A history of time - OTD 13th October 1884
26.6.2025 (Thursday) 04:58 - All running AOK
Re: A history of time - OTD 13th October 1884
Posted by Mark A at 15:07, 14th October 2024
Sometimes known as a 'Bolinder clock'.
Posted by grahame at 13:18, 14th October 2024
The town hall clock pictured above is far more useful than a clock that is running.
I used to have an analogue electric clock that would sometimes run backwards when plugged in.  Right four times a day AND if you knew when it has started in was a good test if you were awake, intelligent and sober to work out the actual time based on what it said.
Posted by broadgage at 11:11, 14th October 2024
It is accurate twice a day, and at the same times every day ! if a clock is running then it might never be right, or more likely will only be right at and long and unknown intervals.
P.S. on the Corn exchange, Bristol there is a clock with two minute hands, one shows Greenwich time and the other shows the local time. The difference is a little over 10 minutes. If that clock stops, it will accurate FOUR times a day.
Posted by GBM at 11:09, 13th October 2024
Standardisation of time is a fascinating subject.
Here in Melksham, we aren't yet fully standardised.  Time on Spa Road is a couple of minutes behind time elsewhere, and the driver of the x34 I rushed up to at 06:53 my time on Friday informed me I was lucky to catch the bus as it was 06:55 and he was due out at 06:54.  A good example of why we should standardise time.
The number of times passengers have said how lucky they were to catch the bus when I've been running late! Thank you passenger(s), you've just added another slight delay to my already late running.
No, I've never said anything, apart from maybe "That's OK" on occasions.
Only one a few occasions in 14 years has a passenger queried if I was early or late.
Early? an offence with First (but not unknown.....).
Posted by bradshaw at 08:31, 13th October 2024
With the plans for the Bridport Railway freshly announced Bridport Borough Council added a second minute hand to the Town Hall Clock so that it shiwed Local and London Time!
Posted by grahame at 06:38, 13th October 2024
Standardisation of time is a fascinating subject. How with the coming of the railways times / clocks in different towns were co-ordinated to remove confusion, and aid safety on systems of signalling that were time dependent. GWR were in the lead on this in the 1840s.  Story at https://en.wikipedia.org/wiki/Railway_time . It took until 13th October 1884 for the Greenwich Meridian to be officially accepted as the government's zero line according to Beautiful Britain
Time stands still in Melksham ... the Town Hall Clock is right just twice a day at 06:13 and 18:13
