Posted by TaplowGreen at 11:45, 22nd December 2025
Due to a points failure between London Paddington and Reading some lines are blocked.
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 14:00 22/12.
Posted by TaplowGreen at 17:56, 16th December 2025
Alterations to services between Slough and Reading
Due to a points failure between Slough and Reading some lines are closed.
Train services running to and from these stations may be delayed by up to 15 minutes or revised. Disruption is expected until 19:30 16/12.
Posted by Southernman at 23:13, 14th December 2025
I see this Elizabeth Line train arrived at West Ealing on time and departed 28 minutes late and terminated at Paddington.
https://www.realtimetrains.co.uk/service/gb-nr:P07282/2025-12-13/detailed#allox_id=0
Possibly the culprit?
Posted by IndustryInsider at 14:42, 14th December 2025
The penalties are covered in the charter companies contract with NR / ORR, there will be limitations to the penalty; the penalties work in both directions ie a TOC, FOC or NR causing delays to a charter as well as a charter fault.  Charter operators will operate with 2 locomotives to cover for a loco failure which is more than can be said for TOCs
Yes, and there has to be limitations otherwise a small charter operator would instantly go under if it was the cause of a significant incident.
Posted by Electric train at 12:19, 14th December 2025
Due to a fault on a train in front of this one between London Paddington and Reading all lines are blocked.
Train services running to and from these stations may be cancelled, delayed or suspended between Reading and London Paddington. Some stations between Reading and London Paddington will not be served. Disruption is expected until 19:45 13/12.
A train has had its doors accidentally open over the tracks.
Not sure which train was involved but a charter service from Bath Spa to Hull was delayed by 24 minutes near Stockley Junction.
If it was the charter service that was responsible I hope the business concerned is charged for the full cost of all the delays incurred.
Posted by TaplowGreen at 20:42, 13th December 2025
Not being reported by JourneyCheck......from National Rail
Elizabeth line between Abbey Wood and Heathrow Terminal 4 / Maidenhead / Reading, between London Paddington and Maidenhead, and also between Shenfield and Heathrow Terminal 5
Great Western Railway between London Paddington and Reading / Didcot Parkway / Swindon / Oxford / Newbury / Cheltenham Spa / Bristol Temple Meads / Great Malvern / Swansea / Carmarthen / Exeter St Davids / Plymouth / Penzance
A fault on a train earlier today in the West Ealing area means all lines are blocked. Trains running between London Paddington and Heathrow Airport / Reading may be cancelled, delayed by up to 40 minutes or revised.
There is significant disruption across the entire Elizabeth line network as a result, and service is currently suspended between Abbey Wood and London Paddington.
Disruption is expected until 22:00.
Great Western Railway and Heathrow Express customer advice:
You may use your ticket, at no extra cost on the following services:
Elizabeth line between London Paddington and Reading (please note, Elizabeth line are also affected by this disruption)
London Underground via any reasonable route
South Western Railway between London Waterloo and Reading, and also between Reading and Windsor & Eton Riverside
Elizabeth line customer advice:
Trains are unable to run between Abbey Wood and London Paddington.
You may use your ticket, at no extra cost on the following services via any reasonable route:
Docklands Light Railway
Great Western Railway (please note, Great Western Railway are also affected by this disruption)
London Underground
Check before you travel:
You can check your journey using the National Rail Enquiries real-time Journey Planner.
Compensation:
You may be entitled to compensation if you experience a delay in completing your journey today. Please keep your train ticket and make a note of your journey, as both will be required to support any claim.
Posted by ChrisB at 19:43, 13th December 2025
Locomotive Services are operating it. Now 30 mins down leaving London suburbs.
https://www.realtimetrains.co.uk/service/gb-nr:U70999/2025-12-13/detailed?s=2483
Posted by TaplowGreen at 19:35, 13th December 2025
Posted by bobm at 19:33, 13th December 2025
Posted by TaplowGreen at 16:28, 12th December 2025
And now the 01:42 as well. So that’s nothing after midnight on one of the busiest nights of the year.
Why buy a ticket if you don’t think that you’ll be allowed to get home?
Merry Christmas.
I think at least some of the late night cancellations last night were down to crew shortages - and it looks like the same is happening tonight with the cancellations starting to pop up - not great during Christmas party season!
Posted by Worcester_Passenger at 05:59, 12th December 2025
Due to urgent repairs to the track between London Paddington and Reading fewer trains are able to run.
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 09:00 12/12.
Following a safety inspection of the track today in the London area some lines are currently closed.
We are working with Network Rail to be able to return running the normal timetable as soon as safely possible.
We have stopped running trains in the area until safety staff on at the scene to investigate.
The safety of customers is our top priority and we will restore the service as soon as it is safe to do so.
What are my options?
We are sorry for the delay to your journey today. Below are the current options available to you:
Option 1: Use the National Rail Enquiries real-time journey planner to check if a journey by rail is currently possible. If you are at a station please check the live departure boards or speak to a member of station staff.
Option 2: Chiltern Railways are conveying passengers between Oxford and London Marylebone in both directions until further notice.
Elizabeth line are conveying passengers between Reading and London Paddington in both directions until further notice.
South Western Railway are conveying passengers between Reading and London Waterloo in both directions until further notice.
South Western Railway are conveying passengers between Slough and Windsor & Eton Central in both directions until further notice.
London Underground are conveying passengers via any reasonable route until further notice. Arrangements have been made for Great Western Railway rail tickets to be accepted for these journeys.
Option 3: Replacement transport provided by us such as a buses, coaches or taxis, have not been requested at this time. We will continue to monitor the need for this as the situation develops and provide updates here.
Option 4: If you can, you might want to consider postponing your journey until our service returns to normal.
Let us help you:
As a result we will have to reduce the number of train movements through the area. This will mean that local train services between London Paddington and Newbury will only operate between Reading and Newbury, in both directions. Customers travelling to / from Newbury, Thatcham & Theale from / to London Paddington will need (in most cases) to change trains at Reading.
In addition, local train services which would normally operate between London Paddington and Didcot Parkway, and return, will only operate between Reading and Didcot Parkway. Customers travelling to / from Didcot Parkway / Cholsey / Goring & Streatley / Pangbourne / Tilehurst from / to London Paddington (and intermediate stations between London Paddington and Reading) will need to change trains at Reading. Didcot Parkway will continue to have main line services running to / from London Paddington.
Twyford, Maidenhead and Slough stations will see a considerable reduction in the frequency of train services and GWR ticket holders should utilise Elizabeth Line services instead where no GWR services are available. Note that at London Paddington the Elizabeth Line services operate to and from platforms A & B which are accessed through the entrances alongside platform 1 of the main terminus.
If you're already travelling when disruption happens, we'll get you where you need to go. If you miss the last train of the day due to cancellation or because another train was delayed, we wont leave you stranded.
If you require help, further information or would like to provide feedback, to help us improve in the future:
Speak to staff at the station or on the train. Use the Customer Help Point on the platform.
Message us on X @GWRHelp, Facebook Messenger @gwruk, Instagram @gwruk or WhatsApp 07890 608043. Our team is available daily between 06:00 and 23:00 Monday to Friday and 07:00 to 23:00 Saturday and Sunday.
Call our Customer Support team on 03457 000 125, who are available between 06:00 and 23:00, or National Rail Enquiries on 03457 484 950, who are available 24 hours a day.
Delay Repay:
If you arrive at your destination 15 or more minutes late because your GWR train was delayed or cancelled, you can apply for Delay Repay compensation. Please keep your ticket and visit GWR.com/DelayRepay
Last Updated:12/12/2025 05:29
Posted by NickB at 23:51, 11th December 2025
Merry Christmas.
Posted by NickB at 23:48, 11th December 2025
This apparently doesn’t even warrant a comment about an interruption to service but both the 00:02 and 00:45 towards Didcot are cancelled which are the 2 final services of the day(?)
Hey, it’s only Thursday 11th Dec so who on earth might be taking a later train home than normal??
Posted by Witham Bobby at 15:49, 8th December 2025
Train services running to and from these stations are returning to normal. Disruption is expected until 16:00 08/12.
An axle counter, part of the signalling system, have stopped working in the Langley area. Axle counters tell the signalling system if a section of track has a train on it.
Trains need to stop at the affected section so that the Driver can speak to the Signaller to confirm if the track ahead is clear.
Engineers are heading to site to assess the situation.
Option 1: Use the National Rail Enquiries real-time journey planner to check if a journey by rail is currently possible. If you are at a station please check the Live Departure Boards or speak to a member of our station team.
Option 2: Travel at a later time. You might want to consider postponing your journey until our service returns to normal.
Last Updated:08/12/2025 14:53
Posted by ChrisB at 10:41, 7th December 2025
Train services between Didcot Parkway and Reading may be running non stop between Didcot Parkway and Goring & Streatley. Cholsey will not be served.
In that direction only - service stops towards Didcot.
Posted by TaplowGreen at 07:52, 7th December 2025
Alterations to services between Didcot Parkway and Reading
Due to urgent repairs to the track at Cholsey fewer trains are able to run on the line towards Reading. Disruption is expected until the end of the day.
Posted by TaplowGreen at 21:24, 27th November 2025
Due to a safety inspection of the track between London Paddington and Reading trains have to run at reduced speed on some lines.
Train services running to and from these stations may be delayed by up to 15 minutes. Disruption is expected until 18:00 27/11.
This one seemed to have disappeared but is now back again.........now until the end of the day.
Train services running to and from these stations may be delayed by up to 15 minutes. Disruption is expected until the end of the day.
Posted by TaplowGreen at 16:42, 27th November 2025
Posted by TaplowGreen at 08:44, 26th November 2025
Due to congestion between London Paddington and Reading:
Train services running to and from these stations may be delayed by up to 20 minutes. Disruption is expected until 09:00 26/11.
Owing to earlier points problems at Slough, an ongoing points failure at Didcot Parkway and a defect on a train in the Maidenhead area train services between London Paddington and Reading are experiencing some delays.
Posted by NickB at 07:00, 19th November 2025
Due to a fault with the signalling system between Twyford and Maidenhead trains have to run at reduced speed on some lines towards London Paddington bound local stopping.
Train services running through these stations may be cancelled or delayed. Disruption is expected until 08:00 19/11.
Posted by TaplowGreen at 11:27, 18th November 2025
Alterations to services between Reading and Didcot Parkway
Due to damage to the overhead electric wires between Reading and Didcot Parkway the line towards Didcot Parkway is disrupted.
Train services running to and from these stations may be running non stop from Reading. Some stations between Reading and Didcot Parkway will not be served. Disruption is expected until 14:00 18/11.
Posted by GBM at 08:16, 14th November 2025
Due to a points failure between London Paddington and Reading some lines are closed.
Train services running to and from these stations may be cancelled, delayed by up to 20 minutes or revised. Disruption is expected until 10:15 14/11.
Following a points failure between London Paddington and Reading all lines have now reopened.
Posted by TaplowGreen at 07:55, 14th November 2025
Posted by TaplowGreen at 03:34, 12th November 2025
Due to a speed restriction over defective track at Hayes & Harlington fewer trains are able to run. Disruption is expected until the end of the day.
Train services between Reading and London Paddington will be cancelled, delayed or terminated at and started back from Reading. Twyford, Maidenhead and Slough will not be served.
A crack in a rail has been discovered in the Hayes & Harlington area. This defect cannot be fixed until Tuesday night at the earliest.
.......the majority of Elizabeth Line trains are also being cancelled.
Engineers are on site monitoring the issue. There is a plan to fix the defect overnight but we will advise further here if this plan changes.
Well that's helpful.
Latest update.....genuinely couldn't make it up...........
Engineers are on site monitoring the issue. The defect was going to be fixed on Tuesday night but a fault was encountered with the machine used to replace the section of track. There is now a plan to fix the defect on Wednesday night, but we will advise further here if this plan changes.
Posted by TaplowGreen at 16:12, 11th November 2025
Posted by TaplowGreen at 05:48, 11th November 2025
Posted by TaplowGreen at 11:50, 28th October 2025
Train services running to and from these stations may be cancelled, delayed by up to 20 minutes or revised. Disruption is expected until 14:00 28/10.
Posted by TaplowGreen at 09:00, 26th October 2025
Delays to services between Reading and London Paddington
Due to damage to the overhead electric wires between Reading and London Paddington:
Train services running to and from these stations may be delayed. Disruption is expected until 12:00 26/10.
Posted by TaplowGreen at 03:30, 23rd October 2025
Cancellations to services at Didcot Parkway
Due to urgent repairs to the track at Didcot Parkway:
Train services running through this station will be cancelled, delayed or revised. Didcot Parkway will not be served. Disruption is expected until the end of the day.
Overnight Network Rail discovered a crack in the rail outside Didcot Parkway station. For safety reasons train are being diverted onto an alterative track past the area. To prevent congestion and further delays fewer trains will be able to run through Didcot Parkway all day today, Thu 23/10/2025.
Posted by TaplowGreen at 21:38, 22nd October 2025
Just seen this X post with a video of a trespasser simply casually strolling along the DM between Hanwell and Southall causing major disruption in today's evening peak:
https://x.com/golfbyrail/status/1981030855012151598
Disruption ongoing "until the end of the day".
I hope the trespasser in question receives a punishment that fits the crime, this must be costing a fortune and inconveniencing thousands of people.
Took me 3 hours Bond Street - Taplow and I know of others who've had horrendous journeys thanks to this thoughtless individual.
Posted by TaplowGreen at 18:09, 22nd October 2025
Yep, Ive been trying to get home since 1630, made it as far as Hayes so far!
Posted by Chris from Nailsea at 17:40, 22nd October 2025
Can we correct the abbreviation please? DM is *not* Dilton Marsh. that's DMH.
Done!
Posted by ChrisB at 17:24, 22nd October 2025
Posted by BBM at 17:18, 22nd October 2025
Posted by TaplowGreen at 13:13, 22nd October 2025
Alterations to services between Bedwyn and Newbury
Due to a broken down train at Kintbury the line towards Reading is blocked. Disruption is expected until 14:00 22/10.
Train services between Bedwyn and Newbury may be delayed or diverted.
GWR services from the West of England towards London Paddington are being delayed due to a broken down freight train at Kintbury.
Posted by TaplowGreen at 18:24, 17th October 2025
Due to the emergency services dealing with an incident between London Paddington and Reading all lines are closed.
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 15:00 17/10.
Emergency services are currently dealing with an incident at Hanwell Station. All trains are unable to run while the emergency services are investigating.
Now pushed out to 1800
"Until the end of the day"
Posted by TaplowGreen at 14:10, 17th October 2025
Posted by GBM at 12:28, 17th October 2025
Posted by GBM at 09:29, 17th October 2025
Now extended to 1030.
Posted by TaplowGreen at 07:30, 17th October 2025
Due to a speed restriction over defective track at Twyford trains have to run at reduced speed on some lines. Disruption is expected until 09:30 17/10
Train services between Reading and London Paddington may be cancelled, delayed or revised.
Posted by TaplowGreen at 06:29, 16th October 2025
Alterations to services between Reading and Newbury
Due to a fault with the signalling system between Reading and Newbury trains have to run at reduced speed on the line towards Newbury.
Train services running to and from these stations may be delayed by up to 30 minutes or revised. Disruption is expected until 10:00 16/10.
Posted by TaplowGreen at 09:47, 28th September 2025
Delays to services between Didcot Parkway and Reading
Due to a fault with the signalling system between Didcot Parkway and Reading some lines towards Reading are blocked.
Train services running through these stations may be delayed. Disruption is expected until 12:00 28/09.
Posted by NickB at 21:56, 20th September 2025
Power failure again. Delays and cancellations until the end of the day.
Posted by TaplowGreen at 15:00, 19th September 2025
Broken train removed and line reopened. Expect residual delays due to trains and crew being out of position.
Yep, Journeycheck saying disruption till 5 although it'll probably stretch into the rush hour, then again that's much quieter on a Friday these days - although hopefully it won't affect busier long distance trains in the early evening to Wales/the Westcountry etc.
Posted by Timmer at 14:27, 19th September 2025
Posted by BBM at 12:17, 19th September 2025
I see that GWR/Journeycheck are doing their usual thing of saying ‘just take the Elizabeth Line instead’ whereas in reality all Elizabeth Line trains are cancelled (to give priority to GWR services). This attitude of shift the problem at all costs is very annoying.
.......and as if last night wasn't enough.....
Due to a broken down train at Ealing Broadway the Reading bound high speed line is blocked. Disruption is expected until 11:45 19/09.
Looking at RTT and Open Train Times Maps the train concerned is a HEx service, the 09:25 from PAD to T5 which appears to be still on the DM between Ealing Broadway and West Ealing nearly three hours later. Hopefully some sort of rescue of the passengers is in progress.
Train services between London Paddington and Reading may be delayed or revised.
Posted by Timmer at 12:12, 19th September 2025
Now 5pm.
Posted by TaplowGreen at 10:55, 19th September 2025
Posted by NickB at 21:58, 18th September 2025
Posted by TaplowGreen at 20:19, 18th September 2025
Due to failure of the electricity supply between London Paddington and Southall some lines are blocked. Disruption is expected until 21:00 18/09.
We have had a report of a fault with the Overhead Line Equipment between London Paddington and Southall. Overhead Line Equipment (OLE) is the name given to the overhead wires and other equipment on electrified railway lines that provides power to the trains.
Engineers are investigating the fault. Currently we are unable to run any trains between London Paddington and Reading, in either direction.
Now revised to "till the end of the day" and "Do not travel" notice issued.....
Posted by TaplowGreen at 19:52, 18th September 2025
Posted by TaplowGreen at 14:15, 13th September 2025
A team is en route with a pin
Delays to services between Reading and Didcot Parkway
Due to an object being caught on the overhead electric wires between Reading and Didcot Parkway trains have to run at reduced speed on some lines.
Train services running to and from these stations may be delayed. Disruption is expected until 14:20 13/09.
Due to a balloon on the overhead eletric wires, trains between Reading to Didcot Parkway will be cautioned.
As a result some services will be delayed.
Posted by TaplowGreen at 16:34, 11th September 2025
Delays to services between Slough and Maidenhead
Due to a fault with the signalling system between Slough and Maidenhead trains have to run at reduced speed on some lines.
Train services running through these stations may be delayed by up to 15 minutes. Disruption is expected until 19:00 11/09.
Posted by TaplowGreen at 14:20, 30th August 2025
......a very poor week for the Thames Valley.....
Due to an object being caught on the overhead electric wires between London Paddington and Reading some lines are blocked.
Disruption is expected until 17:00 30/08.
Posted by TaplowGreen at 10:53, 30th August 2025
Due to a fault with the signalling system at Reading trains have to run at reduced speed on some lines
Train services running to and from this station may be delayed. Disruption is expected until 11:15 30/08.
Posted by TaplowGreen at 14:22, 29th August 2025
Cancellations to services between Newbury and London Paddington via Reading
Due to a safety inspection of the track at Midgham trains have to run at reduced speed on the line towards Reading. Disruption is expected until 15:00 29/08.
Train services between Newbury and London Paddington via Reading may be cancelled.
Posted by TaplowGreen at 10:34, 29th August 2025
Posted by TaplowGreen at 10:27, 27th August 2025
Due to a derailment within the depot between Oxford and Didcot Parkway the line towards Didcot Parkway is blocked.
Train services running through these stations may be cancelled. Disruption is expected until the end of the day
Posted by Timmer at 07:42, 26th August 2025
This is probably why Elizabeth line and Oxford to London services are being affected, signalling fault affecting the fast London bound platforms at Reading.
Cancellations to services at Reading
Due to a fault with the signalling system at Reading fewer trains are able to run on some lines.
Train services running to and from this station will be cancelled. Disruption is expected until the end of the day.
Due to a fault with the signalling system at Reading affecting platforms 10 & 11, some services will be altered; delayed or cancelled.
Posted by TaplowGreen at 07:33, 26th August 2025
From National Rail - judging by the cancellations between Oxford-Paddington it's not only affecting the Elizabeth Line.
A fault with the signalling system between Reading and Twyford means some lines are disrupted.
As a result, Elizabeth line trains running between Reading and Maidenhead may be delayed or cancelled.
Disruption is expected to continue until 09:00.
Posted by TaplowGreen at 22:54, 24th August 2025
Due to a fault with the signalling system between Newbury and Reading trains have to run at reduced speed.
Train services running to and from these stations may be delayed by up to 20 minutes. Disruption is expected until 23:00 24/08.
Posted by TaplowGreen at 12:37, 23rd August 2025
Due to a points failure between London Paddington and Reading trains have to run at reduced speed on some lines.
Train services running to and from these stations may be delayed by up to 30 minutes. Disruption is expected until 13:30 23/08.
Posted by TaplowGreen at 18:39, 21st August 2025
Due to a fault with the signalling system between Twyford and Maidenhead trains have to run at reduced speed on some lines.
Train services running through these stations may be delayed by up to 20 minutes. Disruption is expected until 19:00 21/08.
Posted by TaplowGreen at 19:21, 19th August 2025
Cancellations to services between Didcot Parkway and Oxford (also affecting much wider area)
Due to the emergency services dealing with an incident at Didcot Parkway all lines are blocked. Disruption is expected until 17:15 19/08.
Train services between Didcot Parkway and Oxford may be cancelled or delayed.
A person has been struck by a train, leading to all lines being blocked.
Disruption now expected "until the end of the day" across the region.
Posted by TaplowGreen at 16:40, 19th August 2025
Posted by TaplowGreen at 08:03, 16th August 2025
Due to a fault with the signalling system between Reading and Westbury some lines are blocked.
Train services running to and from these stations may be cancelled, delayed or diverted. Disruption is expected until 09:00 16/08.
Due to a fault with the signalling system, west country train services are currently unable to run between Reading and Westbury. Trains from the west country towards Reading are unaffected.
Posted by TaplowGreen at 10:21, 8th August 2025
From National Rail
between London Paddington and West Ealing
A fault with the signalling system between London Paddington and Acton Main Line means trains must run at a reduced speed on some lines. As a result, trains operating to / from these stations may be cancelled, delayed by up to 20 minutes or revised.
Posted by Electric train at 09:27, 6th August 2025
What is needed is some analytical boffin to gather all the failures reported here in these forums for the TV and trend them say over the last 4 years ie post COVID lockdowns
Posted by TaplowGreen at 07:27, 5th August 2025
Train services running to and from these stations may be cancelled, delayed or revised. Disruption is expected until 11:00 05/08.
Posted by TaplowGreen at 13:50, 4th August 2025
Due to damage to the overhead electric wires between Reading and London Paddington trains have to run at reduced speed on some lines towards London Paddington.
Train services running to and from these stations may be delayed by up to 20 minutes or revised. Disruption is expected until 15:00 04/08.
Posted by TaplowGreen at 12:34, 1st August 2025
Following a points failure at Slough the line towards London Paddington will be reopened shortly. Disruption is expected until 13:45 01/08.
Posted by TaplowGreen at 11:58, 28th July 2025
Cancellations to services at Tilehurst
Due to a points failure at Tilehurst some lines are blocked.
Train services running through this station may be cancelled or revised. Pangbourne will not be served. Disruption is expected until 12:45 28/07.
Posted by Electric train at 06:14, 25th July 2025
Consistency being maintained.....
Following a broken down train at Twyford some lines will be reopened shortly. Disruption is expected until 17:15 22/07.
Train services between London Paddington and Reading may be delayed by up to 15 minutes.
Broken down freight train.
So not an infrastructure problem or failure that caused the disruption
Posted by a-driver at 20:53, 22nd July 2025
Posted by TaplowGreen at 16:32, 22nd July 2025
Posted by a-driver at 11:49, 22nd July 2025
See also: https://www.firstgreatwestern.info/coffeeshop/index.php?topic=30475.msg363433#msg363433
Fair play to the SWR managers concerned for pitching up given the circumstances, it must have been quite uncomfortable for them. Would be good to see Hopwood et al at Paddington (or indeed anywhere!) doing a similar session during a GWR meltdown, seeing (and hearing) what their customers have to put up with at first hand may concentrate a few minds.........
I’d rather have the top brass from the DfT and Network Rail.  They’re the ones inflicting the misery.
Posted by TaplowGreen at 05:38, 22nd July 2025
Posted by Chris from Nailsea at 19:13, 21st July 2025
Posted by TaplowGreen at 19:05, 21st July 2025
We're now getting back to the days where this is virtually a daily event. If not points it's signal or track issues.
Train services running to and from these stations may be cancelled or delayed by up to 30 minutes. Disruption is expected until 11:15 21/07.
And it’s not confined to just GWR, it’s the same across the country.  Look at Waterloo today.
There’s some serious issues within Network Rail that need addressing urgently.
Reported at length on BBC London news tonight.........South Western even had a "Meet the Manager" event today at Waterloo! Perfect timing!
Posted by a-driver at 16:56, 21st July 2025
Posted by TaplowGreen at 15:16, 21st July 2025
The obvious solution, don't increase road fuel duty again. You couldn't make it up could you.
I'm unclear as to the correlation? (Which as we know, is not causation!)
Posted by CyclingSid at 12:35, 21st July 2025
Posted by TaplowGreen at 10:56, 21st July 2025
Posted by TaplowGreen at 11:35, 20th July 2025
Due to a safety inspection of the track at Hayes & Harlington fewer trains are able to run on the line towards London Paddington. Disruption is expected until the end of the day
Posted by GBM at 05:57, 18th July 2025
Due to a speed restriction over defective track between Reading and London Paddington fewer trains are able to run on the London Paddington bound local stopping line.
We're sorry for the delay to your journey today. Following a safety inspection of the track in the Twyford area, a speed restriction has had to be implemented on some lines. Network Rail advise that due to the nature of the fault found, this disruption will last until the end of the day.
In order to avoid the speed restriction, both ours & other operators local stopping trains will need to share the high speed lines with our high speed long distance trains that run between Reading and London Paddington. This will cause some delay due to congestion, much like a lane closure on a motorway.
In order to reduce congestion in the area and to reduce any further impact to your journey, we will need to cancel some trains.
We will only be running one train per hour between Oxford and London Paddington.
Some of our trains that run between Newbury and London Paddington will only run between Newbury and Reading. You may need to change trains at Reading if you are travelling to or from London Paddington.
Posted by TaplowGreen at 19:55, 17th July 2025
Train services running to and from these stations may be cancelled, delayed or terminated at and started back from Reading. Slough, Maidenhead and Twyford will not be served. Disruption is expected until 20:30 17/07.
Posted by TaplowGreen at 05:25, 16th July 2025
Due to a fault with the signalling system the line is blocked. Disruption is expected until 08:30 16/07.
Due to a fault with the signalling system, trains are currently suspended between Reading and Newbury.
Posted by TaplowGreen at 07:07, 15th July 2025
Delays to services between West Ealing and Greenford
Due to a fault with the signalling system between West Ealing and Greenford all lines are blocked.
Train services running to and from these stations will be delayed. Disruption is expected until 07:45 15/07.
Due to a fault with the signalling system between West Ealing and Greenford, the line is currently blocked.
Posted by Electric train at 07:07, 13th July 2025
Why oh why didn’t GWR send a unit to Didcot once they had overcome the Traincare issues?  Is it because those poor customers who had been stranded at Reading for 2 hours were already a lost cause in terms of repayment claims - so to minimise the damage to the GWR coffers it was better to send units to London?
I'm often less than impressed with decisions operators make during disruption, but I genuinely don't think that minimising repayment claims figures highly, other than as a by-product of the underlying "how can we best sort out this mess?", for which there are various meanings of the word "best".  Where the cost more directly affects the response is likely to be in areas such as arranging alternative transport (bus, taxi etc), for which there are probably guidelines on severity/timescale of disruption etc and someone will need to authorise it.  Staff overtime may be another area, though working time limits will restrict that anyway.
I have been involved quite a few times in the conference calls that are managing service disruption, there are so many moving parts and demands.  I as the electrification Engineer or my colleges PWay and S&T Engineers may need access to fix a fault  this may add to the initial impact but ultimately will result in a full recovery but that has to be balance against the urgent operational need to provide even a limited service also more importantly we have to say sometimes it is unsafe to use this section of the railway.  The TOC and NR Ops have to consider train crew, suitable rolling stock, train pathing out and return
I'm not involved in the Western Region but each Region has a Silver Command head by senior leaders of NR and the TOCs this will be Route Director level.
The result has been that services west of Reading that 10 years ago were run by 3 car Turbos now run often with very lightly loaded 387s. Some have (of course) already been reallocated to Heathrow Express duties, but the rolling stock shortage across GWR territory extends to all non-electrified Thames Valley services too (remember the 769s?).
Listening to the recent interview Jeff Marshal did with Mark Hopwood the GWR do not see the rebuild of 'D' Stock as being the answer to future rolling stock.
It has always been my view you can cascade rolling stock, but the rebuilding a traction unit to a different form of traction especially when its greater than 40% of it life is just not value for money
The contrast with the glacial progress in introducing the 185s further west is striking. If all that I have learned as a member of this forum over the years, this bears the fingerprints of DfT. Will GBR, when it eventually takes over do better (or be allowed to)?
Ultimately HM Treasury holds the purse strings, those strings and fare increases are politically controlled.
Posted by eightonedee at 18:24, 12th July 2025
Following up on a-driver's comments on the transfer of some of the class 387s, I am afraid this seemed inevitable. The fleet was procured when it was anticipated not only that electrification would get to Oxford, but also would extend to the Windsor, Marlow, Henley and Basingstoke branches. The Elizabeth Line has also absorbed quite a proportion of GWR stopping train traffic east of Reading.
Posted by Ralph Ayres at 17:33, 12th July 2025
Posted by a-driver at 17:08, 12th July 2025
Why are GWR 387s being released elsewhere when they can’t hold/recover the timetable together with the stock they have.
GWR were instructed to release the 387's by the DfT.  As Oxford wasn't electrified the DfT calculated that GWR had a surplus of 387's
There was I believe, a points failure at Didcot with no access from Reading to Oxford.  Trains used Foxhall Jn which requires a reversal and free platforms at Didcot.
Why do customer service facing staff have no better (and in some cases less) information that Joe Public? If I wasn’t aware of RTT or OTT I would be completely at the whim of the train companies
Multiple failures at Didcot, Maidenhead and Ladbroke Grove simply means a constantly changing situation and an overstretched controller juggling resources and attempting to perform miracles!
Decision are never made to benefit the company.  The controllers sole intention is trying to keep things moving with what you've, some days whatever decision you make minutes later something else happens that scuppers that plan.
Posted by lbraine at 16:29, 12th July 2025
A miserable couple of days relying on the UK train service.
I’ll start elsewhere and then bring it back to GWR towards the end.
I needed to go to Cambridge on Thursday (actually a day early than needed but the extortionate day return price meant going a day before was 1/2 the price).
My Thames Valley stopper gave up at Reading - no reason given, just an announcement from the Driver pulling into Reading. Not to worry - hustled across to platform 10/11 to catch a fast 5 car IEP at 12:34, pausing briefly to notice the number of delayed services on the list. Hmmm - glad I went now as later on could be a mess.
Arrived at King Cross at the start of a major meltdown - the next 3 Cambridge Great Northern train all delayed/cancelled. RTT actually showed all running. Message on the boards said due to a signal failure journeys north of Cambridge would be delayed and subject to cancellation.
Hmmm - but surely running to Cambridge should be fine? Jumped onto OTT and started looking at the maps and it was clear the issue was at the Kings Cross/Cambridge box boundary - south of Cambridge, hence no trains. Gate line staff were pretty hopeless, basically telling people to wait. Jumped onto National Rail where they said fault would not be fixed until 10:00 pm
I started sharing this with other stranded customers - amazingly much to the clear annoyance of the Great Northern staff.
Back onto RTT/OTT - and worked out that if I jumped on the Victoria line to Tottenham Hale I could catch a slow all station stopper from Liverpool Street to Cambridge. Yes it was going to take forever - but I should get there.
Apart from a protracted discussion with Great Anglia gate line staff who had to be convinced that this was a valid route for my ticket I arrived at Cambridge at 5pm (to a scene of armageddon as hundreds stood in the longest queues for taxis to Royston from which trains to Kings X were running.
In total my 2:15 scheduled journey took 5 1/2 hours.
Friday was the return trip - leaving Cambridge at 1:00pm on a GWR liveried  Class 387, albeit with logo removed. I actually spotted 3 more on this trip - I was unaware GWR were transferring these to other operators. Even the WiFi onboard was GWR, so it must be a recent movement.
Kudos to Network Rail who had repaired the signalling interface problem and it’s was a smooth, fast 45 trip to Kings Cross and then onto Paddington.
Arriving at 2:30pm the Thames Valley Didcot stopped was cancelled - alongside several others. Again, back onto RTT and I could see the train actually scheduled to start from Reading.
So why were GWR announcements saying to wait for the next train in 30 minutes.
Jumped into a 10 car IEP bound for Penzance and actually found a seat ! Things were looking up and a smooth ride to Reading took place. This where the GWR customer experience really bottomed out.
I arrived to see the train I was trying to catch showing for Platform 12. Five minutes after the supposed departure  this changed to Delayed - which a s everyone knows is GWR speak for a coin-toss as to whether the train will depart or not.
Some disgruntled customers started merging to for a group to get a taxi to Pangborne - as the previous train has been cancelled.
Time ticked by the the next service was due - but it too fell to the dreaded Delayed banner. I started talking to some friendly GWR staff who like me were glued to their OTT like app trying to work out what the hell was going on.
We finally got an announcement - as they officially Cancelled the first train I was going for - to say there was an issue as Reading Traincare meaning units could not be released. By now the next service has appeared and was showing as Delayed.
To summarise - for at least 2 hours GWR had failed to run 4 local services to Didcot.
Finally, around 4pm Class 387’s started emerging from Reading Traincare.
Excellent news, or so I thought - surely at least one of these units would service the crowd of hundred customers on Platform 12 and send a train to Didcot. (By this time I have seen a service at Slough, in bound).
But No! GWR sent all these units (I witnessed at least 3) towards London.
At 4:30 I board the Class 387 - the one that arrived from Slough. This was a sauna as the aircon on-board was not working and people arriving fell out of the train gasping for air, and issuing us dire warnings.
So here is my ire (in no particular order)
Why at Paddington did they not tell customers that the cancelled train would start at Reading (OK - it did not in the end but did they know that at that point in time?)
… I could go on.
I have watched and read much on the coming of Great British Railways - and have been neutral about the pros and cons. Privatisation has brought investment to the railway (alongside large shareholder payouts) but this investment has done nothing to allow the railways to continue to operate on days when it is stressed. So what is the point? Maybe public ownership will correct some my experiences - but maybe not.
But most importantly I want a railway that puts customers FIRST and the banishment of operational decisions that benefit no one except the train operating company themselves.
I’ve written this 24 hours after arriving home - giving at lease my blood pressure time to fall, if not the actual temperature. My original draft was far far more spicey.
Posted by Ralph Ayres at 10:37, 12th July 2025
The lines may have been open but certainly around 1900 when I arrived trying to reach West Drayton, nothing was running on the relief lines with TfL having given up completely. Only reported delay was west of Reading, and nothing had been mentioned in the banner on the NRE app or I'd have taken a very different route from my starting point of Alton having already had to detour thanks to two successive GWR cancellations on the line from Gatwick.  The information booth seemed to know less than I could work out from the departure screens and kept telling people to ask gateline staff; I'd expected the booth would at least have a feed of the signal diagram showing actual locations, train running info etc.  Eventually got on an eastbound IET which I'm sure was shown as calling additionally at Slough to get me closer, but ran non-stop to Paddington. By that time Lizzie trains were running west to Heathrow via Hayes so took that option followed by a bus. Fortunately I was in no hurry and the trains had working air conditioning.
Posted by a-driver at 21:07, 11th July 2025
Posted by TaplowGreen at 20:21, 11th July 2025
Posted by TaplowGreen at 18:00, 11th July 2025
Posted by grahame at 16:37, 11th July 2025
The train being used on the Slough to Windsor route has developed a fault, and we have been unable to fix the problem.
No spare trains are currently available, therefore the service along this route is suspended until further notice.
..............unhappy tourists/commuters, happy taxi drivers.
I'm not in the UK at the moment and they seem to do things differently here.  As I understand it earlier today, there was a fault on the train we were waiting in, and we all transferred to another just along the platform. There seems to be an appreciable supply of parked trains at most operating centres, some of which I suspect are spare donors but some are in running order, and this provision of a few spares - no doubt each given a run from time to time - seems to make sense.  I would prefer and older train occasionally to no train.
Such a system could not be easily adopted in the UK due to the rolling stock leasing regime and the need for every train to pay its way every day.
Posted by TaplowGreen at 16:22, 11th July 2025
Another Turbo has sat down.
Due to a broken down train between Newbury and Bedwyn fewer trains are able to run.
Train services running through these stations may be cancelled or revised. Disruption is expected until the end of the day.
The train operating the Newbury/Bedwyn shuttle has failed.
Some long distance GWR Westcountry services will call additionally and rail replacement transport is being arranged.
...........and another
Cancellations to services between Slough and Windsor & Eton Central
Due to a fault on this train between Slough and Windsor & Eton Central fewer trains are able to run on the line.
Updated;
Posted by TaplowGreen at 16:11, 11th July 2025
