wide spread disruption at Bristol Temple Meads Sunday 8th June 2025
25.6.2025 (Wednesday) 23:25 - All running AOK
Re: wide spread disruption at Bristol Temple Meads Sunday 8th June 2025
Posted by grahame at 10:37, 8th June 2025
Switched it off/switched it on again?
Risky - it may not start up at all.  Isn't that why some diesel engines are / have been left running for hours?
Posted by TaplowGreen at 09:57, 8th June 2025
Posted by Timmer at 09:13, 8th June 2025
Further information on this:
Cancellations to services between Bristol Temple Meads and Swindon via Bath Spa
Following a fault with the signalling system at Bristol Temple Meads some lines have now reopened. Disruption is expected until 10:00 08/06.
Train services between Bristol Temple Meads and Swindon via Bath Spa and Chippenham are returning to normal but some services may still be cancelled or delayed.
The signalling system in the Bristol Temple Meads area had failed. This has meant weve been unable to run trains to, from or through Bristol Temple Meads. Most of the signalling system is now working and trains can now start to run through the area. There may be still be some delays and cancellations as no trains had been able to leave our depot in Bristol.
Network Rail specialist staff have been able to reset and restore most of the signalling system. We are now working get our trains and crew in place to start running our normal timetabled service, but there may still be some delays and alterations while we do this.
Posted by infoman at 08:28, 8th June 2025
Due to a fault in the signalling system in the BTM area
