The Consultation is On!
26.6.2025 (Thursday) 04:42 - All running AOK
Re: The Consultation is On!
Posted by grahame at 06:50, 10th September 2024
Six YEARS today since the consultation closed.
Fares system still "a bit" confused!
Posted by grahame at 04:48, 18th February 2019
Results published - 18.2.19 - discussion started at
http://www.firstgreatwestern.info/coffeeshop/index.php?topic=21076.0
Posted by grahame at 16:37, 15th February 2019
Results Monday?
ITN are doing a feature on railway ticketing on the News At Ten on Monday, and they want to talk to a frustrated passenger. Reporter Cxxxx Cxxx writes:
"The Rail Delivery Group is issuing the findings from its consultation on ticketing reforms on Monday. We just want a quick chat with a passenger who feels they have been disadvantaged by ticketing rules ..."
Good Ole press reporter ... hunting around for the exceptionally negative examples ...
Posted by grahame at 12:02, 9th September 2018
Having expressed my concerns, I will be going ahead and submitting a response.    Stating my personal background of learning and - I hope - adding a flag that they are thought through rather more deeply than most. But not claiming to be representing the full view of any organisation.   And it is worth submitting to at least indicate an appreciation that at least some views have been sought, and that I want to contribute.   It has also been very helpful to me personally to be thinking about these things as the wider picture moves forward.
Well - I have responded.
Cheekily added a "please ask me if you want further expansion of this idea" and included my contact details should they wish to do so.  I doubt they will ...
Your name and email address are important to help ensure that all responses to the consultation are unique. They will not be used for any other purpose.
which perhaps reads as "thank you for you inputs.  We have consulted you and are not further interested in anything you may have suggested".  Why no "may we contact you to follow up on your comments if we would like clarification or to take them further"?
Posted by ellendune at 17:57, 8th September 2018
Sorry missed that.
Posted by grahame at 16:37, 8th September 2018
Another thought:
5. There is a desire for long distance and return journeys which are only in the peak for a small proportion of the journey to only be charged at peak rates for that portion of the journey.
This is going further than I had thought and I support it. However it fails to point out the need for a lesser step.  FGW (as it was then) changed their fare structure so that Single Tickets were about half the return fare.  In doing so they proved it could be done while remaining revenue neutral (I assume or they would not have done it). This should be rolled out across the network so that we do not have the ridiculous situation of a return being only just more than a single.
As in
3. 24 hour return fares at 65% of two singles. Monthly returns at 80% of two singles.
Posted by ellendune at 15:12, 8th September 2018
Another thought:
Posted by ellendune at 15:05, 8th September 2018
The way the suggestions I make further down would work would remove these anomalies - period.
Agreed
Major waves in the system and perhaps the economic situation of commuters, with a lot depending on the pricing of each mileage leg.
Accepted that is why I was suggesting at least not making things worse.
There is a case for pointing out those current issues by example - whether in point 8, or by adding a point 11.
I did in my response.
Posted by grahame at 06:15, 8th September 2018
8. It is understood that a straight "pence per mile" fare across the network would cause serious socio-economic changes, and that changing other metrics would also have significant impacts
Could this be qualified to highlight that the present system has created some major discrepancies in the pence per mile fares particularly between 'commuter' and 'long distance' stations and that at the very least a new system should not allow such discrepancies to worsen, but have a log term objective to reduce them.
I refer to the very high pence per mile rates for long distance anytime fares such as Paddington to Swindon or Bristol (which have not been regulated) compared to say Paddington to Reading or Oxford (which have been regulated).  These become very apparent when you look at the difference between the anytime fare and the season ticket as the season tickets have been regulated.
The way the suggestions I make further down would work would remove these anomalies - period. Major waves in the system and perhaps the economic situation of commuters, with a lot depending on the pricing of each mileage leg.   There is a case for pointing out those current issues by example - whether in point 8, or by adding a point 11.
I, sadly, am far from convinced that thoughtful inputs to this consultation will have any noticeable effect; that's not an unusual view for many to have of most consultations, but in this case my cynicism is right up at the top of the scale if asked "is my text input going to be of any use".
1. RDG have told us they are looking for massive response and they are quoting numbers. They have lots of tick boxes that can be counted then only a few write-ins which will make it very hard for them to meaningfully analyse the write-ins.   They will be open to cherry pick from them, however
2. The consultation defines a narrow bottom line outcome of what's required and does that simplistically to the extent of it being inconsistent within itself - point 3.
3. The RDG is not an uninterested party conducting a consultation. They are the ones with members who's company members / shareholders will loose or gain from any results that are implemented, and must be seen not to be tempted to recommend solutions which allow the maximisation of income / profit within optional ticket products outside or in addition to any new system
4. It is a nationwide consultation - so inputs from the South West / GWR area will be but a small proportion of inputs so will be diluted within the whole response.
5. The tick box questions which require a yes/no answer are really not that simple and are woolly.  Yes, a wide range of things should be considered, but that is very different to a scheme being implemented which uses elements of that measure.
6. The respondent profile is going to be self-selecting interested people; I wonder what measure there is to normalise the result to an average profile.
I would encourage members to submit their own responses ... and members (and guests) are very welcome to use / repeat any (or even all) of my thoughts in their inputs.   I am flattered by the suggestion made to change and I will think on that carefully - but this one is about numbers and I am just one and hold no authority - I'm just a passenger who sees some issues in the current system and asks "why", "could it be better", "could it be fairer".  I suspect many respondents will be coming from "will that make it cost more or less for my travel" ... and RDG are looking to say "how can we increase profit" and we have, sadly, an unholy mix ...
Posted by ellendune at 19:37, 7th September 2018
Posted by grahame at 18:36, 7th September 2018
I am going to put in a reply on Sunday night.  Some of it intentionally provocative.   Thoughts?
... I also attended your round table discussion in Bristol, and have worked with fare experts at GWR looking at issus around local anolomolies and opportunities. My does not represent a unified view from any of those groups / organisations as there is a no general concensus - however, there are some common thoughts.
------ Common(ish) thoughts -----
1. To come up with a simpler fare system, it's very hard starting from here.
2. The current system is held in some disrepute for its complexity and for the difficult people have in getting the correct and lowest cost fares for their journy. A very big hurdle the rail industry will have with a new fare structure is to gain the trust of the travellig public that they are being offered / sold / chrged the correct amount.  Trust is going to be key
3. It is noted that a requirement of the proposed outcome is that it maintains farebox income at current levels. It is also noted that the RDG's committment is to continue to grow passenger numbers.  The implication of those two criteria together is that fares per journey can decrease in propostion to journey number incrases.  However, there is unlikly to be extra capacity available everywhere it's needed without additional (revenue) expenditure, suggesting that the proportion of each journey cost paid from the farbox will decrease; where the shortfall is made up is not clear
4. Split ticket saving are largely the result of the perversities of the current fare system, and any new and logical system should reduce their utility as a putre money saving gambit. It would be undesirable to remove the facility or change it such as it caused a safety issue (e.g. by requiring people to get off and on the train, or to exit and re-enter the station at the point they change from one ticket to another.  There is no appetite for the removal of split ticketing as a specific objective - that would simply make the train operators look greedy.
6. There is a lack of accurate, complete and understandable information about tickets and fares for the travelling public - for example on ticket machines which offer peak and superoffpeak, you'll often find identical descriptions "cannot be used on peak trains on Mondays to Fridays" with a caveat to ask for details which is not always possible.
7. Far too many customers are overcharged in the current system because they buy a less restrictive ticket than they need (e.g. anytime when they could buy off peak) or when they are sold a ticket for their entire journey - even when they ask for the cheapest possible way to travel and that cheapest way is a split ticket.
9. Routing perversities need to be eliminated, with "any reasoanable route" being the default. "Any Reasonable Route" needs to include the fastest available journey available when you arrive at the station. For example, Melksham to Bristol Parkway is only available via Bath Spa, even though the quickest route for the journey is via Swindon. If you travel from Melksham to Swansea - through Bristol Parkway - that IS a valid route!!
10. Removal of bulk purchase systems such as season tickets (or return tickets) would require significnatly more bandwith in ticket issuing; technology might help, but current technology could not cope.  However, bulk purchase such as season tickets leave a step in the market for those for whom they just fail to do the job.
---------  Suggestions -----------
1. Base fares on a pence price between each station, adding up those fares to make a total journey fare. There is also a case for "quantity discount" on longer journeys.  Add in a fixed fee for station use at the start and end of the journey; that may be based on station facilities including the availability of buses which would be included in the price within the station's catchment.
2. Retain 3 time zones - any time, off peak and super off peak.   Close to uniformly peak for trains leaving stations beween 07:00 and 08:45, and 16:45 to 18:15. Super off peak from 10:15 to 15:15 and from 20:00 to 22:00. Which leave off peak from 22:01 to 06:59, 08:46 to 10:14, 15:16 to 16:44 and 18:16 to 19:59. Note that late night and early morning trains are off peak and not super off peak.  Where a train calls at an intermediate station, the ongoing fare is based on that schedued time of departure.
4. Replace current railcards and children's fares with
   Bronze      25%   off off-peak and super-off-peak fares
   Silver      35%   off off-peak and super-off-peak fares
   Gold      35%   off all fares
   Platignum   40%   off all fares
Progrssivley more expensive to buy - but maybe special deals on railcards for specific groups
5. Retain / make universal Groupsave. Ranger, rover, advance tickets options
6. Rail tickets routinely valid for travel by parallel bus.
Edit to correct typos
Posted by JayMac at 21:13, 6th September 2018
I've stopped paying tax for the time being.
How are you managing to do that? Have you become entirely self sufficient? No mains utilities? Fuel? Clothes? No non zero rated foodstuffs? No booze? No leisure activities? Holidays/Flights? No Council Tax?
Impressive if you've cut out all that. How did you access the Internet to tell us? And what's the secret?
Posted by TonyK at 20:54, 6th September 2018
Can't agree with that, seems a bit "I'm all right Jack" - the railways are massively subsidised by the taxpayer and as we all (mostly) pay tax, it should be a level playing field, it shouldn't favour those "in the know", fares should be transparent and easy for all to understand, be they enthusiasts or occasional travellers.
Posted by Bmblbzzz at 18:06, 26th August 2018
Just spotted this and have completed the RDG survey, including some suggestions in the relevant boxes, though I doubt they were ones they haven't heard before.
Posted by grahame at 15:54, 26th August 2018
From "The Wider Picture" ... a reminder that you nay have a couple of weeks left
Not sure if it's been brought up, but Britain Runs on Rail are looking at changing the UK rail fare structure.
Some interesting ideas, including rail fare caps for season ticket passengers, and bringing it even higher prices for peak services and lowering further off peak services   I found it on the LNER website, Not many TOC's seem to making the public aware of it.
Here's the link for those who want to have a say.
https://www.britainrunsonrail.co.uk/fares.html
Posted by grahame at 13:02, 13th August 2018
Last Wednesday ... RDG meeting / briefing in Bristol - for which the polls here had been very useful informing me.  Sorry about their being a few days delay in the writeup - been manic with one thing and another!
Easier Fares!
Really don't know what to say about the meeting.  Perhaps 15 to 20 of us (3 from RDG) starting off with an introduction telling us that the system dates back to 1995 and that changes since then to regulation and rule have left it even tighter than it was, and even more restricted in what can be done under current government rules that was the case in British Rail days.  Problem highlighted of looking for a system which allows for local requirements of a fare system to be met, and yet requires national (long distance) fares. Also problems of bringing a system that was designed for ticket clerks into the electronic age.
The objective of the consultation is to find a widely supported route forward that reflects future needs. Not necessarily looking for a "one size fits all" solution. And indeed a problem identified in defining what "success" might mean as as outcome.  A recognition that there is unlikely to be a "big bang" type change - rather looking for the start of a process / a long term strategy.
Some 8,000 responses have been received to far to the consultation (at Weymouth yesterday I picked up a flyer from the literature rack, so there is a lot of encouragement out there) ... wanting to encourage over 10k.  Especially "if you have ideas, write them in".   RDG's comments are that this is a "genuine consultation looking for ideas and not just window dressing".
I noted that the consultation asks for ideas which maintain the fare basket income, but the RDG's publicity talks of Cheaper Journeys.   Logical conclusion is that changes should be designed to increase passenger numbers, but no real answer when I asked RDG if that was the intent - more a sheepishness that suggests to me two goals that aren't fully mutually compatible.
Outcomes ... a one off meeting, so no direct follow up.   RDG logged / took away meeting's views to feed into their system / unsure of any level of influence therein.
A common factor is the use of technology to calculate the fares dynamically - in London, all you get is a brief flash of your fare.  While you have a simple(r) system, all stations gated or with readers, a customer base that's familiar with the system for the most part, and maximum fares of an hour or two's pay, people will be and large accept it. Move to a network where a fare can be over £100, with some stations are so small as to make smart readers not cost effective (yes, I am aware of the reader at Breich), and where the current system is so complex that no-one understands it, and it fails to offer the cheapest available journey, and you have a trust problem.  Further, errors even if that are small in percent terms might be big in pound terms.
Discussions on Railcards ...
Interesting discussion on removal of Severn Bridge tolls, and on what that will do to road and rail traffic across the Severn, to road congestion in the Bristol area, and to house prices in the Chepstow area.
Posted by bobm at 07:10, 9th August 2018
If my sister wants me to visit - she pays.   Simple.   (or she pays for the DIY jobs I do when I am there)
Posted by TonyK at 00:07, 9th August 2018
Condemn me if you wish but I did not take part in the consultation because my days of long distance rail travel looks to be a relic of the past, Glasgow is where I fledge my wings to and when I can get one way fares on Easyjet from / to Bristol for as little as £22.66 to and £24.68 from Scotlands second city then regards competing modes of transport there is "no contest".
I have now moved to within 3 miles of Tiverton Parkway. I thought I would visit my sister in Norwich, and on looking up rail fares thought of a crowd funding approach to pay for the rental of the trains, or maybe purchase. Then I found that Flybe will take me there from Exeter for twenty quid each way.
What should I do?
Posted by stuving at 09:27, 8th August 2018
The average train journey (a few years back) was 20 miles [[not sure how that was calculated]], compared to 6 miles by bus.
Where did this data come from, I live in an area which is widely regarded as a dormitory town for Bristol and in the morning and evening peaks we have had "express" bus services to Bristol and from 03 September these are being extended to run all day until early evening with longer duration journeys running until a last bus from Bristol at 23.35 daily. Distance about 12 miles. I could also make a similar repeat statement regarding the town of Thornbury. We also have a, reopened in 1989, rail station from which we have been promised a half hourly rail service in the future, hourly now, how far in the future is in the "lap of the gods" knowing how long it takes the rail organisations to do what is normally viewed as a simple task.
First answer: the rail figures come from ORR, the bus ones from DfT. There's obviously a second answer about how they get them, which for the rail figures is: they divide a year's total national passenger-km by the total national passenger journey count.
The one year I happen to have the ORR stats to hand for is 2014-15, and the average journey length works out to 38 km - at 24 miles that's probably what Graham was remembering (or perhaps for another year). ORR give a breakdown by franchise, which makes it obvious why the figure is what it is - most journeys are commuter ones, or daytime ones over the same routes. Thus the three SR franchises, plus Thameslink, c2c, and LO add up to well over half the journeys, and an average length of 24 km. And that's before adding in the cities outside London, which are part of most franchises: note that Scotrail's average is only 33 km. Of course the two long-distance franchises have much larger average lengths (256 and 199 km) though XC serves so many cities its is only 96 km. GW is mixed, and gives 57 km, while its "twin" GA then had so many commuters (now lost to TfL/XR) its was below the average at 32 km.
As to where those ridership figures come from, I don't have ORR's footnotes (but no doubt they suffer from them) but I'm pretty sure it's ticket sales. Train passenger counts are much less complete and reliable, and even when most trains can count their own passenger load it will take a while to woke out what the numbers really mean. I suspect buses are in theory based on ticket sales, though with most tickets not having a specific journey and some passes not registered electronically it won't be so simple. Operators will have ways of filling in the gaps and the national figures probably just represent the best estimates they have flowed up to DfT statisticians.
Of course average fares and cost per mile will also show the same bias (in a value-neutral sense) towards the biggest concentration of users (or whatever is the divisor). It's not "biased" in the sense of dishonest: if that's what you want to know it's the right answer. But it's not the only answer; there are other averages and you may not want one anyway. And for this consultation, one point to consider is that "revenue neutral" only means what the TOCs want it to if the passenger numbers don't change as a result of any pricing changes. Since TOCs (or "the railways" more generally) use pricing to encourage new passengers or journeys and to time-shift existing ones it's not obvious that's going to be the case.
Posted by TaplowGreen at 08:14, 8th August 2018
Why change? What is wrong with the air of mystery and the fact that those of us "in the know" can play the system to our advantage? Almost the only fun in my monthly trips to Blackpool to visit my late mother in the nursing home was in seeing how cheaply I could manage the trip - usually under £25 each way. My cousin recently sent her 17-year-old son to stay with his uncle in the north of Scotland, buying a Cross Country ticket from Bicester the night before and wondering a) why it cost so much and b) why she couldn't reserve a seat for him. It wasn't a trip planned at the last minute, just badly planned in terms of transport. People like her effectively subsidise those of us who know the value of booking at least a few days in advance.
Posted by martyjon at 06:38, 8th August 2018
Posted by grahame at 06:13, 8th August 2018
Condemn me if you wish but I did not take part in the consultation because my days of long distance rail travel looks to be a relic of the past, Glasgow is where I fledge my wings to and when I can get one way fares from / to Bristol for as little as £22.66 to and £24.68 from Scotlands second city then regards competing modes of transport there is "no contest".
It is my understanding that the consultation refers to all rail fares - long and short distance.  Indeed, much of the "split ticket" business comes from local fares which are cheaper per mile than long distance fares.   The average train journey (a few years back) was 20 miles [[not sure how that was calculated]], compared to 6 miles by bus.
Railways have largely priced themselves out of the South West to Scotland market.  But then you look at the crowding on so many CrossCountry trains in and out of Birmingham, and you wonder if high prices for the long journeys are actually a sensible business decision.
Posted by martyjon at 05:45, 8th August 2018
Posted by TonyK at 22:45, 7th August 2018
Posted by JayMac at 21:54, 7th August 2018
Which is usually converted into beer tokens!
Posted by bobm at 21:52, 7th August 2018
He does get his 10% though.
Posted by JayMac at 21:48, 7th August 2018
I am occasionally bobm's unofficial travel consultant consultant.
Posted by bobm at 21:02, 7th August 2018
One thing a lot of the new technologies rely on is that the person buying the ticket is the person who travels.  There should still be a mechanism for those (like me) who are unofficial travel consultants for their family and friends and buy tickets on their behalf but don't travel with them.
Posted by grahame at 20:47, 7th August 2018
Many thanks for your inputs ... all three polls closed earlier today
As fallout from the timetabling look over work for May 2019 that I've been involve with, I have been invited to an "Easier Fares Consultation roundtable " ... and  thanks to the airing of views and voting on here, I feel better informed to understand what I hear said against the views of our typical untypical customer sample. I will us your inputs to guide, and feedback any gems I learn that might help with your answers.
Posted by grahame at 11:49, 4th August 2018
Grahame. You could just buy a Melksham to Oldfield Park Day Return, breaking your outward journey at Bath.
Agreed - if I knew in the first place that I was coming back from Oldfield Park.    You know what it's like - you go into Bath to buy a widget and find that Maplins has gone and Currys don't have it ... neither do Bath Electtical services. However, Currys have checked with their Weston Lock branch so you stroll out there and - yes - purchase what you need.  Oops - nearest Station Oldfield Park ... don't really fancy walking back in carryon a widget. Do you realise just how heavy and bulky they are.
Could I also excess the return half of my Bath Spa ticket into a return from Oldfield Park?
That's certainly cheaper than any combination of split tickets. Railway ticketing doesn't really cater for those whose plans change on the hoof. Nor should it without introducing more complexity.
Fair enough - and so a good example of a use of split tickets as the system intended in the first place!
None of the topics and polls started on this forum, nor the consultation (which I think offers nothing positive) have considered what I'd like to see. A reduction in fares across the board. Achieved through greater subsidy from central government. Oh, and by stripping out wasteful costs from a rail industry that is fractured and has too many layers. Yes. Nationalisation.
The consultation very specifically sets the bounds of retaining the same income, and I would agree that's not taking a wide look at all.    In theory, it does allow for lower fares though the generation of more journeys, but it would be a very brave person to make that case - more likely, if the system changed those who's fares rose significantly would quickly move away from the train, but the build up of new business on lowered price tickets would take longer, resulting at least in a temporary downturn in passenger numbers.
Posted by JayMac at 10:43, 4th August 2018
Posted by Clan Line at 10:40, 4th August 2018
Suggestions of solutions to "solve the split ticket problem" worry me.  It feels to me that we are treating the symptoms not the underlying disease, and that if we were to treat the disease we would mitigate or cure the symptoms.  And are the symptoms in themselves really a problem?   Do we really want to throw out the baby with the bathwater?
Totally agree with you there !  The main problem is that no one knows what the disease actually is. The usual assumed complaint is "fares-too-high-itis" followed by examples of how cheap the fares are in any other country on the planet apart from the UK. Any fares "rationalisation" would therefore require huge cuts in ticket prices across the board - just how likely is that that ??  2 or 3p on income tax would probably make every rail traveller happy  ....until they get next year's tax coding notice from HMRC.
"Solving the split ticket problem"...what problem ? If I get a day ret from WMN to SOU it costs 18.0p/mile. (on a railcard). If I split at SAL, it works out at 12p/mile. Would the fare to SOU come down to 12p/mile - or the split fares go up to 18p/mile ...........only one answer there, I fear - problem solved !
I would put Advance fares in the same bucket as splitting - they can be amazingly "cheap" (My best one: 8p/mile, 1st Class from Euston to Glasgow). Does the commuter on the 0730 from Swindon to Paddington really expect his ticket price to drop to that level ? or does he want the Advance ticket his granny (and me !) buys, to travel off peak, to double/triple in price ? A lot of empty daytime trains coming up.
I fear that all that is going to happen is that many of the bargains available on the railways - and there are plenty - will vanish. Leave well alone until the disease is actually identified - if it ever is !
Posted by grahame at 06:35, 4th August 2018
Maybe tapering mileage charge less the longer the journey. That would solve the split ticket problem/solution.
Passenger's journeys require the use of two stations with all of their facilities which brings a cost, as does the stopping a starting of the train at their begin and end point.  Running a train has fuel, wear and tear, staff costs etc based on distance and time taken - which increase directly (or roughly) in proportion to distance.   So there is an argument to suggest a station use charge plus a charge that's based on mileage or time taken as being closer to the cost of providing the service than most / many other approaches.
Being able to join multiple tickets is a really positive encouragement.   I can travel out from Melksham to Bath Spa, find myself doing various things in Bath and traveling back from Oldfield Park.  Under split ticket arrangements, I can top up my ticket with a single from Oldfield Park to Bath, remain on the train to Trowbridge, and change there for Melksham.  What would I do without the split?
* I could buy a single to Bath Spa, get off, go out through the barriers, around the station and back in; pretty sure my train would have left by then, and I wouldn't get back to Melksham until an hour or more later
* I could buy a new single ticket all the way from Oldfield Park to Melksham
* I could buy an Oldfield Park to Trowbridge ticket, where I would leave an re-enter the station rather than just swapping platforms, joining the Melksham train "short" on the return half of my Melksham to Bath ticket (if THAT were still allowed)
* I could make my way back (by bus or on foot) to Bath Spa to rejoin the railway there, even though a train going in the direction I wanted called at a station that I was right beside, and on which I had already paid for a ticket for 90% of the way.
* I could decide just to do the whole day's trip by some other means such as car.
Posted by eightf48544 at 17:37, 3rd August 2018
Onr of the difficulties with the fare structure however devised is tha are too many )pun) Many to Many  relationships to cope with even with a computer.
Consider just Many Stations, Many trains, Many routes. Add in peak, off peak, single return  and the number of possible fares  sky rockets.
Demand led pricing like the airlines, who mainly fly A to B  a couple of times a day,  falls down because a train may stop 10 times and the service be once an hour at each those 10 stations. too many combinations.
Posted by grahame at 06:46, 3rd August 2018
Many thanks to those who have voted in our polls already.  For those who have not yet, your opinions over the weekend would be appreciated - our polls close on 7th August.  This is a nationwide (RDG / TF) consultation, so our area inputs will be combined with many others, but still worth completing the main consultation.
Our polls:
What fare base options should be considered? - [here]
What basket / overall scheme philosophy would be your preference - [here]
Choices on how you buy tickets - [here]
Background - http://www.firstgreatwestern.info/coffeeshop/index.php?topic=20153.0
Remember - 10th September 2018 is the closing date of the real consultation.
Posted by grahame at 15:12, 31st July 2018
The "Fares Consultation" .... below is a summary of the questions being asked.  It would be very intersting to see member's opinions too so I will add a series of polls ...
What fare base options should be considered? - Poll [here]
What basket / overall scheme philosophy would be your preference? - Poll [here]
Choices on how you buy tickets- Poll [here]
At this stage, I am not proposing any input from the forum as a group / organisation to the consultation - however, should this thread and the polls reveal a significant interest and a view held by the vast majority of members, we could re-visit that.  I would certainly suggest individual members with strong views complete the consultation directly.
It has been suggested thar the current structure of fares on Britain's railways could be improved, should be improved, or is in desparate need of improvement, depending on your view.  The Rail Delivery Group (for the rail industry) and Transport Focus are currently undertaking a survey of views to find out about the type of systm and structure people want to see.  The home page of this consultation is at https://www.britainrunsonrail.co.uk/fares . You may take the survey online at https://www.smartsurvey.co.uk/s/EasierFaresConsultation/ . There is also a printable copy of the consultation at https://www.britainrunsonrail.co.uk/files/docs/English_Version_v2.pdf which I suggest you read before answering online so that you know all the questions and options ahead of filling anything in.
Part 1 is about Fare restructuring.  The introduction reads:
We know that rail fares can sometimes be confusing to customers and we are interested in your views about how rail fares should be structured in the future. To what extent do you think each of the following options should be considered in re-structuring rail fares?
In answering these questions please assume that:
• The overall average rail fare remains the same as now.
• Fares may be structured in a different way (so that some people pay more, some will pay less and others will pay the same as they do now).
• The consultation does not advocate any of the options you will be presented, but seeks your views on a range of scenarios. All the options presented are broad concepts which would require further consideration and refinement.
You are asked to say whether each of the following should be considered in restructuring rail fares - each comes with a piece of decsripting text, and a choice of "Definitely consider" / "Maybe consider" / "Do not consider" / "Don’t know/No opinion"
Fares based on distance travelled
Fares based on the level of service received
Fares where the cost is the same at all times of day and for all days of the week
Fares based on time of booking
Fares based on the amount of flexibility required
Fares designed so that it is unnecessary to buy a ‘split-ticket’ in order to get the cheapest deal.
Fares based on encouraging travel to fill up empty seats
Fares based on loyalty to regular travellers
Fares which provide savings for certain groups in society
Fares where both the outward and return journey fares are based on time of day travelled
There is then a further "basket" question  asking for a choice between three options ("Reforming rail fares will involve balancing the needs of different customers and it is unlikely that a single approach will suit everyone. Which of the three options described below best reflects your preference for the range of rail fares available?")
Option A: No discounted tickets, standard ticket price lower than now
Option B: Discounted fares same as now, standard ticket price same as now
Option C: Greater discounts than now, standard ticket price higher than now
And you may also select "Don't Know / no opinion".
Part 2 is about buying a ticket
We are interested in your views about how passengers should be able to look for, buy and receive rail tickets. To what extent do you think each of the following options should be considered?
• The range of rail fares is easier to use than it is at the moment and that the average rail fare remains the same.
• Some people pay more whilst some pay less.
• The options presented are broad concepts which would require further consideration and refinement.
Should a ticket cost the same however you buy it?
Should there be a smart card systems with a price cap?
Should online accounts be available which could be used for rail and other of types of public transport ?
Part 3 is for "Any other thoughts" - free format input boxes asking for
Comments on the factors which you think should influence rail fare structures e.g. peak/off-peak fares; advance fares, or anything else.
Comments on the factors which you think should influence how tickets are purchased e.g. online purchase, electronic ticketing, or anything else.
Any other comments.
The survey concludes with questions about your travel habits, your postcode area, email, age, ethnicity, gender, any disabilities.  A different set if you're answering for an oranisation.
Posted by WelshBluebird at 10:21, 13th June 2018
A post on the Southern Electric Group's Facebook page pointed to this blog which has some interesting observations on the consultation  https://diamondgeezer.blogspot.com/2018/06/easier-fares-consultation.html?m=1
His blog is usually pretty good in general!
Back onto topic, I specifically agree with his conclusion of "but in a consultation which can only keep average fares the same, what's the betting that the potential losers ultimately drown out the potential winners?"
Posted by RichardB at 08:29, 13th June 2018
Posted by grahame at 16:03, 12th June 2018
Media release: https://www.britainrunsonrail.co.uk/media-releases/134-rail-industry-seeks-root-and-branch-reform-of-rail-fares-regulation.html
Decades of well-intentioned but outdated regulation have led to a range of fare options that have not kept pace with technology or how people work and travel today.
Industry, with independent watchdog Transport Focus, will launch a public consultation spanning the country to establish a road-map for change to update fares regulation and make things easier for customers
Any proposals from the industry will be designed to be neutral in overall revenue terms and would require working with governments to implement
Alongside major upgrades to services, an easier-to-use range of fares is key to delivering the industry’s long-term plan for change and improvement
An easier to use range of fares will aim to maximise the benefits to customers, businesses and the economy of improvements in ticket-buying technology
Britain’s rail companies, a partnership between the public and private sectors, are launching a public consultation to seek ‘root and branch reform’ of fares and ticketing regulation.
The announcement follows new research by KPMG which shows that only one in three (34 per cent) rail customers is very confident that they bought the best value ticket for their last journey and fewer than one in three (29 per cent) were very satisfied with the experience of buying their ticket. Reform has the potential to transform the buying experience for customers, making it easier for people to be confident they are getting the right ticket.
Well-intentioned but ultimately counterproductive regulations underpinning rail fares have remained unchanged from the mid-1990s, when the 1995 Ticketing Settlement Agreement spelled out how fares should be set and sold. It assumes all customers will buy their ticket by visiting a ticket office and sets out in detail how customers must be able to buy a ticket from each of the 2,500 stations in Britain to every other station in the country.
Since then, further layers of requirements have been added through individual franchise agreements, with little or nothing taken away. This means that long-standing anomalies* are becoming locked in resulting in bigger problems for customers, and there are now around 55 million different fares. As a result it has become increasingly difficult for rail companies to guarantee the right fare. Regulations have failed to keep pace with the rise of smartphone technology or how people work and travel today, with part time working and self-employment having increased by over a third in 22 years.
Updated, fit-for-purpose fares regulation would enable the right changes for the long-term. That’s why the industry will be working with Transport Focus, the passenger watchdog, to launch a public consultation next month to hear the views of businesses, passenger groups, stakeholders, employees and the public on what a future range of fares should look like.
The consultation will help the industry to establish a road map which delivers against these principles. The industry wants to then work with governments to make fares simpler, easier and more trusted while continuing to enable investment in the railway.
To help frame the consultation, the Rail Delivery Group, which brings together all rail companies, has commissioned an independent report from KPMG to identify key principles which are driven by what customers and the country need from the railway. These principles should underpin a fares offering that is fit for the future and include:
Being transparent, predictable, fair, trusted, easier to use and value for money for customers;
Offering integration with other modes of transport;
Offering personalised, flexible fares which best serve customers in different markets;
Enabling growth, innovation, efficiency and choice; and,
Providing funding for investment and avoiding the need for additional taxpayer subsidy.
A final report will be informed by the consultation and will make proposals to governments with options for fares reform. The industry’s proposals will be designed to be neutral in overall revenue terms with no change in average fares, and therefore not requiring any extra taxpayer support for the railway. A fares offering which is trusted, though, has the potential to attract more people to travel by train which would support investment in rail or give governments the option to change the balance between taxpayers and farepayers for funding the railway.
The change the industry is calling for comes on top of improvements it is already making to fares where it can, and by working with governments. These include cutting jargon, clearer information about peak and off-peak times and better information about how people can use their ticket, part of a fares action plan agreed between industry, passenger groups and government. This is alongside the on-going roll-out of smart-ticketing, which will also help make it easier for people to buy the right ticket. But these changes alone will not go far enough in making things better for customers.
Commenting, Paul Plummer, Chief Executive of the Rail Delivery Group, said:
“As part of the industry’s plan for change, we want to work in partnership to drive root and branch reform of well-meaning but out-dated fares regulation. Working together, we want to develop proposals to reform fares and regulation to make it easier for our customers to get the right ticket, enhancing trust in the system and supporting continued investment to improve the service.
“Unpicking the regulation of a £10bn-a-year fares system that underpins such a vital public service means there are no quick-and-easy solutions. The change that’s needed won’t be easy and the industry doesn’t have all the answers, which is why we want to hear views from passengers, communities and businesses in all parts of the country.
“There have already been improvements and more are on the way but this consultation will enable us to create a clear roadmap with the country so that we can make the right changes for the long-term more quickly.”
Anthony Smith, Chief Executive of Transport Focus, said:
‘Rail passengers want a simpler, more understandable and modern fares system which matches the way we now travel. Opening up the debate and looking at the pros and cons of various reform options is welcome. Transport Focus will make sure the passenger voice is heard in these debates.’
Mike Cherry, National Chairman at the Federation of Small Businesses, said: “Small business owners, their staff and customers need to know they are getting the best deals when they travel by train.
“We look forward to working with the industry to help develop proposals for meaningful reform that benefits our members and rail customers right across the UK.”
Today’s announcement is an example of the industry delivering on the commitments it made in its cross-industry plan – launched last year – to deliver simpler ticketing and better value for money for customers, and to keep changing and improving for the economy, customers, communities and employees. Examples include the start of 18-months of unprecedented improvements with the opening of London Bridge and plans for an independent ombudsman to go-live this autumn.
Jane Gratton, Head of Business Environment at the British Chambers of Commerce (BCC), said:
“Businesses rely heavily on the rail network and will welcome this long-overdue review of the fares and ticketing system. Increasingly confusing, frustrating and unfair, the current system needs to be brought in line with the more nimble and flexible way in which firms now operate. It’s the obvious next step to ensure people gain maximum benefit from the ongoing investment in our railways.”
Notes to editors
The hashtag for the consultation will be #easierfares.
Last October, the partnership railway of the public and private sectors published a long-term plan for change – In Partnership for Britain’s Prosperity. It included a commitment to increase customer satisfaction by developing practical proposals for the reform of fares.
The 1995 Ticketing and Settlement Agreement can be found on the RDG website – chapters 4 and 6 set out how fares should be set and sold.
In addition to changes already underway as part of the fares action plan which will improve the buying experience for customers, over the next six months, the industry will be looking to run a number of trials to test options for a future fares structure.
Also, train companies will be selling more advance fares on the day of travel and more train company websites and apps will display information about when advance fares are running out. The industry will also be continuing to simplify and improve the information printed on orange tickets.
* Examples of some of the long-standing anomalies which are becoming increasingly apparent include:
‘Through-ticket peak-time premiums’, where a customer takes a journey involving more than one leg. The first leg is on a peak-time train and the second leg is on an off-peak service. The customer might be charged a peak-time fare for the whole journey because regulation means train companies have to offer one through-fare. For example, a passenger travelling from north to west via London can end up paying for a peak fare for their entire journey when half their trip is on an off-peak service.
Inflexible 7-day, monthly or annual season tickets, where smart ticketing could offer better products to passengers who work part time. Because smart schemes have been required to sell the same products as the paper tickets, this is often not possible.
The advent of digital ticketing and smartphones means there is potential to retail tickets in a way that lets more customers buy tickets where and when it suits them, and be confident they are paying the right fare. However, the inflexible nature of the current underlying fares structure and regulation limits the possibility to do this.
The rail industry, working with KPMG, has undertaken a detailed pre-consultation policy scoping review process to define the parameters of this ticketing and fares reform consultation which is available on the RDG website.
Data on self-employment and part-time working is based on ONS April 2018 labour market statistics.
Timeline of consultation process:
Public consultation opens – Monday 4 June
Public consultation closes – Monday 10 September
Final report – Late autumn
The proposed consultation is not about the overall balance between farepayers and taxpayers since this choice is rightly a matter for governments.
Posted by CyclingSid at 07:41, 5th June 2018
Whatever the outcome, I hope the implementation is better than the new timetables.
Posted by welshman at 18:51, 4th June 2018
People's Republic of Wales obviously.
Posted by grahame at 17:52, 4th June 2018
I find it interesting that on the same day that the Rail Delivery Group announce their fare consultation, Transport for Wales release details of the new Welsh franchise which includes a number of fare changes which will add yet more variety and differences between England and Wales ...
Posted by JayMac at 16:12, 4th June 2018
Where was the question about increased state subsidy to reduce fares across the board?
Posted by grahame at 13:27, 4th June 2018
10 September.
Thanks - will probably split thread and add consultation to calendar tonight (unless someone beats me to it)
Done!
Split from http://www.firstgreatwestern.info/coffeeshop/index.php?topic=19779.0
From Association of British Commuters [Southern, Facebook] A post and a follow up
In #Metro today. Seriously how dodgy and disgraceful is this!!! Passengers to be asked if they would pay more for better service? Unbelievable! NO is the answer.#RDG #chrisgrayling #transportfocus #anthonysmith #jojohnson #railminister
HAVE your say here - if anything the fares should be reduced at least by half
Dear all please read the survey carefully- the questions are structured in a manipulative way. Bottom line is they want to increase the fairs and want to manipulate passengers to agree to it
Posted by stuving at 10:45, 4th June 2018
The text of that (in its PDF form) says:"This survey, which is part of a joint consultation between the rail industry and passenger watchdog Transport Focus,...". Elsewhere, it seems to refer to itself as "this consultation".
Posted by grahame at 10:20, 4th June 2018
10 September.
Posted by didcotdean at 10:14, 4th June 2018
10 September.
Posted by grahame at 09:58, 4th June 2018
Consultation has started here: https://www.britainrunsonrail.co.uk/fares
Haven't had a chance to read through it myself but reportedly everything is in the option mix: elimination of season tickets in favour of a cap; elimination of peak / off-peak distinction; obviation of split ticketing; fares determined by speed and/or distance ...
EDIT: there is also a pdf version: https://www.britainrunsonrail.co.uk/files/docs/English_Version_v2.pdf
Can't see an END date on those links ... if someone could find one / follow up please ('ve limited access today) .... Thanks!
Posted by didcotdean at 09:39, 4th June 2018
