton.
Give me a bit of time tomorrow morning, and I'll stroll down to NLS to count the relevant signs here.
Posted by Mark A at 15:36, 14th December 2025
Yes.
Also, it was curious to watch several passengers off the up service at Warminster the other day cross to the down side and walk past the open exit by the footbridge to the 'Way Out' notice for the booking office exit to find that that that was closed: they retraced their steps to the very visible side exit.
Meanwhile I couldn't locate the ticket machine, then found I was looking at it. To passengers entering the station, it presents an anonymous grey flank that I'd dismissed as a piece of lineside equipment.
Posted by grahame at 15:26, 14th December 2025
Are they all necessary?
Are they all correct?
Do they all apply at this station?
Will passengers have time to read them?
Are they written in understandable English?
Will people be able to find the answer to any question even if the answer id there?
Are they all legible when needed?
Is anything missing?
