| Re: Search facility, document and post archives on the Coffee Shop forum Posted by grahame at 07:27, 17th July 2025  |   ![]() ![]() ![]()  |
Just hit a couple of milestones - the 1300th archived and indexed document, and the 200th "whitelisted" so that it's public accessible as well. A co-incidence that the two milestones were hit with the same document MTUG an MTUG / Melksham Transport update for Melksham Town Council reps to MTUG
The "Deep Search" box and hourglass on our front pages help you find what you want in this resource, and include many documents which are no longer otherwise online
| Re: Search facility, document and post archives on the Coffee Shop forum Posted by grahame at 07:55, 14th February 2025  |   ![]() ![]() ![]()  |
Deep Search didn't find 'Devon delays 2024' so again had to revert to scrolling through My Posts
Odd. It came up with 56 hits in 2 threads for me, and I was scratching my head. Until I replaced the 1 space between "delays" and "2024" with 2 spaces and it failed. Silly thought - I wonder if that could be it? So easy to pick up multiple spaces in a cut and paste ... or type them (I still do) at the end of a sentence. I also need to take a look at whether admin rights give me something different; I really doubt ...
Today will be a bit of a "down" day for me ... just have fair warning ... things going wrong all over the place ... nothing that's vital and can't be fixed given 24 hours ...
If you use QR codes, this should repeat the search in a working way:
P.S. - Leading and trailing space don't help either. I know why I allowed them - for complete word matching - but perhaps too clever
| Re: Search facility, document and post archives on the Coffee Shop forum Posted by GBM at 06:19, 14th February 2025  |   ![]() ![]() ![]()  |
| Re: Document and post archives and searching Posted by grahame at 08:01, 11th February 2025  |   ![]() ![]() ![]()  |
Personally, I hate our forum 'search' facility with a passion: that's why I spend time moving and merging existing topics wherever possible - to avoid the need to 'search'.
That is in no way any criticism of grahame: he has done a brilliant job, working to improve upon the software restrictions this forum uses.
It's a bit like the Melksham Train Service. 15 years ago, the facility supplied by default was broken, and we were left without any useable search. I have worked to provide something and make it extendable useable, but there is a lot more to be done and users need to be aware and work with the limitations at present. There is a lot more that could be done .. recall 3000 journeys a year past ... 75,000 journeys a year pre-covid peak, 400,000 journeys a year that is should be for the size and shape of the town. And a huge "thank you" and no criticism for the people who have helped the rise from 3k to 75k, whilst being reminded there is still work to be done.
| Re: Document and post archives and searching Posted by Chris from Nailsea at 15:33, 10th February 2025  |   ![]() ![]() ![]()  |
No results found!
No results found!
1. In the case of "Cornish delays" the words aren't mentioned as a pair anywhere in the thread - just in the subject line - so you drew a blank. The fact that I have now mentioned them means that this tread and post will be found in the future. clearly a design shortcoming - because at times some of our member don't repeat the words of the subject in their threads - something I have been aware of for a time and I have just applied a patch so it searches both. I hope I have not caused a problem applying the law of unintended consequences.
2. Where a search uses a pseudonym the search is only on the word you put in - so look for "Cornish delays" and our system is not bright enough to look for "Cornwall delays' and will certainly not offer you "Western Peninsular delays". If you put in a single word which does not match, it WILL offer you close spellings - "did you mean". Put in "Sinday" and it will suggest Sunday, even if you were searching for a naughty overnight destination with the girlfriend.
3. If you put a space between word in the search we look for the words consequetively. If you put an "*" between two words it will look for both words in the post / document and in that order, but not necessarily together
Our receptionist server is more powerful than our worker that does all the searching at present, and there is scope for enhancement - the sort of code I enjoy writing. All sorts of consideration for - well - some point in the future
I have added a copy of the above post here, in this general guidance for the use of the Coffee Shop forum's search facility.
| Re: Document and post archives and searching Posted by grahame at 17:14, 11th December 2023  |   ![]() ![]() ![]()  |
We have some
May 2019 - http://www.firstgreatwestern.info/nr_timetables
December 2019 - http://www.firstgreatwestern.info/nrtt20
May 2020 - http://www.firstgreatwestern.info/nrtt20summer
May 2021 - http://www.firstgreatwestern.info/nrtt21summer
December 2021 - http://www.firstgreatwestern.info/nrt_dec21
December 2022 - http://www.firstgreatwestern.info/nrtt1222
May 2023 - http://www.firstgreatwestern.info/nrtt_may23
Added
December 2023 - http://www.firstgreatwestern.info/nrtt_202312/
| Re: Document and post archives and searching Posted by grahame at 11:13, 19th November 2023  |   ![]() ![]() ![]()  |
An update from my blog - http://grahamellis.uk/blog1052.html - "Melksham needs appropiate "Siftware"" ... looking at the issues managing and finding data in the town. I have include Coffee Shop stats ...
The Great Western Coffee Shop forum - founded in 2007 - has an incredible amount of data on it, and over the years our team of moderators (data managers) and contributors have helped us build a searchable archive. I'm rather proud of this - open source software with code I have added and the search will help you navigate though:
* 1933 Mirrored documents
* 2535 Stations
* 25340 Forum topics
* 137143 "Did you mean?" words
* 337789 Individual posts
It's not just searching - these resources are indexed by category, date, security level, and geographic area too ... and there are 1562 timetables and 28819 images which come up within other documents or just by geographic and date index. Here is an example ... searching for "Rail Link Bus" if you wanted the history of the shortlived bus service to Melksham Station
* 2535 Stations
| Re: Document and post archives and searching Posted by grahame at 19:45, 8th October 2023  |   ![]() ![]() ![]()  |
can previous copies of the Nathional rail timetable be published/shown/downloaded?
We have some
Edited to add these other places you could try:
https://timetableworld.com
https://www.railtables.co.uk/all-services/
https://britishrailwaybooks.co.uk/wtt/wtt.php
https://discovery.nationalarchives.gov.uk/details/r/C13103
https://www.dpsimulation.org.uk/timetables.html
| Re: Document and post archives and searching Posted by infoman at 17:54, 8th October 2023  |   ![]() ![]() ![]()  |
| Document and post archives and searching Posted by grahame at 10:28, 8th October 2023  |   ![]() ![]() ![]()  |
We now have over 1,900 documents in our archive of which 1,075 searchable indexed documents. Most of these are available to members only, but just under 150 are available in public where we are clear there's public interest and no copyright concerns. We also have 25,000 threads with over 335,000 individual posted contributions - and the vast majority of those ARE public.
Just this morning I have added three documents:
http://www.passenger.chat/NN_at_announcement.pdf - "Network North" as it was announced by the Prime Minister on 3rd October
http://www.passenger.chat/NN_20231008.pdf - "Network North" as it was updated on 4th October
http://www.passenger.chat/hs2program_20231001.pdf - A recent (but pre-changes) description of HS2 and the various phases from "HS2" themselves.
Anyone can access the public (white list) documents via http://www.passenger.chat/whitelist.html ; they are categorised by importance though and it's not always easy to find what you want. Indeed a great deal of work could usefully be done to make the entire archive easier to use.
If you want to search for something, the "deep search" box and button at the top of forum pages is a good place to start, as is http://www.passenger.chat/research.html - if you are a member, log in first and you'll then be able to view the documents you find.
Note that some resources are left out of default searches. If you want to go back to forum threads prior to 2019, the "Dated" option lets you add in a seach right back to our foundation in 2007, and if you want to look in the documents in our archives but not yet indexed, use the "Report on" option and select "All Resources".
Coverage in our archive is patchy as documents need to be added when they crop up, and it's something of a personal project. However, I try to make it useful by adding things as I see them crop up. Many are never accessed at all - but at least we have backup copies should the original resource get lost or changed.
* Please let me know / send me a copy or link of documents you feel are missing - even if I have them, you might be helping me with poor indexing
* Some documents we have are locked .pdf files and that has made it impractical for us to extract the textual content to search
| Re: Research corner - finding archived documents and historic forum content Posted by grahame at 19:13, 10th July 2022  |   ![]() ![]() ![]()  |
We have now reach 1000 indexed documents in our .pdf library, with another 1000 or do still to be indexed.
1 document dated 1845
1 dated 1855
1 1874
1 1907
1 1928
1 1931
1 1941
1 1953
1 1955
2 1957
2 1960
4 1963
2 1964
3 1965
1 1979
2 1981
1 1982
1 1983
2 1984
2 1987
1 1988
1 1989
1 1990
1 1991
3 1992
1 1993
2 1996
3 2002
1 2003
4 2004
4 2005
11 2006
4 2007
61 2008
21 2009
19 2010
26 2011
21 2012
57 2013
61 2014
72 2015
91 2016
77 2017
107 2018
81 2019
104 2020
107 2021
27 2022
Indexed documents accesible to members are categoried as follows
324 3 - of local interest
355 5 - General documents
214 7 - Important documents
48 9 - Key documents
with the remaining documents being only accessible to admins, largely for copyright reasons. 110 of the documents included in the counts above are "whitelisted" so that they are available to the public even without an account.
| Re: Research corner - finding archived documents and historic forum content Posted by grahame at 11:54, 31st January 2022  |   ![]() ![]() ![]()  |
An update - Deep Search now defaults to reporting the resource with the most hits first rather than sorting by date. This is what the small print has always told you the default is, but it hasn't actually done that. The issue came to light when I was adding the Bristol to Birmingham report in this morning.
Try entering Bristol*Birmingham into the Deep Search box - you should find the resource that I added this morning high up the list now, with 85 mentions!
| Research corner - finding archived documents and historic forum content Posted by grahame at 10:19, 13th January 2022  |   ![]() ![]() ![]()  |
( Earlier discussions at http://www.passenger.chat/24635 )
There are now 2,000 documents in the Coffee Shop's archive collection, of which 900 can be found through a default search using the forum's deep search facility at http://www.passenger.chat/research.html and also accessible from the box near the top of forum pages. Location shown in greeh here:
Default searches will also find matches within public forum posts which are less that three years old (there are some 50,000 posts that are searched) and stations who's names match (from 2,500 National Rail stations)
* A further 900 of the archived documents can be found if you select to report on "All resources (including archive)"; the final 200 documents are stored in various conditions awaiting attention.
* If you wish to look back to earlier forum threads, there's a option on the search page ( http://www.passenger.chat/research.html ) that lets you look into all public posts since the forum started in 2007
There are copyright issues with archived documents, and rather than make the content of them public ("publish them") ourselves, most of them are accessible to members only . If you are a guest, please remember that registration doesn't cost anything and if you have a public / sustainable transport interest with a significant UK element, you'll be welcome.
Around 100 documents in our archive are "whitelist"ed, and those are available to guests without registration as well as to members. These documents are listed at http://www.passenger.chat/whitelist.html
If you feel that our archive is missing a key document, please let me know - chosing what's in there is somewhat subjective and there will be things I have missed (and probably things included that you will wonder "why?"). All documents are stored as .pdfs - if necessary, other formats such as .doc and .html can be "printed" to .pdf and archived in that way, but with some formats and security features that might not be practical. Spread sheets in particular can be awkward to 'reduce' to printable documents.
| Re: Search Function Posted by ellendune at 22:05, 7th October 2021  |   ![]() ![]() ![]()  |
Thank you
| Re: Search Function Posted by grahame at 08:11, 7th October 2021  |   ![]() ![]() ![]()  |
I have used this to find the Lorry Driver Shortage Thread.  I found the name of the thread.  It tells me this.
Unfortunately I still have no idea which board it is on. How can I find out?
+   30 Sep 2021   Thread - Lorry driver crisis made worse by Covid - Shapps   9
e StokeonTrentLive:. Tesco beats HGV driver shortage by importing fresh produce from Spain b
Click on the "+" to the left of the result you have quoted above and it will take you to the thread. If you look in the top bar above the thread when you're there, you'll see which board it is on.
| Search facility, document and post archives on the Coffee Shop forum Posted by ellendune at 08:04, 7th October 2021  |   ![]() ![]() ![]()  |
