1.8.2025 (Friday) 00:23 - All running AOK
Posted by TaplowGreen at 11:58, 28th July 2025
Cancellations to services at Tilehurst
Due to a points failure at Tilehurst some lines are blocked.
Train services running through this station may be cancelled or revised. Pangbourne will not be served. Disruption is expected until 12:45 28/07.
Posted by Electric train at 06:14, 25th July 2025
Consistency being maintained.....
Following a broken down train at Twyford some lines will be reopened shortly. Disruption is expected until 17:15 22/07.
Train services between London Paddington and Reading may be delayed by up to 15 minutes.
Broken down freight train.
So not an infrastructure problem or failure that caused the disruption
Posted by a-driver at 20:53, 22nd July 2025
Posted by TaplowGreen at 16:32, 22nd July 2025
Posted by a-driver at 11:49, 22nd July 2025
See also: https://www.firstgreatwestern.info/coffeeshop/index.php?topic=30475.msg363433#msg363433
Fair play to the SWR managers concerned for pitching up given the circumstances, it must have been quite uncomfortable for them. Would be good to see Hopwood et al at Paddington (or indeed anywhere!) doing a similar session during a GWR meltdown, seeing (and hearing) what their customers have to put up with at first hand may concentrate a few minds.........
I’d rather have the top brass from the DfT and Network Rail.  They’re the ones inflicting the misery.
Posted by TaplowGreen at 05:38, 22nd July 2025
Posted by Chris from Nailsea at 19:13, 21st July 2025
Posted by TaplowGreen at 19:05, 21st July 2025
We're now getting back to the days where this is virtually a daily event. If not points it's signal or track issues.
Due to a points failure between
London Paddington and Reading some lines are blocked.
Train services running to and from these stations may be cancelled or delayed by up to 30 minutes. Disruption is expected until 11:15 21/07.
And it’s not confined to just GWR, it’s the same across the country.  Look at Waterloo today.
There’s some serious issues within Network Rail that need addressing urgently.
Reported at length on BBC London news tonight.........South Western even had a "Meet the Manager" event today at Waterloo! Perfect timing!
Posted by a-driver at 16:56, 21st July 2025
Posted by TaplowGreen at 15:16, 21st July 2025
The obvious solution, don't increase road fuel duty again. You couldn't make it up could you.
I'm unclear as to the correlation? (Which as we know, is not causation!)
Posted by CyclingSid at 12:35, 21st July 2025
Posted by TaplowGreen at 10:56, 21st July 2025
Posted by TaplowGreen at 11:35, 20th July 2025
Due to a safety inspection of the track at Hayes & Harlington fewer trains are able to run on the line towards London Paddington. Disruption is expected until the end of the day
Posted by GBM at 05:57, 18th July 2025
Due to a speed restriction over defective track between Reading and London Paddington fewer trains are able to run on the London Paddington bound local stopping line.
We're sorry for the delay to your journey today. Following a safety inspection of the track in the Twyford area, a speed restriction has had to be implemented on some lines. Network Rail advise that due to the nature of the fault found, this disruption will last until the end of the day.
In order to avoid the speed restriction, both ours & other operators local stopping trains will need to share the high speed lines with our high speed long distance trains that run between Reading and London Paddington. This will cause some delay due to congestion, much like a lane closure on a motorway.
In order to reduce congestion in the area and to reduce any further impact to your journey, we will need to cancel some trains.
We will only be running one train per hour between Oxford and London Paddington.
Some of our trains that run between Newbury and London Paddington will only run between Newbury and Reading. You may need to change trains at Reading if you are travelling to or from London Paddington.
Posted by TaplowGreen at 19:55, 17th July 2025
Due to a points failure between London Paddington and Reading fewer trains are able to run on some lines.
Train services running to and from these stations may be cancelled, delayed or terminated at and started back from Reading. Slough, Maidenhead and Twyford will not be served. Disruption is expected until 20:30 17/07.
Posted by TaplowGreen at 05:25, 16th July 2025
Posted by TaplowGreen at 07:07, 15th July 2025
Posted by Electric train at 07:07, 13th July 2025
Why oh why didn’t GWR send a unit to Didcot once they had overcome the Traincare issues?  Is it because those poor customers who had been stranded at Reading for 2 hours were already a lost cause in terms of repayment claims - so to minimise the damage to the GWR coffers it was better to send units to London?
I'm often less than impressed with decisions operators make during disruption, but I genuinely don't think that minimising repayment claims figures highly, other than as a by-product of the underlying "how can we best sort out this mess?", for which there are various meanings of the word "best".  Where the cost more directly affects the response is likely to be in areas such as arranging alternative transport (bus, taxi etc), for which there are probably guidelines on severity/timescale of disruption etc and someone will need to authorise it.  Staff overtime may be another area, though working time limits will restrict that anyway.
I have been involved quite a few times in the conference calls that are managing service disruption, there are so many moving parts and demands.  I as the electrification Engineer or my colleges PWay and S&T Engineers may need access to fix a fault  this may add to the initial impact but ultimately will result in a full recovery but that has to be balance against the urgent operational need to provide even a limited service also more importantly we have to say sometimes it is unsafe to use this section of the railway.  The TOC and NR Ops have to consider train crew, suitable rolling stock, train pathing out and return
Posted by eightonedee at 18:24, 12th July 2025
Posted by Ralph Ayres at 17:33, 12th July 2025
Posted by a-driver at 17:08, 12th July 2025
GWR were instructed to release the 387's by the DfT.  As Oxford wasn't electrified the DfT calculated that GWR had a surplus of 387's
There was I believe, a points failure at Didcot with no access from Reading to Oxford.  Trains used Foxhall Jn which requires a reversal and free platforms at Didcot.
Decision are never made to benefit the company.  The controllers sole intention is trying to keep things moving with what you've, some days whatever decision you make minutes later something else happens that scuppers that plan.
Posted by lbraine at 16:29, 12th July 2025
Friday was the return trip - leaving Cambridge at 1:00pm on a GWR liveried  Class 387, albeit with logo removed. I actually spotted 3 more on this trip - I was unaware GWR were transferring these to other operators. Even the WiFi onboard was GWR, so it must be a recent movement.
I arrived to see the train I was trying to catch showing for Platform 12. Five minutes after the supposed departure  this changed to Delayed - which a s everyone knows is GWR speak for a coin-toss as to whether the train will depart or not.
… I could go on.
Posted by Ralph Ayres at 10:37, 12th July 2025
The lines may have been open but certainly around 1900 when I arrived trying to reach West Drayton, nothing was running on the relief lines with TfL having given up completely. Only reported delay was west of Reading, and nothing had been mentioned in the banner on the NRE app or I'd have taken a very different route from my starting point of Alton having already had to detour thanks to two successive GWR cancellations on the line from Gatwick.  The information booth seemed to know less than I could work out from the departure screens and kept telling people to ask gateline staff; I'd expected the booth would at least have a feed of the signal diagram showing actual locations, train running info etc.  Eventually got on an eastbound IET which I'm sure was shown as calling additionally at Slough to get me closer, but ran non-stop to Paddington. By that time Lizzie trains were running west to Heathrow via Hayes so took that option followed by a bus. Fortunately I was in no hurry and the trains had working air conditioning.
Posted by a-driver at 21:07, 11th July 2025
Posted by TaplowGreen at 20:21, 11th July 2025
Posted by TaplowGreen at 18:00, 11th July 2025
Posted by grahame at 16:37, 11th July 2025
I'm not in the UK at the moment and they seem to do things differently here.  As I understand it earlier today, there was a fault on the train we were waiting in, and we all transferred to another just along the platform. There seems to be an appreciable supply of parked trains at most operating centres, some of which I suspect are spare donors but some are in running order, and this provision of a few spares - no doubt each given a run from time to time - seems to make sense.  I would prefer and older train occasionally to no train.
Posted by TaplowGreen at 16:22, 11th July 2025
Another Turbo has sat down.
...........and another
Updated;
Posted by TaplowGreen at 16:11, 11th July 2025
Posted by Timmer at 16:09, 11th July 2025
Posted by lbraine at 16:02, 11th July 2025
Mini melt down at Reading taking place. Announced as an issue getting u its out of Reading Traincare Depot.
Three missing Thames Valley services (Delayed)
Cancellation to Basingstoke and Newbury
Seems the Class 387 don’t like the heat !
Posted by TaplowGreen at 11:19, 11th July 2025
Train services running to and from these stations will be delayed by up to 15 minutes. Disruption is expected until 1130
Posted by IndustryInsider at 16:48, 4th July 2025
Ah, fair enough, it looked like you were after a more radical change of wording than that.  Though I would suggest the phrase ‘on the branches’ would mean nothing to a fair few passengers, so you would still want to list them like in the original message.
Posted by TaplowGreen at 16:14, 4th July 2025
Posted by grahame at 11:46, 4th July 2025
Edit to correct quoting
Delays to services at Slough
Lovely day for it.
Not a very good day......
