Train hits tractor and trailer on level crossing 22/05/2025.
7.6.2025 (Saturday) 01:13 - All running AOK
Re: Train hits tractor and trailer on level crossing 22/05/2025.
Posted by a-driver at 11:46, 6th June 2025
Interesting perspective on the issues and risks involved with these types of crossings in general.....
https://www.facebook.com/share/v/12K9u3WiHKT/
And you can't disagree with what that farmer is saying
When I worked in a box, we had a panel with a button for each crossing, anytime someone called from a crossing the button illuminated so we knew exactly what crossing they were be calling from.  I don't know if that's still the case though.
Workload is a big issue.  One signaller can only manage a certain amount of these crossings.  If you've got 20 crossings in your area and a queue of calls waiting to be answered mistakes are going to be made.  Signallers are only human, we are all prone to making mistakes, there needs to be a fail safe method of working.
Posted by TaplowGreen at 08:41, 6th June 2025
Posted by a-driver at 14:26, 5th June 2025
All safety critical photo calls made into or out of a signal box are recorded.
Posted by TaplowGreen at 14:00, 5th June 2025
.....which was not recorded.....
Should it have been and the process was not completed for some reason? I would have thought the recording of such a potentially safety critical interaction should be mandatory.
I don't think user phones at UWCs are, in general - but maybe that has changed. In any case, analysing any recordings would still take more time and precaution than would allow a quick initial conclusion.
Given the wide availability of call recording technology and safety critical nature of the locations and the calls for which they are used, if those phones aren't suitably equipped for call recording I would find it absolutely breathtaking.
Posted by stuving at 12:40, 5th June 2025
Posted by Bob_Blakey at 11:38, 5th June 2025
Posted by stuving at 10:45, 5th June 2025
Playing devil's advocate - it doesn't say that he got permission to cross though - don't you think that they'd have added those few words?
No. Whether a telephone conversation (which was not recorded) provided "permission" is not the kind of simple fact that can be determined at the outset of an investigation. It is likely to be contentious, and a different interpretation of what went on by the two parties has caused such accidents in the past. In other words, you are looking for evidence of confusion and find that the evidence itself is confused - so you avoid jumping to conclusions.
Posted by ChrisB at 08:54, 5th June 2025
Posted by TaplowGreen at 06:45, 5th June 2025
Rant time.
A major problem at farm crossings all around the UK. Too many farmers ignore the safety rules by either leaving gates open, not seeking permission to cross or not confirming afterwards that the gates are closed and the crossing is clear for a train to proceed. And if any livestock is killed on the track it's always the fault of the railway, not the impatient farmer who didn't close the gate(s).
Hopefully this farmer is convicted.
Rant over.
Thankfully very few injuries. The worse case scenario, one train derails and is struck by another train.
From the RAIB
https://www.gov.uk/government/news/collision-between-a-train-and-an-agricultural-trailer-at-nordan-farm-user-worked-level-crossing?fbclid=IwY2xjawKuC9NleHRuA2FlbQIxMABicmlkETFBYmZKV0lZWjVVVHJ3VlRPAR5P9niXBe2dPwGakmuwkMHMcQeJD6UFY-ubeAmicBM7V5ZAVdD9ap4q3jU04Q_aem_FbaGDzgW3wnNb6Yb-QGECw
Before leaping to conclusions/convictions, no doubt readers will note "The evidence available to RAIB shows that the driver of the tractor involved in this accident telephoned the signaller before using the crossing".
Posted by JayMac at 18:44, 24th May 2025
When you can't be certain of something it's probably best not to double down.
Hoping a farmer is convicted, then the whataboutery from Slovakia... jeez.
Posted by UstiImmigrunt at 18:13, 24th May 2025
Bit presumptive that. Investigations need to carried out, parties involved to be questioned, witness statements to be gathered. Rather too early to blaming any one individual.
99.5% of crossing incidents are caused by the users. As per the rest of the comment I made.
There's no such thing as a dangerous crossing, its the dangerous idiots that use them.
PS There was a collision on that crossing in 2023, what's the betting it was the same idiot user? And failed to learn any lessons?
Once a few farmers are convicted for crossing misuse and insurance premiums go up maybe railway staff and passengers will be a lot safer.
You need to be very careful with your defamation of the tractor driver, as it appears he gained authority in this instance, the tractor driver is not the arrested person.
Which is why I said 99.5%. There was a nasty incident in Slovakia last year where a level crossing wasn't working after track maintenance. The treadles were left switched off so the red warning lights didn't activate or the barriers lower. Unfortunately several people were killed when a train struck a bus.
In this recent incident I know the CCIL, NR incident log, has been locked so it cannot be generally viewed by NR staff. A previous comment on this thread mentions a information on NoFriendsBook.
We shall wait for the RAIB to say something.
And no doubt somewhere on the UK rail network today a locally operated crossing wasn't used correctly.
Posted by LiskeardRich at 16:45, 24th May 2025
Posted by grahame at 10:32, 24th May 2025
Over the years, most reports here on the "Coffee shop" but not all of them have turned out to be the obvious ones - in the case of level crossing incidents mostly but not all the road / track user.  Should this turn out to be the fault of a crossing user who should have known better, I would agree with throwing the book at [him/her].  But until the responsibly is confirmed, we should hold fire on passing verdict and certainly on sentence.
Posted by UstiImmigrunt at 09:23, 24th May 2025
Posted by JayMac at 23:53, 23rd May 2025
Bit presumptive that. Investigations need to be carried out, parties involved to be questioned, witness statements to be gathered. Rather too early to be blaming any one individual.
Posted by LiskeardRich at 20:14, 23rd May 2025
Later reports state that the driver of the tractor was arrested on suspicion "of endangering lives on the railway"
One person taken to hospital by air ambulance, and another by land ambulance, many others treated at the scene for minor injuries.
The train remained on the track and does not look badly damaged. Probably driveable under its own power, at very low speed to a depot for repairs.
The tractor looks still useable. the trailer is substantially destroyed
Nowhere does any report say the tractor driver is the arrested individual. In fact the reported age rules the tractor driver out.
Signaller maybe? Tractor driver called and was given clearance is being reported on a Facebook page I seen earlier today.
Posted by UstiImmigrunt at 18:48, 23rd May 2025
Rant time.
Rant over.
Posted by Clan Line at 16:47, 23rd May 2025
From Telegraph.
Posted by broadgage at 10:00, 23rd May 2025
Posted by broadgage at 17:25, 22nd May 2025
Several persons injured, though reported to be not life threatening.
https://www.bbc.co.uk/news/articles/cly3885e58no
