| Re: Bristol Temple Meads - station, facilities, incidents and events (merged posts) In "Bristol and Bath (WECA, now WEMCA)" [381249/10737/21] Posted by WelshBluebird at 17:39, 23rd October 2026 | ![]() |
There are also some ticket types that are not able to be bought from a ticket machine
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 In "Across the West" [381248/31163/26] Posted by TaplowGreen at 16:44, 23rd October 2026 | ![]() |
Elizabeth line services between Slough and London Paddington
A speed restriction over a bridge between Southall and Hanwell means some lines are blocked. As a result, Elizabeth line services between Slough / Heathrow Airport and London Paddington may be cancelled or revised.
This is expected until 18:00.
| Re: Storm Austen: modified services In "Across the West" [381247/32650/26] Posted by IndustryInsider at 16:03, 23rd October 2026 Already liked by Western Pathfinder | ![]() |
....................there's a policy?
https://assets.publishing.service.gov.uk/media/600eaa69e90e071440e63da1/valuing-nature_a-railway-for-people-and-wildlife-the-network-rail-vegetation-management-review-document.pdf
From 2018, so not sure if there’s an update somewhere.
| Re: Electric Trains - Manchester to Sheffield, retired to the Netherlands In "Railway History and related topics" [381246/32133/55] Posted by Electric train at 15:59, 23rd October 2026 | ![]() |
ET, thanks for the additional technical insights. Did you mean to suggest that the 6.25kV was just for individual bridges? (as that's the impression I got).
Was 6.25kV employed anywhere else? (e.g. the Glasgow network).
The 6.25kV was used for electrical sub sections under bridges / tunnels and multiple bridges where they were close together. The EMU Class 306 (AM6) were converted from DC to AC.
Yes it was used on the Glasgow system for tunnels and bridges although this was never a 1500V DC system
6.25kV sub electrical systems would have been kept as short as possible because of the Voltage drop and higher current hence large conductors there would have been a balance between this and the cost of the additional transformers and circuit breakers
There has been a bit of a thing about collecting details and dates of electrification programmes, on RailForums over the last 2-3 years. The sources include books, technical magazines and papers, ferreting about on line, and the many ex-railway members of the forum who worked on them.
The consensus of that work is that Liverpool St - Shenfield at least was all converted 1500 DC - 6.25 kV, and then later all uprated to 25 kV. One of my few contributions to this collection was to locate the 1962 Langley Report, "Railway Accidents - Failures of Multiple-unit Electric Trains on British Railways". This inquiry was set up to explain the alarming series of on-board explosions in Glasgow Blue Trains, including the Renton accident which injured a guard and seven passengers (three seriously). However, it contains a thorough description of the Modernisation programme electrification work to date.
That report includes the attached table, which confirms that the GE network was done with 6.25 kV continuous over the suburban part to Shenfield and onward to Southend (Victoria). It was the "north-east London suburban" network that had a mixture of voltages, and so did the Glasgow suburban lines. The LTS lines are missing from the table, as electrification work was still underway when the inquiry started. There is a mention of a limited electric service starting there in 1961, and many of the TLS stock which were built earlier and used on other lines temporarily.
You can't tell from the table how long the 6.25 sections were (or how many) but the similarity of the total route miles at 6.25 and 25 kV (25:24 in NE London, 20:32 in Glasgow) suggests more than just a bridge or three at a time. After all, each transition needed a neutral section with APC magnets to open and close the pantograph circuit breaker.
Many thanks for the info, I gleaned part knowledge from engineers involved in later conversion of the 6.25kV bridge subsections.
The conversion of the 1500V DC to 6.25kV makes sense as the could switch and entire route from DC to AC literally over a weekend. Based on Stuving info I feel the upgrade happened fairly quickly where possible during the 1960 using ABB minimum oil circuit breakers leaving the low bridges at 6.26kV these areas on the Liverpool Street - Shenfield being converted in the 1970 where the metal clad air insulated 25kV switchgear developed by GEC and South Wales Switchgear was used
Both the Glasgow, the LTS and the Liverpool St - Southend used 25kV Asea Brown Boveri (ABB) minimum oil circuit breakers these were installed from the early 1960 the last going out of service on the LTS around 2007. As a side note they were prone to switchgear expulsions destroying / badly damaging the brick building housing them. I was the site Distribution construction Engineer at Dunton, in 2005 replacing the totally destroyed ABB building with a redundant 25kV air insulated metal clad vacuum circuit breaker building recovered form the ECML.
| Re: Storm Austen: modified services In "Across the West" [381245/32650/26] Posted by TaplowGreen at 15:09, 23rd October 2026 | ![]() |
There have been/are trees down/been struck at:
St Austell
Luxulyan
Cullompton
Bruton
St Keynes
Bere Ferrers
Perranwell
Yeoford
The Dawlish sea wall was closed this morning due to broken ballast boards.
St Austell
Luxulyan
Cullompton
Bruton
St Keynes
Bere Ferrers
Perranwell
Yeoford
Anyone would think that the vegetation management policy might just be in need of review
All down to fallen trees on the line.......
Alterations to services between Par and Newquay
Cancellations to services between Basingstoke and Reading
Cancellations to services between Exeter St Davids and Barnstaple
Cancellations to services between Truro and Falmouth Docks via Penryn
Alterations to services between Yeovil Pen Mill and Castle Cary
Quite breezy here in Taplow now but the rain has largely held off all day apart from a few bursts (generally whilst I was outdoors!)
| Re: To 'stockpile food' is now our Government's official policy, apparently In "The West - but NOT trains in the West" [381244/32456/31] Posted by broadgage at 14:38, 23rd October 2026 | ![]() |
For bottled drinking water, I suggest sparkling water in glass bottles.
Glass bottles are preferable because plastic bottles are slightly pervious and allow the carbon dioxide to escape.
Sparkling water is preferable to to still, because the dissolved gas is slightly anti bacterial, and the escaping pressure on opening provides assurance that the seal was intact.
Still water in plastic bottles should be replaced, by or shortly after the expiry date. Sparking water in glass bottles keeps indefinitely.
Any bottled water is better than none.
| Re: Please help the Webmaster - how and where do you browse from? In "News, Help and Assistance" [381243/32656/29] Posted by GBM at 14:26, 23rd October 2026 | ![]() |
Desktop PC. Chrome browser with BT Norton security.
FTTC, between 35/50mbs download.
Rarely use my Samsung mobile for this site.
The print is too small without trying to find where I left my glasses!
Yes, I know I can manually enlarge the page print, but each reply comes out at a different size!
Too much hassle, so I try not to use my mobile for the forum.
| Re: Storm Austen: modified services In "Across the West" [381242/32650/26] Posted by Witham Bobby at 12:44, 23rd October 2026 | ![]() |
St Austell
Luxulyan
Cullompton
Bruton
St Keynes
Bere Ferrers
Perranwell
Yeoford
St Austell
Luxulyan
Cullompton
Bruton
St Keynes
Bere Ferrers
Perranwell
Yeoford
| Re: Storm Austen: modified services In "Across the West" [381240/32650/26] Posted by plymothian at 12:31, 23rd October 2026 | ![]() |
St Austell
Luxulyan
Cullompton
Bruton
St Keynes
Bere Ferrers
Perranwell
Yeoford
Surely a solution is provide a place to buy tickets at this new entrance?
A couple of machines would mean people can buy a ticket
There are two ticket machines there already.
I am confused now by the post from Chuffed - why did they just not buy a ticket from the machine and walk through the barriers?
I’m sure chuffed can speak for themself, but are there not circumstances where people might want to discuss their travel arrangements at the ticket office? This, surely, is why we faught to keep them a few years ago…
| Re: Storm Austen: modified services In "Across the West" [381238/32650/26] Posted by bobm at 11:45, 23rd October 2026 | ![]() |
Over an inch of rain in Swindon between midnight and 9am.
| Re: Storm Austen: modified services In "Across the West" [381237/32650/26] Posted by JohnM at 11:44, 23rd October 2026 | ![]() |
| Re: Bristol Temple Meads - station, facilities, incidents and events (merged posts) In "Bristol and Bath (WECA, now WEMCA)" [381236/10737/21] Posted by Phantom at 11:18, 23rd October 2026 | ![]() |
We have acknowledged that an error was made in not allowing you through the gates and, as a result, we did not meet our ATP obligation on this occasion.
As this is a new operation, there can sometimes be unforeseen issues during implementation, mistakes can happen. However, we take these situations seriously and use them as opportunities to learn, review our processes, and put measures in place to help ensure we consistently meet our commitments in the future.
Thank you for bringing your experience to our attention and helping us identify where improvements are needed.
Yours sincerely
Yours sincerely
I had to look up ATP - "Automatic Train Protection" turns out to be "Accessible Travel Policy". I don't have the context in which the reply was written - so I hope it's a term you used, chuffed, in which case their use of it in writing to you is AOK - otherwise, it's rail jargon, and shouldn't be used without explanation to customers.
The rail industry has "created itself" a problem with multiple gated entrance stations where they offer a complete staffed ticketing service outside only one of them. Typically the reason for multiple entrances is to reach a different customer catchment area. You see the same thing at Chippenham. Bath Spa - less of an issue; it's very easy and perhaps reasonable there to some across the bridge over the Avon from Widcombe and walk under to the ticket office. It would be no shorter to go in and out through 2 sets of barriers.
As an after thought - why is this only an issue for passengers with a disability - or is in an issue for all? Cynthia Doe gets off the no. 8 bus with her twins in their pushchair, and needs access to the ticket office / travel centre ...
I get the impression that the gate staff are getting a lot of hassle from people who realise they've gone out the wrong exit/want the staffed ticket office/want the cashpoint/are trying it on etc.
That said, a person with reduced mobility shoudl reasonably be given the benefit of the doubt.
Add to that sadly there will be people who see it as a way to get a free ride on a train
The part about reduced mobility, I don't know Chuffed personally, but I also have a disability card, but I don't have a physical disability, unless you knew me personally you would not realise why I have the card
I am confused why a ticket was not bought at one of the ticket machines, if there is uncertainty about how to use the machine I would expect the member of staff to assist
| Re: Bristol Temple Meads - station, facilities, incidents and events (merged posts) In "Bristol and Bath (WECA, now WEMCA)" [381235/10737/21] Posted by Phantom at 11:15, 23rd October 2026 | ![]() |
| Re: Storm Austen: modified services In "Across the West" [381234/32650/26] Posted by JohnM at 11:05, 23rd October 2026 Already liked by grahame, Chris from Nailsea | ![]() |
Trees barely moving in Melksham
| Re: Please help the Webmaster - how and where do you browse from? In "News, Help and Assistance" [381233/32656/29] Posted by Marlburian at 10:48, 23rd October 2026 | ![]() |
My eyes glazed over when reading some of the techno-jargon in preceding posts! I access this website only from my home PC, which has become slow with age, with no fancy (if desirable) add-ons (except an adblocker). I've never had issues with Coffee Shop performance. I did try a free Proton VPN but found it took a while to find an overseas location; it blocked me from a couple of websites that I do visit and was reluctant to be closed.
I use a cheapo mobile phone, mostly for texts and emails, and, being clumsy, find it difficult to use it to compose anything other than a short message.
| Re: Storm Austen: modified services In "Across the West" [381231/32650/26] Posted by rogerpatenall at 10:36, 23rd October 2026 Already liked by Witham Bobby, Red Squirrel, GBM | ![]() |
Hot off the press: my son, in Falmouth, tells me that their bin blew over…
I hope the emergency services dealt with the Great Bin Disaster before dealing with boring old trees, etc. . .
| Re: Please help the Webmaster - how and where do you browse from? In "News, Help and Assistance" [381230/32656/29] Posted by grahame at 09:46, 23rd October 2026 | ![]() |
Some really useful feedback thus far - please keep it coming.
| Re: Storm Austen: modified services In "Across the West" [381229/32650/26] Posted by bobm at 09:38, 23rd October 2026 | ![]() |
Tree down on the Falmouth branch. Same on the Gunnislake and Newquay lines.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 In "Across the West" [381228/31163/26] Posted by TaplowGreen at 09:17, 23rd October 2026 Already liked by NickB | ![]() |
...............no need for storms to make the railway fall over in the Thames Valley, we have this sort of thing virtually every day.........."until the end of the day"
Due to a points failure between Reading and London Paddington fewer trains are able to run on some lines towards London Paddington.
| Re: Please help the Webmaster - how and where do you browse from? In "News, Help and Assistance" [381227/32656/29] Posted by Red Squirrel at 08:46, 23rd October 2026 | ![]() |
No VPNs, nothing particularly fancy. Occasionally access via public wifi or mobile hotspot, but usually from home.
| Re: Storm Austen: modified services In "Across the West" [381226/32650/26] Posted by Red Squirrel at 08:41, 23rd October 2026 Already liked by Chris from Nailsea, Mark A, Witham Bobby, Clan Line | ![]() |
| Re: Storm Austen: modified services In "Across the West" [381225/32650/26] Posted by Mark A at 08:40, 23rd October 2026 | ![]() |
Ew. Hadn't checked, but high tide is listed as 4.49am. Realtimetrains has the down sleeper listed as passing Dawlish at 04:49 and terminating at Plymouth so it may be that contingencies are activated.
[EDIT to add] But happily the centre of the low pressure system is booked to pass directly over Dawlish at the same time too, so if everything runs to time the wind will have fallen away more or less completely.
https://www.realtimetrains.co.uk/service/gb-nr:W34774/2026-10-22/detailed
In the event it picked up a few minutes delay through Dawlish, a few more by Newton Abbot and over the banks, but was less than half an hour late into Plymouth where it terminated.
| Re: Mayer Hillman In "Buses and other ways to travel" [381224/32655/5] Posted by Red Squirrel at 08:40, 23rd October 2026 | ![]() |
Thanks for highlighting this, Trowres.
| Re: Please help the Webmaster - how and where do you browse from? In "News, Help and Assistance" [381223/32656/29] Posted by bradshaw at 07:48, 23rd October 2026 | ![]() |
I access in the UK and at home use Vodafone broadband (FTTC) with them providing their Secure Net filtering system. I also use an iPhone 14 when on the move which also has Secure Net when linked to them and Sophos X for mobile when not.
| Re: Electric Trains - Manchester to Sheffield, retired to the Netherlands In "Railway History and related topics" [381222/32133/55] Posted by Electric train at 06:53, 23rd October 2026 | ![]() |
| Re: Aberfan disaster - 21 October 1966 - 116 children, 28 adults killed In "The West - but NOT trains in the West" [381221/31667/31] Posted by broadgage at 06:20, 23rd October 2026 Already liked by GBM | ![]() |
ISTR, that the dedicated graveyard, situated on a hillside nearby was recently refurbished. Each grave is marked by an arch of white marble, these had not stood up to the weather and were refurbished/renewed.
I visited the graveyard before the restoration, and was saddened by the (then) poor state of repair.
We visited in February 2017, and all was looking OK then.I visited the graveyard before the restoration, and was saddened by the (then) poor state of repair.
Very sad
I think that the the repairs and refurbishment must have been longer ago than I realised, and prior to your visit.
