| Re: Derailment in Normandy In "The Wider Picture Overseas" [379609/32488/52] Posted by stuving at 00:48, 16th September 2026 | ![]() |
Clearing and repairing the track is going to take over a week. The first stage is removing the two damaged - or in one case wrecked - DMUs. SNCF are using the same method as NR did at Lewes - the two-Kirow ballet. While the five vehicles on the track are being moved, a lot of trees have to be felled so the two jibs can be slewed far enough to reach the other vehicle.
| Re: Automatic can use multi-operator if train cancelled In "Fare's Fair" [379608/32502/4] Posted by grahame at 22:45, 15th September 2026 | ![]() |
Customers holding a valid ticket will be able to travel on another participating operator’s train, departing within 2 hours before or after their original cancelled service, using a direct or reasonable alternative route. Passengers will need to show their original ticket to customer support staff on their new service as proof of purchase, with no requirement to download a new ticket.
"Customers holding a valid ticket [...]"
So I have a Network Railcard discounted ticket from Waterloo - Exeter, possibly split at Honiton. Is that valid to travel on GWR via Taunton?
I have a series of split tickets Paddington - Plymouth, with a Network Card split at Newbury, Pewsey and Hungerford. Is that valid to travel on a non-stopping service?
I have a Sheffield - Taunton not via London ticket Is that valid to travel via London?
"[...] using a direct or reasonable alternative route"
How is everyone going to know my train was cancelled across all those regions/operators? Can I just buy a cheaper ticket and make it up or will I be expected to have proof?
On line systems typically let staff look up cancellations all across the network; they can find the proof.
Reading the statement with a pedant's eye in answer to your questions
* London stations to Exeter "via Honiton" WILL be accepted via Taunton.
* Sheffield to Taunton "not via London" WILL be accepted via London but not on East Midlands Trains
* It says "ticket" singular, so a split ticket booked journey must still stick to the "must call at" rule.
And adding some thoughts of my own
* Nothing is said about failed connections - only cancellations. So a late running train that fails to connect with another operator is not covered. For example, a Penzance to Cheltenham Spa Advance ticket on GWR to Plymouth then XC but where the train from Cornwall is late - it does NOT cover onward travel by GWR from Plymouth and you must wait for the next Cross Country service.
* Can we treat a train that stops short as a cancellation - for example, if a Bristol to Portsmouth passenger who finds his (advance ticket) train gets cancelled beyond Southampton - I'm unclear as to whether he can carry on with SWR or Southern or must wait for the next GWR service an hour later
* A passenger planning to travel from Melksham to Bristol Parkway, tickets only available via Bath Spa, CAN travel via Swindon if the service via Bath Spa is cancelled - and indeed may want to because it's much faster
* Passengers from stations with occasional services cannot take advantage of the scheme if the next train isn't until more than two hours later. Menheniot, Pilning, some gaps at Melksham, smaller stations on the halts train in Oxfordshire
* I am unclear as to how this works with tickets sold on virtual branch lines - a ticket from Kingsbridge to Kings Norton, for example.
I am probably overthinking this and in practise I find staff pretty reasonable when things go wrong.
| Re: Another worrying incident of sabotage - now in the Netherlands 15 Sept 2026 In "The Wider Picture Overseas" [379607/32506/52] Posted by stuving at 21:18, 15th September 2026 | ![]() |
...and a degree of insider knowledge as to how railways technically work.
Yes, though that only needs to be one person involved in the planning. But the degree of planning and the number of people involved does say "political group" (including workers' ones). We don't seem to be using "splinter group" any more - is there a current equivalent?
| Re: Another worrying incident of sabotage - now in the Netherlands 15 Sept 2026 In "The Wider Picture Overseas" [379606/32506/52] Posted by Oxonhutch at 21:08, 15th September 2026 | ![]() |
| Re: Plymouth - Devonport - Saltash - St Germans - Liskeard (local) services In "Shorter journeys in Plymouth and Cornwall" [379605/32505/25] Posted by Chris from Nailsea at 20:30, 15th September 2026 | ![]() |
Is it just me, or does the word "replacement" (which I have automatically used) worry you too where the alternative / substitute offered / suggested is very different from the product that's supposed to be there?
I agree: the word used should be 'alternative'.
| Re: Checking on your train running just before you set off In "Introductions and chat" [379604/32503/1] Posted by Chris from Nailsea at 20:03, 15th September 2026 | ![]() |
In my retirement, I generally don't 'book in advance' for rail travel: it's no longer time critical, as it used to be when I had an important team meeting to attend in London, for example.
Nailsea & Backwell, on the main line, benefits from a rather reliable service, these days: half hourly services into Bristol Temple Meads, for example, from which there will probably be alternative options if there is any disruption.
I will be taking the three trains from Nailsea to Kemble tomorrow (two changes, at Bristol and Swindon). I will only be looking at 'train running' so I can inform my family that I may be a few minutes late for our lunch.
| Re: Dreadful GWR performance figures In "Across the West" [379603/32150/26] Posted by TaplowGreen at 20:00, 15th September 2026 | ![]() |
Am I being unrealistic, or are these figures some accepted new normal ?
I don't think any of the operators is doing especially well at the moment, so this is not a GWR thing. I think it's the 'new normal' until GBR is up and running when there might be more structure and therefore more accountability and control. At the moment it's a mess organisationally and that feeds down to the operational side of things.
And when I say GBR is up and running, I don't mean in December when GWR moves under direct government operation, but when the whole GBR organisation steps out of the shadows and into the limelight. Scheduled for next year still?
How would the semi-permanent cancellation of the Padd to Didcot services be represented on here? The services ‘operated’ but skipped Twyford, Maidenhead and Slough for much of the month.
Happy to be corrected, but I think any service that skipped a station (including services that start/terminate short) are counted as a 'half' cancellation for the 'All Cancellations' figure.
It seems like only yesterday when you first said "Manana Manana"
| Re: Another worrying incident of sabotage - now in the Netherlands 15 Sept 2026 In "The Wider Picture Overseas" [379602/32506/52] Posted by stuving at 19:50, 15th September 2026 | ![]() |
From what I've seen of the size of these pipes and cables, they were not intended to cause anything like a derailment. All about activating track circuits, using for example jump leads or pipes "attached" to the rails. I have no information how that attachment might have been done, but some kind of scaffold clamp perhaps?
One specific trick has been to do this near a level crossing, brining the barriers down until the shorting link is removed. Of course that might also be just because that's easy to get to. But doing this during the day and on such a scale, you'd think something was caught on CCTV. But then, if the operation was carefully planned for its effect on the railway, it also was done knowing how to avoid cameras.
| Re: Dreadful GWR performance figures In "Across the West" [379601/32150/26] Posted by grahame at 15:48, 15th September 2026 | ![]() |
It's been a difficult summer weather-wise, and other factors such as the side effects of pending re-organisation, budgetary control, world events, and so on all have their effect. And so standards slip, or feel like they are slipping, right across the board. How much of the slippage in our region is just a refection of nationwide ills, and how much of the performance issue is more regional of local?
I went to Open Train Times, where they produce station performance rankings, and share with you a map showing where the stations in a particular area come in a ranking. I also took a number of stations starting with "M" across Great Britain, and had the site plot their rankings for the last 6 months.
I personally question the Open Train Times evaluation algorithm, as I feel it give too little weight to cancellations, and so too much wait to delays. However - the shape of the curve, where things have got better and where worse, is very informative.
| Re: Dreadful GWR performance figures In "Across the West" [379600/32150/26] Posted by IndustryInsider at 14:56, 15th September 2026 | ![]() |
| Re: Dreadful GWR performance figures In "Across the West" [379599/32150/26] Posted by NickB at 14:17, 15th September 2026 | ![]() |
Abysmal is polite.
| Re: Dreadful GWR performance figures In "Across the West" [379598/32150/26] Posted by John D at 14:04, 15th September 2026 | ![]() |
GWR have now published performance figures for 4 weeks 26 July - 22 August 2026
Once again, depending on how polite you are, somewhere between awful and abysmal
Cancellations overall 7.02%
but certain lines did worse, eg
London - Cotswolds 10.16% cancelled
Outer Thames Valley 9.81%
North Downs 9.33%
London - South Wales 9.07%
Bristol Suburban 8.67%
South Wales - South Coast 8.51%
Plymouth and Cornwall 8.24%
Some of the cancellations were due to external factors, so not all GWRs fault (although how quickly they recover from an incident is really a function of control). But worryingly some areas had over 6% cancelled that were totally due to GWR
However you look at it, a commuter doing 5 return trips (10 return journeys) shouldn't have to put up with 1 of those 10 cancelled
https://www.gwr.com/-/media/gwr-sc-website/files/publications/performance-report/gwr-performance-report-period-2705.pdf
Of the trains that did run, only about half (51.96%) actually ran on time, with one group not even managing 30% on time.
If you use the more generous within 3 minutes, GWR didn't even get 7 in 10 meeting that spec, with the worst group achieving just a lowly 44.67%
Sometimes I try and encourage public transport use, but am I wasting my time when GWR seems so out of its depth and performs so badly, and seems to be getting worse. This is not a bad day, it is ongoing for months.
| Another worrying incident of sabotage - now in the Netherlands 15 Sept 2026 In "The Wider Picture Overseas" [379597/32506/52] Posted by eightonedee at 13:54, 15th September 2026 | ![]() |
Following the recent incident between Rouen and Caen, there has now been another, apparently larger scale and more organised incident in the Netherlands-
https://www.bbc.co.uk/news/articles/c8ly49w9g1edo
I have already seen speculation on-line about the involvement of Russian involvement. Having regard to the veiled threats made by Putin, I am not inclined to dismiss this as paranoia.
The aftermath of the 1987 storm, was unique.
The power failed across the south east, which remained disconnected from the rest of the grid. a "black start" of the south east was performed, and the area run for some hours as an island, still disconnected from the rest of the grid.
| Re: Checking on your train running just before you set off In "Introductions and chat" [379595/32503/1] Posted by Phantom at 10:12, 15th September 2026 | ![]() |
If I have planned in advance to travel, I will always check Realtimetrains before travelling, but if a spur of the moment thing I would just turn up, but that would mainly be because I would be on route that I know there are regular services available
Timetable, fares, terms and conditions some six months later ...
Returning to the subject of food stocks, I am still working though the dried pasta and jars of tomato-based sauces that I got at the start of Covid-19 in early 2020 (remember that?) in preparation for a long lockdown. They have kept well.
Ah ... yes ... that reminds me ...
| Re: West Wilts Rail User Group - 16th September 2026 In "Diary - what's happening when?" [379592/32313/34] Posted by grahame at 09:56, 15th September 2026 | ![]() |
Late notice extra ... from https://www.facebook.com/groups/wwrug
From DILTON MARSH for our meeting tomorrow (16.9.26) evening in Trowbridge, GWR are making an extra stop at 18:04 on the Portsmouth - Cardiff train than usually goes through non-stop at that time.
Big THANK YOU to GWR for this extra stop. Please do come along to our event at 19:00 (coffee and networking) for 19:30 - talk by Peter West OBE, looking at the rail review that's bringing big changes, and updating us on how it's going and how it will go. All welcome - guests £2. Venue - Bethesda Church Hall, about 100 yards from Trowbridge Station.
Dilton Marsh station has grown from a remote little station serving a village and field into a station servicing (now) a much larger village on one side, and the Westbury suburb of Westbury Leigh on the other, and as such is the railhead for quite a large residential area. Services have somewhat improved over the years, and we might anticipate that they'll continue to do so, with operational changes making the station much more akin to a regular stop than a halt.
| Re: A379 at Slapton Sands in south Devon - sea related incidents In "The West - but NOT trains in the West" [379591/31569/31] Posted by Chris from Nailsea at 09:41, 15th September 2026 | ![]() |
Seafront repair works under way after storm damage
Works to reinforce a seafront have started after it was battered by winter storms.
In May, the Environment Agency (EA) announced it had approved £19.8m for the scheme at Torcross in Devon.
The defences were damaged by multiple storms in January, eventually leading to part of the A379 coastal road between Torcross and Slapton being washed away in February. The road remains closed.
The EA said: "We recognise how important access at the southern end of Torcross beach is to the community, and we are continuing to work on a solution."
Torcross seafront will soon have 25m of rock armour installed to help protect the village
Under the plans, 25m (82ft) of armour - made up of large rocks - would be placed on the beach between the access steps at the southern end and the slipway at the north end, project leaders said.
The Tank car park in the village has been closed to become a compound for the works, with the first rocks due to arrive on 17 October.
| Re: Automatic can use multi-operator if train cancelled In "Fare's Fair" [379590/32502/4] Posted by plymothian at 09:28, 15th September 2026 Already liked by Witham Bobby, PrestburyRoad, rogerw, Mark A | ![]() |
| Re: Westbury -> Warminster -> Salisbury -> Waterloo through train not running In "South Western services" [379589/32407/42] Posted by grahame at 09:17, 15th September 2026 | ![]() |
Now the 0750 through train has been removed................should I bother any more ?
Here's the danger to the passenger experience (and so to the number of customers in the medium term and beyond) of removing this as a through train - although Recent Train Times does suggest that this failure is the exception rather than the rule.
I was also very wary about hiring someone young and/or inexperienced with too many qualifications as it suggested a focus on exams rather than practical experience. ...
From Huffpost
Michael Nicholson.
The 71-year-old man from Kalamazoo, Michigan, has earned 29 degrees -- and he's not finished yet. ABC News breaks that down: one bachelor's degree, two associate's degrees, 22 master's, three specialist degrees, and one doctoral degree.
"I would like to get to 33 or 34. I'm almost there," Nicholson told ABC News. "When I complete that, I'll feel like I've completed my basic education. After that, if I'm still alive -- that would take me to 80 or 81 -- I would then be free to pursue any type of degree."
That did come back to bite me though when I applied recently for a government job and didn't get an interview on the basis of not having a particular low level qualification (or rather I did but had let it lapse about 20 years ago). I suspect though that's AI job filtering to strict criteria rather than my 30 years experience in the field.
I can ... understand ... that frustration. I have a number of connections with guests from Ukraine who are highly intelligent, very well qualified, but with qualifications that are not recognised in the UK. The lady who's got a second degree in environmental sciences, really bright and "with it", and is stacking shelves in a store in Swindon. In contrast, I had a job lined up for when I finished my Batchelor's degree, ((sure, I got an upper second with honours (too lazy to have got a first))), but whether or not I passed and got "letters" didn't matter to my employer, and it's never been of any consequence to getting a job since.
A couple of things I have picked up overnight - a bus that's running the rest of this week ("rail replacement") from Plymouth to Liskeard at 15:55, calling at Devonport, Saltash and St Germans and arriving Liskeard at 17:32 ....
This bus is in replacement of the cancelled 15:56 Plymouth to Penzance - cancelled "due to more trains than usual needing repairs at the same time". Due to call at all stations to Liskeard at 16:42. The replacment bus, due Liskeard at 17:32 (50 minutes later) leaves out Dockyard, Keyham, St Budeaux and Menheniot.
| Plymouth - Devonport - Saltash - St Germans - Liskeard (local) services In "Shorter journeys in Plymouth and Cornwall" [379586/32505/25] Posted by grahame at 07:42, 15th September 2026 | ![]() |
A couple of things I have picked up overnight - a bus that's running the rest of this week ("rail replacement") from Plymouth to Liskeard at 15:55, calling at Devonport, Saltash and St Germans and arriving Liskeard at 17:32 - that's 97 minutes by bus for a journey that takes a maximum of 45 minutes on the very slowest of trains, and half of that on a typical fast train or one, perhaps, with just one stop. It shows the advantage of rail over road on this corridor, and though I can guess why it's being run (GWR not having enough trains or staff) it's a really poor substitution in my view.
And in the other direction, two extra calls at Saltash
https://www.facebook.com/SaltashRail/posts/pfbid02dHmXCLCLjtRHNY6LG49ePA7RtR9C6MhDRKLZp8bhBaESHFcYsiXQ3SkaXwWk1VKRl
SALTASH RAIL UPDATE
2 ADDITIONAL WEEKDAY SALTASH SERVICES
Following our request to strengthen the temporary rail timetable that has been introduced we are very pleased to report that GWR have added two additional Saltash calls on each weekday from today. Two Penzance to Paddington services will now call at Saltash, Monday to Friday at 16.00 and 17.58. These services will be extremely useful for anyone traveling back from Cornish stations during the afternoon period, ensuring minimal delays and in some cases, providing a better service than previously.
We hope that you can make use of them both for local and long distance travel, and as ever, we hope that wide scale use can help our justification for broader improvements at Saltash.
| [otd] 15th September 1830 - Opening of the Liverpool and Manchester Railway In "Railway History and related topics" [379585/32504/55] Posted by grahame at 06:56, 15th September 2026 | ![]() |
The opening day of the Liverpool and Manchester Railway was a chapter of things going wrong - very wrong indeed, and far more so than we see to this day ... see the description on Wikipedia that reports locomotive failures, people getting off trains between stations (and sadly dying as a results of then being hit by a train), hostile crowds of people, disruptive passengers (refusing to detrain), and trains being there and in working order but not able to run the planned service (facing the wrong way).
| Checking on your train running just before you set off In "Introductions and chat" [379584/32503/1] Posted by grahame at 06:41, 15th September 2026 | ![]() |
From another thread - good question - I would be guessing at a general answer
I think its an excellent idea,but how many travelers would check their booked train is not cancelled before they leave home?
Personally, leaving from home, I usually check. I need to allow 25 minutes from home before the train's departure and I would rather plan an alternative if my train is cancelled or seriously delayed. I do not really want to be waiting / sorting stuff out when I get to the station, as there is usually a very long wait for the next train, even assuming that's running. With a shuttle up and down, staff, infrastructure or train problems tend to mean that if one train's cancelled, there's a higher chance that the next one(s) are as well. Sometimes, 1 train cancellation will result in my aborting a whole day's travel
If a train is shown as delayed, with a new estimated time before I leave home, I will tend to leave home anyway as the train may leave before the estimate. For example, the 05:11 from Gloucester calls at Melksham at 06:29, but if it is advertised at being 10 minutes late from Gloucester, that will show up as 10 minutes late at Melksham too on Journeycheck, but that's only an estimate and it may well make up most of that delay by a quicker reversal at Swindon.
Travelling home from elsewhere, I inevitably keep an eye in on what's happening ahead. At this point, journeys cannot realistically be aborted (except in extremis) and I look to amend plans if something is going wrong. Unlike the outward journey, poor performance of more frequent services inbound to connecting stations make a difference - outbound, I can often realistically wait for the next train, but inbound a longer distance train cancellation of delay makes a big difference - between catching and failing to catch a connection. Also inbound / afternoon train services are more prone to cancellation.
That's just personal - based on experience and the metrics of my local station. What about others?
| Re: Automatic can use multi-operator if train cancelled In "Fare's Fair" [379583/32502/4] Posted by grahame at 06:34, 15th September 2026 | ![]() |
Good question - I would be guessing at an answer on that. In fact I'll start a poll / new thread (here) as we're straying from the original topic.
| Re: To 'stockpile food' is now our Government's official policy, apparently In "The West - but NOT trains in the West" [379582/32456/31] Posted by PrestburyRoad at 06:14, 15th September 2026 | ![]() |
Re police specials and truncheons: I stand corrected. My source was my memory of a tour of Painswick one evening in the 1970s or 1980s given by, I think, a special constable. Apart from the issue of truncheons, I believe he also said that Painswick is used as an early session in the training of specials, because it is a nice quiet town, with the implication that if they can't cope with that then they certainly won't manage Gloucester on a Saturday night.
I can confirm that Painswick is indeed a nice quiet town - I went on a pub crawl back then and it didn't take long - I only found one bar.
| Re: Automatic can use multi-operator if train cancelled In "Fare's Fair" [379581/32502/4] Posted by infoman at 05:13, 15th September 2026 | ![]() |
| Re: Longest taxi ride? On this day, 15th September 1988 In "Buses and other ways to travel" [379580/32501/5] Posted by broadgage at 02:24, 15th September 2026 | ![]() |
The longest taxi journey that I recall, was Minehead to Nunhead at a cost of about £200.
That was after the Hatfield accident.
