AQ11 - trivia questions in our region
As at 8th January 2025 02:57 GMT
Re: AQ11 - trivia questions in our region
Posted by Ollie at 03:25, 13th December 2024
* Three GWR▸ stations which - though not terminii - you can only leave in one direction on a passenger train
Also Bedwyn no trains to destinations further down the line or from further down the line call there.
Although not frequent, Bedwyn has services from both directions.
Posted by stuving at 11:21, 12th December 2024
* Over 500 metres long and carrying a Community Rail line over a river
I had Tamerton Foliot bridge over the Tavy, but the Thames bridge on the Windsor Branch may fit the bill. Is that community rail though?
The Windsor branch certainly is not a Community Rail Line - perhaps more royal than communal - but its viaduct is well over 1500 m long. The Tavy bridge, however, is less than 500 m long however you measure it. Wikipedia has 453 m, implying it has stretched quite a bit in use since it was built, and announced as 1429' long (436 m). More prosaically, I suspect it is now being measured to the ends of the parapets, rather than to the abutment faces; is the latter the "official" way of doing it?
Posted by grahame at 04:46, 12th December 2024
* Three GWR stations which - though not terminii - you can only leave in one direction on a passenger train
I had Coombe Junction, Bere Alston and Pilning and had overlooked Bourne End
* Two GWR operated stations between which you cannot buy a ticket
St Budeaus Ferry Road and St Budeaux Victoria Road
* Engineering feature over 7000 metres long and carrying a main line
Severn Tunnel
* A journey on which the last through service leaves at 05:44, a journey on which the last through service leaves at 07:11, and a journey on which the last through service leaves at 07:21 (though not today  Angry )
Paddington to Greenford, Chippenham to Penzance and Melksham to Worcester
* A station which was built in 1850, but did not see its first train until 1857
Bradford-on-Avon
* A railway that was standard gauge for the first 20 years after it opened, then dual gauge, then back to standard gauge.
Truro to Penzance - West Cornwall
* Standard gauge is 4'8.5" - but where in the west was there a railway with a 4'6" gauge
Plymouth and Dartmoor Railway
* Passenger services started on 25th March 1807 and ceased on 5th January 1960
Swansea and Mumbles
* Closed 7th September 1964 and re-opening, perhaps, on 12th September 2027
Portishead
Posted by Surrey 455 at 20:18, 11th December 2024
**Three GWR stations which - though not terminii - you can only leave in one direction on a passenger train:
Banbury, Basingstoke and Gatwick Airport. - Although I guess technically they are not GWR stations but stations GWR use and you can leave them in other directions with other TOC's. Maybe need to think again
Ah, I was going to say Redhill but that's a Southern station.
Posted by grahame at 19:34, 11th December 2024
Clifton Bridge Station on the Port Z line ...
I'm playing the game of "here is the answer - but WHAT question does this address".  Is it the one about many years from being built to its first train?   ...  It may be but not the one I had!
Posted by Western Pathfinder at 18:29, 11th December 2024
Posted by ellendune at 16:42, 11th December 2024
I reckon....
Bourne End
Bere Alston
Coombe Junction
What about Carmarthen (which, like Bourne End, originally had two ends) and Swansea
Posted by TonyN at 16:40, 11th December 2024
Posted by Chris from Nailsea at 15:44, 11th December 2024
Portishead.
Good luck with that one.
Posted by PhilWakely at 14:37, 11th December 2024
St Budeaux Ferry Road and St Budeaux Victoria Road
Posted by johnneyw at 14:35, 11th December 2024
I'll guess Heath High Level and Heath Low Level.  I know that you can't buy a ticket between Catford and Catford Bridge (Geoff Marshall made a video about this), and the Heaths are similarly close to each other.
[Edit: probably the wrong answer because they are probably TfW rather than GWR, doh]
Something in the back of my mind said it might be two local Plymouth stations that are close to each other....or has my imagination rather taken over?
Posted by ChrisB at 14:33, 11th December 2024
Fair - so the Low Level & either of the other Worcester stations....
Posted by grahame at 14:29, 11th December 2024
Worcestershire Parkway High Level to Low Level.
Same station, Chris?  - both WOP and isn't it one sequence of platform numbers off a common atrium?
Posted by ChrisB at 14:25, 11th December 2024
Posted by eightonedee at 13:45, 11th December 2024
Is this the brick arch viaduct (with bridge at one end) carrying the Slough to Windsor line across the Thames and meadows to the north?
Posted by PrestburyRoad at 13:21, 11th December 2024
Posted by grahame at 13:11, 11th December 2024
Of course there is allways Pilning which you can only leave in one direction.
Yep, that was the other one I had
Posted by Western Pathfinder at 13:09, 11th December 2024
Posted by old original at 12:40, 11th December 2024
Pedant alert...
Aren't Carmarthen and Swansea TfW stations?
Posted by eightonedee at 12:38, 11th December 2024
Does Swansea fit this?
Posted by Mark A at 12:30, 11th December 2024
Is Okehampton a terminus and if it isn't what about Carmarthen? Maybe i am thinking to hard
Not thinking too hard. Okehampton's a temporary terminus. (And Carmarthen's a disgrace).
Posted by grahame at 12:00, 11th December 2024
I reckon....
Bourne End
Bere Alston
Coombe Junction
Yes, and oh my goodness I had forgotten one of them.  There is a fourth (at least) ...
2nd attempt - Coombe Junction Halt, Bere Alston, Okehampton. Is Okehampton a terminus and if it isn't what about Carmarthen? Maybe i am thinking to hard
Sadly, Okehampton IS a terminus at present - just like you can no longer carry on from Barnstaple.  I will give you Carmarthen though - and I still have one more that's a bit different.
Posted by ray951 at 11:55, 11th December 2024
Ah, shows the great danger of trying to write quiz questions.   All three of these you can leave from either end of the station having got on to a passenger train / agreed that the dark green GWR things only go from one end, but there are other train operators around ;-)
Reading the question back, I was looking in our region - to avoid answers such as "Fort William".
Posted by old original at 11:51, 11th December 2024
I reckon....
Bourne End
Bere Alston
Coombe Junction
Posted by froome at 10:21, 11th December 2024
Ah, I think that rules out my suggestion for one of the stations, which is Pilning, which I believe you can only travel in one direction from? (towards Bristol)
Edit note: Quote mark adjusted, for clarity. CfN
Posted by grahame at 09:11, 11th December 2024
Posted by Oxonhutch at 09:08, 11th December 2024
*Engineering feature over 7000 metres long and carrying a main line.
Severn Tunnel, 7008m
Posted by ray951 at 08:36, 11th December 2024
Posted by grahame at 06:34, 11th December 2024
Some trivia questions - how many can you answer? Just tell me how many - go ahead and follow up with an answer each too if you wish
* A journey on which the last through service leaves at 05:44, a journey on which the last through service leaves at 07:11, and a journey on which the last through service leaves at 07:21 (though not today  )
