| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by IndustryInsider at 11:07, 18th February 2026 | ![]() ![]() ![]() |
With what stock, I wonder?
Based on the 70-minute journey time, two 5-car IET's would be required for a service every two hours. Only the one extra for the hourly service, with around 40 minutes total turnaround time at Bristol and Oxford each cycle.
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by Richard Fairhurst at 09:43, 18th February 2026 | ![]() ![]() ![]() |
Interesting coz one of the reasons for turning down additional services on that stretch between Swindon & Didcot West was lack of pathing. They've already to find room for the West Wales - Paddington open access
Network Rail looked at four applications together: GWR Oxford-Bristol, Midland Central Western Railway (aka SLC Rail) Nottingham-Bristol, Lumo Paddington-Hereford, Lumo Paddington-Paignton.
They said GWR Oxford-Bristol would fit, although they might need to send a couple of services via Bristol Parkway rather than Bath. Lumo Paignton and Lumo Hereford would partly work on weekdays but not really at weekends. Their opinion on MCWR is perhaps best summed up with the phrase "lol nope".
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by bobm at 19:51, 17th February 2026 | ![]() ![]() ![]() |
Those in Bedwyn believe it will use stock being released from elsewhere that was earmarked to restore their through services to London Paddington.
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by ChrisB at 19:03, 17th February 2026 | ![]() ![]() ![]() |
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by Richard Fairhurst at 18:59, 17th February 2026 | ![]() ![]() ![]() |
It's not up to Hendy to approve it, it's up to the ORR. As far as I can see from the Swindon press release, Hendy has just written a letter saying "that sounds like a nice idea".
That said, apparently Network Rail are broadly supportive, so there's probably not much standing in its way. Assuming enough 175s can be crank-started so some IETs can be released...
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by ChrisB at 18:43, 17th February 2026 | ![]() ![]() ![]() |
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by anthony215 at 18:30, 17th February 2026 | ![]() ![]() ![]() |
Local councillors in Swindon saying lord Hendy has approved a 2 hourly Swindon to Oxford service
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by bobm at 15:32, 31st January 2026 | ![]() ![]() ![]() |
Problems with the service today.
The first round trip arrived back at Bristol Temple Meads nearly 25 minutes late. The second round trip was then cancelled due to "a fault on this train".
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by Richard Fairhurst at 16:19, 2nd January 2026 | ![]() ![]() ![]() |
A rather peevish response from the Bedwyn folks to the Oxford–Bristol plans:
https://www.railmagazine.com/news/passenger-group-concern-over-gwr-oxford-bristol-plans
As Rail points out, the Government expressly asked GWR for a Bristol–Oxford plan in 2023 (following up many years' lobbying by Oxfordshire County Council and others), so the assertion that "The Oxford-Bristol plan is seen as an attempt to offset a potential threat from SLC Rail’s proposed Nottingham-Bristol via Oxford open access service" doesn't really hold water IMO.
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by IndustryInsider at 12:56, 5th December 2025 | ![]() ![]() ![]() |
The latest Oxford Clarion newsletter reports that GWR have applied to the ORR to introduce a full Oxford–Bristol service. Every two hours from May 2026, increasing to every hour from May 2027.
More details here:
https://www.orr.gov.uk/sites/default/files/2025-11/gwr-ltd-s22a-301st-sa-network-rail-representations.pdf
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by Richard Fairhurst at 12:47, 5th December 2025 | ![]() ![]() ![]() |
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by IndustryInsider at 11:50, 18th November 2025 | ![]() ![]() ![]() |
Correct. Talk to your MP.
Sympathy for GWR. Their budget is still shrinking year-on-year
..............not too much sympathy though
https://www.firstgroupplc.com/investors/results-centre.aspx
Shares currently down 12.5% today.
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by TaplowGreen at 07:04, 18th November 2025 | ![]() ![]() ![]() |
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by Ollie at 23:14, 16th November 2025 | ![]() ![]() ![]() |
Ollie - are you saying that the same PAD non-HSS drivers drive 166s AND 800s? And the HSS drivers also drive just 800s?
To answer on behalf of Ollie, yes that’s correct. Non-HSS drivers sign Turbos, IETs, and 387s.
Thank you II.
Some also sign the Class 230.
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by IndustryInsider at 20:21, 16th November 2025 | ![]() ![]() ![]() |
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by ChrisB at 17:45, 16th November 2025 | ![]() ![]() ![]() |
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by grahame at 17:44, 16th November 2025 | ![]() ![]() ![]() |
Money.
All the abilities you are suggesting with flexibility cost money. And if the DfT don't want the flexibility, they won't pay GWR for it. GWR have NO choice, but do the DfT bidding.
So if it's true that every idea would cost money, logic suggests we need to amend the DfT's bidding and priorities, doesn't it. And/or that we take a look and see if there's some sort of way that the various objectives come together in such a way that everyone involved want to work for them and get dividends.
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by ChrisB at 17:27, 16th November 2025 | ![]() ![]() ![]() |
Money.
All the abilities you are suggesting with flexibility cost money. And if the DfT don't want the flexibility, they won't pay GWR for it. GWR have NO choice, but do the DfT bidding. You do know that!
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by grahame at 08:25, 16th November 2025 | ![]() ![]() ![]() |
Many thanks for that insight into a complex situation, Ollie - I read the answer as being somewhere between a glib "no, no, no" and something that can obviously be done. "Where there's a will, there's likely to be a way" - we haven't considered the cascading / transfer of trains to meet the commitments, for example. Sorry - but I remain of the concern that GWR do not have enough resources or enough flexibility in their resources to meet their day to day commitments to a reasonably robust degree throughout. Management thing - they have gotten into a situation where far too many difficult calls have to be made, and as those calls are made and the results do severe damage to the business, to the customers, and to the communities they 'serve'.
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by Ollie at 03:22, 16th November 2025 | ![]() ![]() ![]() |
Route knowledge is probably a bit of a topic in itself, each depot has different routes and traction knowledge, then even within that depot the levels of route and traction knowledge will be different.
To use the current example, the Oxford - Bristol services are currently being operated by Paddington drivers, we do not sign via Melksham so wouldn't be of any use to cover the services Graham has mentioned. At Paddington on the non-HSS side, we are multi traction (not 158s) which is why the service was able to be a 166 vice 800 last week.
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by grahame at 21:07, 15th November 2025 | ![]() ![]() ![]() |
Different depot. Different traction. Different route.
Graham knows this....
Not that simple. yes, Chris, Bob has given the "official" answer ... but why is that so?
Bristol to Swindon services can be diverted via a reversal at Bradford South Junction and so surely drivers have that route knowledge, further there is a direct Bristol to London via Wesburty service ... and staff do overlap / work with the next depot.
And didn't I note that the Bristol -> Oxford ran - was it today or last week - 3 car. So the driver that time knew how to drive a 165, 166 or 158 which are exactly the units used on the Westbury to Swindon.
"Different depot. Different traction. Different route." is easy to say but those all overlap and have fuzzy edges, so it's a convenient reason to have. It's not as if there was a spare driver at St Blazey or Redhill. There is the wider question as to why there are such tight route knowledges and thin overlaps these days, so that if anything goes that bit wrong recovery, the system doesn't have the ability to switch and recover easily.
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by ChrisB at 20:36, 15th November 2025 | ![]() ![]() ![]() |
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by bobm at 16:59, 15th November 2025 | ![]() ![]() ![]() |
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by grahame at 16:19, 15th November 2025 | ![]() ![]() ![]() |
Nine coaches on today's services in place of the usual five (or the three which did last Saturday's first round trip).
So they have enough staff to run those experimental services but not the standard contracted bread and butter stuff between Westury and Swindion - two round trips on there cancelled again today, "shortage of staff".
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by bobm at 16:15, 15th November 2025 | ![]() ![]() ![]() |
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by ChrisB at 20:52, 28th September 2025 | ![]() ![]() ![]() |
With the direct train cancelled, permission should be granted for any reasonable (more expensive) routings
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by grahame at 21:35, 27th September 2025 | ![]() ![]() ![]() |
Well....some might have preferred to take longer but easier with lifts and go via Reading?
And ... at a higher price; my ticket was "not via Reading".
Of course, you could now do Oxford to Bristol Temple Meads with a single change at Worcestershire Parkway ;-)
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by ChrisB at 21:12, 27th September 2025 | ![]() ![]() ![]() |
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by Mark A at 20:57, 27th September 2025 | ![]() ![]() ![]() |
As I came through Didcot, I noticed that helpful announcements were being made directing people off the train from Oxford to go through the subway and turn left up to platform 1 to head west.
With the direct train cancelled, what other options were there? Unless I'm misreading Realtime Trains, without something making an additional call at Didcot, the opportunities are quite sparse.
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by Mark A at 19:56, 27th September 2025 | ![]() ![]() ![]() |
As I came through Didcot, I noticed that helpful announcements were being made directing people off the train from Oxford to go through the subway and turn left up to platform 1 to head west. Only those of us in the know would have carried on through the barrier's wide gate, right, around the outside, up the slope and then back in through the sloped wide gate. One couple were trying it but struggling for at least 5 minutes with the barrier which was unstaffed, closed, and by the looks of things reusing their ticket. I know there was probably a help point / button they probably weren't aware of. What a wonderful way to encourage custom.
Yes, there is: during the earlier part of the covid pandemic, and returning from the notorious April 'Day return to Finmere' expedition, it refused my ticket too and summoned a railway genie using the 'Help' button.
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by grahame at 19:37, 27th September 2025 | ![]() ![]() ![]() |
Funnily enough, I took the opportunity of an arrival in Swindon with a LONG wait for the next Melksham train to walk up to the bus boulevard for a first look, then took the 49 to Devizes and the 273 on from there to Melksham. Now recovering from the long day as I walks substantially on having parted company with Mark.
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by Mark A at 19:14, 27th September 2025 | ![]() ![]() ![]() |
Fortunately (for certain defined values of 'Fortunately') after we briefly enjoyed what the Turf PH had to offer, I needed to abandon Graham to further explorations of Oxford and head for a shop, then an earlier return than the through train offers.
For good measure, I chose the option to head through the walkway beneath the lines at Osney rail bridge, along the Botley Road across the Thames (impressive building site for most of the way and most photogenic photo opportunities now blocked by hoarding). After negotiating that, I headed to the bus stop for Swindon, enjoying the journey on a more or less empty top deck of a double decker bus via Faringdon.
It's safe to say that rail staff who in the dim and distant past worked the branch to Faringdon would not recognise the approach to the town now, with a retail park built beside the route, while the road approach to the town, built on top of the branch, runs alongside new housing estates. At a later stage in the journey, the bus route provides an opportunity for canal spotting, and if anything, there's rather more to be seen of that than there is of the branch line to Faringdon.
At Swindon, the old bus station is already starting to fade out of existence - even more than it faded when it was in use that is. Pulling up in the bus boulevard and heading for the railway station, I quickly learned that it's best to cross to the western side of Milford Street to avoid some not brilliant paving, it's a little further, but it wasn't a huge hike. There's mapping on the funded-by-advertising bus-stops-with-seating that puts the place in context, though I didn't quite investigate what signage there is between station and buses - in either direction. Perhaps it's fine. The bus boulevard didn't feel like an enormous hub of activity, but maybe that's just 2025 Swindon new town centre for you, even at ten to five on a Saturday afternoon.
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by grahame at 19:11, 27th September 2025 | ![]() ![]() ![]() |
Chippenham to Oxford this morning was fine bus ...
15:18 Bristol Temple Meads to Oxford due 16:29
17:12 Oxford to Bristol Temple Meads due 18:23
17:12 Oxford to Bristol Temple Meads due 18:23 will be cancelled.
This is due to a short-notice change to the timetable.
Real time trains blames a planning error.
Yep, I suspect that the train path was in the timetable until it was notices that it was missing a physical train, a driver or a train manager, at which point the timetable was changed
Whichever - this is what it lead to at Oxford
and this was the sort of thing people then had to do at Didcot
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by bobm at 16:10, 27th September 2025 | ![]() ![]() ![]() |
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by grahame at 16:00, 27th September 2025 | ![]() ![]() ![]() |
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by grahame at 11:10, 16th September 2025 | ![]() ![]() ![]() |
From https://www.facebook.com/MelkshamTUG
From this Saturday, 20th September 2025, the Saturday through train from Chippenham to Oxford returns. Connection at 10:09 from Melksham, 10:44 from Chippenham, arrive at Oxford at 11:27. Return service direct to Chippenham from Oxford at 17:12, or return to Melkshan at 16:30, 18:02 or 20:05, changing at Didcot and Swindon.
Day return fare - £21.80 each, or £14.50 each with a railcard or in a group of 3. Same fare also applies if you want to go on from Oxford to Bicester Village, and it's the same fare from Melksham or Chippenham.
Tickets can be purchased prior to departure at the ticket machines at Melksham or at Chippenham Station, or from the ticket office in Chippenham or if you are paying in cash on the train from Melksham.
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by TaplowGreen at 11:53, 6th September 2025 | ![]() ![]() ![]() |
Which leads me to the question: At what point does a train manager decide to allow standard class passengers occupy first class seats?
Hardly ever in these days of bargain advance first class fares. First class occupancy, percentage of seats wise, is often the same or even more than standard class on many trains.
"Bargain" doing some extremely heavy lifting there!
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by ChrisB at 11:24, 6th September 2025 | ![]() ![]() ![]() |
Yes, that's the date for the winter service
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by Mark A at 10:35, 6th September 2025 | ![]() ![]() ![]() |
The Saturday service recommences on the 20th September, yes?? Realtime Trains lists it from that date.
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by ChrisB at 17:00, 30th July 2025 | ![]() ![]() ![]() |
Bit worrying that they're the only services featuring on that day though!
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by Richard Fairhurst at 12:20, 30th July 2025 | ![]() ![]() ![]() |
Being reported locally that there are Oxford<–>Swindon hourly ECS paths in the December timetable, which is intriguing:
https://bsky.app/profile/oxfordclarion.bsky.social/post/3lv6cv2p3gk2o
Maybe these are route-learning runs as per II's suggestion above that Oxford crews will sign as far as Swindon?
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by IndustryInsider at 09:59, 13th April 2025 | ![]() ![]() ![]() |
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by eightonedee at 09:58, 13th April 2025 | ![]() ![]() ![]() |
The Beaufort scale of train carriage loading.
This could also have Beaufort-like descriptions of what to look for to avoid having to count seats (like the "white horses begin to appear on waves at sea" or "some trees lose branches" notes you used to see).
Suggestions - for "Busy" - "passengers begin asking anyone with bags on seat to move them or saying "is anyone sitting there"?
For "nesting/nearly every seat taken" - "Announcements made that there are still a few seats available at the front/back of the train"
For "full and standing" - "on-board train staff no longer walk along the train, anyone with a bicycle in a vestibule gets black looks from fellow passengers".
"Stuffed" - "Between Paddington and Reading".
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by froome at 08:47, 13th April 2025 | ![]() ![]() ![]() |
Hmm - I think 'Rammed' = 110% plus....so full & standing
Got me thinking - load definitions
0 to less than 5% - "Fresh Air"
5% to less than 15% - "Light"
15% to less than 25% - "Quiet"
25% to less than 50% - "Comfy"
50% to less thsn 80% - "Busy"
80% to less than 95% - "Nesting / Nearly Every Seat Taken"
95% to less than 110% - "Full and Standing"
110% to less than 125% - "Rammed"
125% to less than 150% - "Stuffed"
Over 150% - "Stupid"
$64,000 - by a seat being occupied, are we counting bums, or bums and bags?
Are you including First Class seats in those figures. If so, anything above 80% could easily include full and standing in Second Class.
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by Mark A at 21:14, 12th April 2025 | ![]() ![]() ![]() |
I knew we could rely on you. The Beaufort scale of train carriage loading.
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by grahame at 21:07, 12th April 2025 | ![]() ![]() ![]() |
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by ChrisB at 12:16, 12th April 2025 | ![]() ![]() ![]() |
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by Mark A at 11:09, 12th April 2025 | ![]() ![]() ![]() |
A report from this morning's Bristol to Oxford service: many people leaving the service at Bath, then, later, 'Absolutely rammed' from Swindon to Oxford.
Update: 'Rammed' = about 80% occupancy, so, comfortably full in standard.
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by grahame at 08:31, 14th March 2025 | ![]() ![]() ![]() |
An hourly service with a running time of just over 1 hour Bristol to Oxford - 3 trains in the "cycle" - extend it to Milton Keynes and the running time looks like it would be around 1 hour 45 minutes, so 4 trains in the cycle (educated guess - looking at the running time of the Verney Venurer as shown on Six Bells Junction). With the extra train required for this, we must note that it would / will be one of the Oxford - Milton Keynes services anyway, so that the it's not really an "extra" train.
For sure, ChrisB, more peoeple coming into Oxford from Swindon would get off than stay on, but quite a number would stay on and many more would join. Rather like the Cardiff - Portsmouth service has major changeovers at Bristol and at Southampton.
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by grahame at 22:04, 13th March 2025 | ![]() ![]() ![]() |
Why would Milton Keynes be a more attractive destination than Oxford?
People could travel there to connect with other services and destinations plus this service would allow people to avoid have to travel across London or even changing at Birmingham new street etc
Taken to extremis, this is a pretty good - err "CrossRail 3"
Weymouth
Dorchester for Poole and Bournemouth
Yeovil Junction Lower Platform for Salisbury - Exteter line
Castle Cary for Taunton, Plymouth, Cornwll
Westbury for Reading, Newbury, Bath, Bristol
Chippenham for Bath and Bristol
Swindon for South Wales and Gloucseter
Oxford for Banbury and Leamington and for Worcester and Hereford
Bicester Village for Bang & Olufsen, Barbour, Beauté Prestige International, Belstaff, Benefit Cosmetics, Bonpoint, BOSS and many more
Bletchley for Northampton, North West, North Wales, Scotland
Bedford for Leicester, Derby, Nottingham and Sheffield. Also for Luton
Sandy for Peterbourough, Doncaster, Leeds, York and Newcastle
Cambridge for Kings Lynn and for Ipswich and Harwich
Norwich for Cromer, Sheringham, Lowestoft
Great Yarmouth
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by anthony215 at 21:18, 13th March 2025 | ![]() ![]() ![]() |
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by Chris from Nailsea at 19:51, 13th March 2025 | ![]() ![]() ![]() |
As this very welcome 'news' discussion develops, I've removed the link to last year's specific date in our calendar and expanded the heading of this topic - purely in the interests of clarity and ease of future reference.
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by IndustryInsider at 18:09, 13th March 2025 | ![]() ![]() ![]() |
On its own, it wouldn't. But if you add the people attracted to Milton Keynes to the people attracted to Oxford, you may get better mass transit which is combining all the flows along a flow and sharing costs between all the various bums on seats.
Quite agree. The more East-West rail becomes a true East-West service over time - Bristol<>Milton Keynes/Bedford/Cambridge and perhaps beyond to Norwich/Ipswich - the appeal grows and an ideal route for a 5-car IET. Not dissimilar to the Cardiff<>Portsmouth or Norwich<>Liverpool routes where relatively low numbers of people are travelling the whole route, but taken as a whole with people joining/alighting at various points en-route, it's difficult to not see it being extremely popular.
But for now I'll be very happy for a new hourly Bristol<>Oxford service. With a presumed target journey time of 70-75 minutes, three IETs would be needed with sensible layovers at each end of the route. Platform 5 at Oxford should be ready by then and IETs should be available by then with Class 175s taking over existing IET diagrams in the west. Crew availablility remains a slightly thorny issue, but drivers wise some Oxford based crew are about to 'sign' as far as Swindon and that would be the logical depot, along with Bristol, to work it.
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by grahame at 16:56, 13th March 2025 | ![]() ![]() ![]() |
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by ChrisB at 16:26, 13th March 2025 | ![]() ![]() ![]() |
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by anthony215 at 16:24, 13th March 2025 | ![]() ![]() ![]() |
Possible progress, with an hourly Bristol-Oxford service hoving in to view. Hopefully.
https://www.bbc.co.uk/news/articles/cedlxqg7ex5o
Long overdue I think it will prove quite popular especially if it ran beyond Oxford to Milton keynes
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by Mark A at 11:40, 13th March 2025 | ![]() ![]() ![]() |
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by grahame at 08:53, 22nd February 2025 | ![]() ![]() ![]() |
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by Chris from Nailsea at 18:56, 2nd February 2025 | ![]() ![]() ![]() |
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by John D at 08:29, 2nd February 2025 | ![]() ![]() ![]() |
Of course, Bristol to Milton Keynes with no changes would be easily possible as well. One might say, the perfect use of an IET!
Or a 110mph EMU with batteries.
Anyone know what is happening to the surplus 350s (the 37 units 350 231-267) which are only 16 years old
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by IndustryInsider at 16:11, 1st February 2025 | ![]() ![]() ![]() |
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by ChrisB at 15:40, 1st February 2025 | ![]() ![]() ![]() |
I'm sure there is one - and a thread already to post it in?
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by grahame at 15:39, 1st February 2025 | ![]() ![]() ![]() |
From the Western Gateway SubNational Transport Body
https://westerngatewaystb.org.uk/wp-content/uploads/2025/01/31921-The-case-for-reinstating-rail-services-Oxford-Bristol.pdf
The case for reinstating Oxford-Swindon-Bath‑Bristol rail services
Quick, affordable and transformational change for the UK economy and transport system
At a glance:
There is a quick, affordable and simple opportunity to reinstate direct rail services between Oxford and Swindon, Bath and Bristol.
Building on the current – highly popular – trial service on Saturdays the new service would provide an all day, every day hourly service.
Journey times between Oxford and Bristol would be a less than an hour and a quarter, and between Oxford and Swindon just over half an hour.
New daily, hourly services will better connect high-performing, knowledge‑intensive sectors and universities at the heart of the Government’s new industrial strategy, together with some of the country’s most popular tourist destinations.
The scheme would add help maximise the value of investments elsewhere, most notably East West Rail (making it possible, as early as 2026, to travel between Bristol and Milton Keynes with only one change) and MetroWest.
This opportunity does not require capital investment
– the necessary infrastructure is already there. Instead, it requires commitment to fund the operational costs of the new service (ie, train crew, fuel, network access costs, and rolling stock lease cost).
Our ask to government: To specify the service in future timetables and commit to fund its additional operational costs (with the expectation that the service is likely to generate more revenue than it will cost).
At a glance:
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by grahame at 11:27, 1st February 2025 | ![]() ![]() ![]() |
10:18 Bristol Temple Meads to Oxford due 11:27
10:18 Bristol Temple Meads to Oxford due 11:27 has been delayed at Chippenham and is now 8 minutes late.
This is due to congestion.
Will be formed of 9 coaches instead of 5.
Not a problem ... good that it's running ... right through to May ..
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by Mark A at 17:55, 28th December 2024 | ![]() ![]() ![]() |
Whew, nearly went to Oxford to collect something heavy.
"Changing at Reading", eh?
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by grahame at 12:51, 28th December 2024 | ![]() ![]() ![]() |
12:02 Oxford to Bristol Temple Meads due 13:12
17:12 Oxford to Bristol Temple Meads due 18:27
28/12/24 17:12 Oxford to Bristol Temple Meads due 18:27 will be cancelled.
We are sorry that this service is cancelled today due to a shortage of train crew. Alternative services are available by changing trains at Didcot Parkway or Reading.
| Re: Leaflets for the BRI-OXF service? Posted by ChrisB at 21:13, 29th November 2024 | ![]() ![]() ![]() |
Not that I've seen around the Oxford area.
I would doubt it as timetables don't appear in racks anymore
| Leaflets for the BRI-OXF service? Posted by grahame at 18:04, 29th November 2024 | ![]() ![]() ![]() |
From my inbox
Have GWR produced a leaflet which deals specifically with the Saturday Bristol - Oxford?
I don't see anything ... but wonder if anyone else has?
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by grahame at 12:01, 16th November 2024 | ![]() ![]() ![]() |
12:03 Oxford to Bristol Temple Meads due 13:12
12:03 Oxford to Bristol Temple Meads due 13:12 will be cancelled.
15:14 Bristol Temple Meads to Oxford due 16:31
15:14 Bristol Temple Meads to Oxford due 16:31 will be cancelled.
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by Richard Fairhurst at 18:03, 29th October 2024 | ![]() ![]() ![]() |
Though even SDO isn’t a panacea - the reason we apparently have never had 2x5 IETs on the Cotswold Line, despite expensive platform lengthening, is platform-end signal siting.
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by grahame at 14:43, 29th October 2024 | ![]() ![]() ![]() |
Thanks. That rather shows how capacity-constrained the railways are, that a one day a week service can be reinstated after a gap of some years and promptly fills standard class in a 5 carriage IET full and standing. It's dire, the cost of the infrastructure that could be bringing in far more income but there's often not the capacity in the trains or the variety of services to attract and carry an increase in passenger numbers.
The really interesting thing with infrastructure limits is that the running of a 9 car IET rather than a 5 car one, or a 5 car train rather than a 3 car one (BTH to BOA) would make very little difference indeed to the number of trains that could pass over the line, or the number of train drivers and train managers needed, For sure, there aren't enough trains
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by Mark A at 14:24, 29th October 2024 | ![]() ![]() ![]() |
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by IndustryInsider at 12:25, 29th October 2024 | ![]() ![]() ![]() |
Thought I would give my experience of using the service (early October). Travelled from Bradford on Avon (change at Bath), ticket split at Chippenham
Bit of scrum at Bath, reservations not working (train manager said not programmed)...
The destination displays also displaying Reading. Apparently since announcing the service in January haven't yet found time to add the route to train computers !
The latest database update (that included added Melksham to the SDO station list) included generic headcodes for these services, so if the journey and reservations don't load the destination and calling points should now display and announce properly - provided the Driver or TM enters them.
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by John D at 11:45, 29th October 2024 | ![]() ![]() ![]() |
No was just a sunny day, but our split tickets were mix of off peak day returns and anytime day returns. So no real control of volumes sold.
Incidently we had to stand Bath-BoA on return because it was just a 3car turbo with people already standing when it arrived at Bath, and was very busy with rugby fans as match had recently ended at Bath. And yes had one of those pointless counted place reservations that basically get you a bit of standing space.
More a case of weekend leisure journeys can see more passengers when good weather is forecast, but GWR doesn't have sufficient stock to lengthen trains.
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by grahame at 09:32, 29th October 2024 | ![]() ![]() ![]() |
No ticket checks and at at Oxford the exit gates near the footbridge were open so no revenue check on whole outbound journey.
I can understand your concern at that - but yet is there a need to check tickets on every journey? A random sprinkling of tickets checks should deter unpaid travel and you will find that very much the way it's done across many countries. Because people who will be inclined to try for a free journey don't know which trains / checks will be on, they will tend to minimise the risks they take and pay, anyway, for services on which it turns out there are no checks. It just "feels" wrong when you buy a ticket and it's never checked.
Another thought / question - was your ticket checked during the return journey? Noting that (and I'm using Melksham which is my knowledge point) Melksham to Oxford off peak day return is £20.80 and Oxford to Melksham super off peak single is £18.60 - if I manage to defraud the railway on the way up, all I'm saving is £2.20 when I get my ticket to come back - not worth the risk.
I would love to see - I think - stronger but occasional enforcement - however, the complexity of the current fare system that even the staff don't always understand has me worried about enforcing on people who have made a mistake and broken the rules.
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by Mark A at 08:13, 29th October 2024 | ![]() ![]() ![]() |
Full and standing from Bath... do you know if there was any special event on please?
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by John D at 07:52, 29th October 2024 | ![]() ![]() ![]() |
Bit of scrum at Bath, reservations not working (train manager said not programmed), our group got scattered finding available seats, handful had to stand. Rather more standing from Chippenham. No advertised trolley service either,
Return train was quieter, but got delayed behind a late crowded 2car turbo on southbound stopping service leaving Oxford, so ran 12-16 minutes late. Arrived Bath 12 minutes late. Missed booked connection (now just 1 minute to get it) . Had to get next train. Arrived BoA 28 minutes late. Submitted delay repay but rejected 2 weeks later as booked train was on time, had to appeal pointing out missed connection, then they decided to pay out for 12.5% of 2 of 3 tickets on submitted 3 tickets of groupsave.
Overall 10/10 for potential free travel on outward train
0/10 for reservations and destination displays
10/10 for train managers announcements
9/10 for journey convenience
0/10 for advertised catering
1/10 for delay repay team
Would love service to be a success, but feel there is too much not working well that would make me happy to use it again.
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by Noggin at 19:50, 25th October 2024 | ![]() ![]() ![]() |
Note that the Wiltshire Rail Strategic Study mentions this service and how it could become both 2 TPH (IIRC) & a means of delivering a service to a new Corsham station.
http://www.firstgreatwestern.info/coffeeshop/index.php?topic=29351.msg353131#new
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by IndustryInsider at 23:07, 15th October 2024 | ![]() ![]() ![]() |
This was confirmed at the TWSW meeting last week - and not only that, but it will continue from Sept 2025 for the season (to May 2026) - still as a trial service though.
Hopefully an all day, all week, service can commence from May 2026? By which time the Class 175 fleet should be fully introduced.
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by ChrisB at 15:47, 15th October 2024 | ![]() ![]() ![]() |
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by bobm at 21:59, 24th September 2024 | ![]() ![]() ![]() |
Not that it is always accurate but if you look on RTT for the 18th January 2025 it shows the Oxford services running Saturdays only from 21st December 2024 to 17th May 2025.
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by grahame at 18:45, 24th September 2024 | ![]() ![]() ![]() |
From this week's Oxford Clarion newsletter
The new Oxford–Bristol direct train service got underway on Saturday. GWR are trialling the service until December, but the Clarion understands that an extension to May could happen if loadings are good. GWR is expecting a new fleet of local trains for Cornwall which could free up trains for a regular Oxford–Bristol link.
Confirmed at WWRUG last Wednesday
Probably the 175s freeing up the IETs
To clarify that confirmation - Bristol -> Oxford may well extend to May. The new service is not expected to run beyond May because the set will be needed for the summer seaside services. Separately 175s to replace remaining HSTs and also IETs from Cardiff west of Exeter.
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by anthony215 at 16:59, 24th September 2024 | ![]() ![]() ![]() |
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by grahame at 21:10, 23rd September 2024 | ![]() ![]() ![]() |
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by ChrisB at 20:50, 23rd September 2024 | ![]() ![]() ![]() |
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by TonyK at 20:28, 17th September 2024 | ![]() ![]() ![]() |
Off Peak adult day return £32.10 according to real time trains, or £21.15 with a senior railcard. Price with a senior railcard rises to £21.35 for next Saturday.
What with the winter fuel allowance going, that 20p hike could be an issue.
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by didcotdean at 11:28, 17th September 2024 | ![]() ![]() ![]() |
Not all football followers want to be in the pubs,
some may have mobility issues and would welcome the chance to have a no change of trains option.
... and those with mobility issues might like to go to the pub too!
I was struck at the "Didcot Dance" on Saturday when I returned on the earlier train to watch the 30 people transferring off the local from Oxford onto the Didcot to Bristol express to see them struggling up the stairs - heavy cases, pushchairs and young children, and in once case what I can only guess was a cello. And some not-so-mobile themselves struggling with the stairs.
I don't think there's a lift to that platform? But it is possible to do it on the level (or rather slopes not steps) by going out of the barbered area, around the outside of the station, and entering again at the barrier set which faces towards the western car parks. I did not take a look at the signage to see how well signposted that option is, nor follow it round to see for myself - so an update from knowledgable members (correcting me as appropriate) would be appreciated.
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by grahame at 09:57, 17th September 2024 | ![]() ![]() ![]() |
For those who used the service on Saturday just gone, what was the day return fare Oxford to Bristol.
Asking the question again,
A foot note IF its the same set bringing Oxford fans to Ashton Gate is the same set, could it take the football followers to Parson Street. So therefore would be cheaper to shunt towards Ashton Halt or go all the way to Weston and then return?
Thought I answered that - normally same set, I think - though it does shunt to Stoke Gifford for the two hours it's back in the Bristol area.
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by grahame at 09:43, 17th September 2024 | ![]() ![]() ![]() |
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by infoman at 01:40, 17th September 2024 | ![]() ![]() ![]() |
For those who used the service on Saturday just gone,what was the day return fare Oxford to Bristol.
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by ChrisB at 21:36, 16th September 2024 | ![]() ![]() ![]() |
Yes there was catering.
Footie fans like to be in a local pub for lunch before a game & the 1203 off Oxford is far too late & the 1528 return far too early too.
The return fixture at Oxford United would quite possibly see the fans using that first service eastbound though
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by infoman at 17:30, 16th September 2024 | ![]() ![]() ![]() |
Thanks for your thoughts on the new service.
Not sure if it will be Oxford moving down or Bristol City moving up.
If loads of Oxford followers reserve tickets on the 12:03
would this "tumble" this computer to say I think a nine car set is required,or two fives?
A question will the service have catering?
regarding not being able to take the Oxford service back home.
It reminds of when air south west airlines had a service recently, Plymouth-Bristol Manchester on a Saturday morning!
Air south West promoted the service "Argyle fans you can fly to Northern football match's"
But there was no return service?
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by grahame at 16:17, 16th September 2024 | ![]() ![]() ![]() |
Will not be able to advantage of the Saturday service/s,
not sure if any one would be willing to make the four trips and see if maybe they will use the same set for all four trips.
Not sure of the prices for the round trips,quite willing to contribute to the fare/s if any one is willing to undertake the four trips.
Thank you, but no need - the diagram has been published and it follows the marketing information in conforming it's a single 5 car IET making both return trips.
A footnote that Oxford United will be playing at Bristol City.
So numbers MIGHT be higher than what would be expected on a first (Satur)day
Is that next Saturday? Certainly a direct Oxford to Bristol train is one to promote if it ties in with match times, but at the moment it's an expermental service and I suspect will get fans to Bristol, but not home again.
Come next season (ah, but won't Bristol City be in a division higher that Oxford by then?) it'll all be GBR and the network will be manageable as a whole, so the Marylebone to Oxford service will be extendable to Swindon, with alternate trains onward to Weston-super-mare and Weymouth.
Numerous benefits such as bringing Swindon a train service within England's Heartland STB, bringing Trowbridge through trains to London (do you realise it's the closest county town to London without any through trains from thetre?), and doing away with the "Didcot Dance". With some trains calling a the three stations between Oxford and Didcot and some trains reversing there, it saves the shuttle train and gives Radley, Culham and Appleford regular through trains to London once again.
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by infoman at 15:46, 16th September 2024 | ![]() ![]() ![]() |
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by grahame at 06:41, 16th September 2024 | ![]() ![]() ![]() |
Finding the railway swingbridge over the Sheepwash channel on the way to the canal to be staffed by volunteers was a surprise,
You were in luck - Oxford Open House weekend....the same reason Culham station was open
Indeed - the Culham visit was planned after learning about the weekend about it - ADVERT - here on the "Great Western Coffee Shop Passenger Forum"
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by ChrisB at 17:40, 15th September 2024 | ![]() ![]() ![]() |
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by Mark A at 12:01, 15th September 2024 | ![]() ![]() ![]() |
A good day out (and a good record in one of the photos of my pernicious trolley fruit cake habit).
The Bristol to Oxford train busy, and merited its own announcement from the platform staff at Bath. Graham, joining the train at Chippenham, was very forebearing when I went into anecdote mode - it was very difficult not to mention the one-time refrigerator in the shop on the opposite corner from the Westgate Hotel on the Botley Road as it really was of a particular age - and then there's the eternal question of whether the railway has ever quashed the requirement to open the Botley Road level crossing on request from members of the public wishing to cross with vehicles too high to pass beneath the bridge (and if they did, the date at which that happened...)
Learnt a lot, saw places old and new, gazed with alarm at the seeming canal beneath the road bridge at Botley Road, and the slightly distressed arch for the footpath beneath the line there - somewhat bristling with telltales bridging various cracks. Oxford station is seeing so much flux that even its Wikipedia page has given up, if anyone is keen on editing Wikipedia and knows, that page would be a good one to which to give some love.
Finding the railway swingbridge over the Sheepwash channel on the way to the canal to be staffed by volunteers was a surprise, but unfortunately they cannot swing it without further work being done for fear that it might not open again. But they seem to have enough railway line stored in the undergrowth to take the track through the block of flats built over the trackbed, which raises questions. Also, on display there was the first photo on the following web page, a record of the decade or three when terrible liquids were carried in wooden hulled narrowboats, before both pipelines and changed industrial practices extinguished the trade - the photo shows what appears to be a boat from Thomas Clayton of Oldbury, they ran to and from Oxford's gas works for a time so it may have been heading there.
https://www.oxfordpreservation.org.uk/rewley-road-swing-bridge
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by grahame at 06:50, 15th September 2024 | ![]() ![]() ![]() |
Pictures to follow - just a few minutes to Melksham ...
Straight back into the Last Night of the Proms, broadcast live on a screen in the KGV Park here in Melksham to an audience of perhaps 400 to 500 who were picknicing there. Not a Coffee Shop topic, but a delay in following up. Here you go:
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by ChrisB at 21:15, 14th September 2024 | ![]() ![]() ![]() |
Sorry I missed you - XC was late down from Banbury & you'd cleared the station before I arrived.
Not so busy in the reverse direction back to BRI - although a balls-up on accessibility, which I'll say more on tomorrow. Hence enough to say that a 5 car IET only has two wheelchair spaces, where a 9car has three.
| Re: New Oxford - Bristol direct service, ongoing developments and discussion Posted by grahame at 17:51, 14th September 2024 | ![]() ![]() ![]() |
181 passengers in standard class on departure from Swindon. Add just under 20 who got out of first clasa at Oxford and give or take a handful, that was 200 passengers. Nice sunny autumn day for people to be out, but I did not see more than 1 or 2 more than Mark and I who were there to celebrate the return of the through service.
Headed back just before the direct Oxford to Chippeham direct service returns (as it misses the Melksham connection by 10 minutes). Coming off there local from Oxford to Didcot, I counted just under 30 people coming back under the subway at Didcot and going up the steps to the westbound main line platform.
