| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 In "Across the West" [375353/31163/26] Posted by TaplowGreen at 15:11, 22nd May 2026 | ![]() |
........and also the second one of the day a little further West in the Thames Valley.....I guess now it's a little warmer we have to expect the infrastructure/service to start melting down.......literally as well as figuratively
Still, cracking BBQ weather! Just in time for the Bank Holiday weekend!
Train services running to and from these stations may be cancelled, delayed or revised. Disruption is expected until 19:00 22/05.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 In "Across the West" [375352/31163/26] Posted by NickB at 13:34, 22nd May 2026 | ![]() |
Due to a points failure between Reading and London Paddington fewer trains are able to run on some lines.
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 15:15 22/05.
| Re: West Wiltshire Rail User Group meeting, Trowbridge, 20 May 2026 In "TransWilts line" [375351/32018/18] Posted by GBM at 12:23, 22nd May 2026 | ![]() |
The mention of GWR/Chiltern - might this be the battery train?
| Re: Wokingham station - improvements, resignalling and siding - merged posts In "South Western services" [375350/11448/42] Posted by GBM at 12:04, 22nd May 2026 | ![]() |
Incidentally, since when were OS grid coordinates called X and Y?[/i]
Since never, but unfortunately I assume the days of our schoolchildren being taught something as useful as Ordnance Survey map reading are long gone.
| Re: West Wiltshire Rail User Group meeting, Trowbridge, 20 May 2026 In "TransWilts line" [375349/32018/18] Posted by grahame at 11:28, 22nd May 2026 Already liked by GBM | ![]() |
| Re: Manvers Street, Bath, disrupted for reconstruction works for 6 months from May. In "Buses and other ways to travel" [375348/31887/5] Posted by Mark A at 09:15, 22nd May 2026 | ![]() |
For the next six months in Bath, how are faciilities being provided for personal needs breaks for bus staff on the routes affected, anyone?
| Re: Manvers Street, Bath, disrupted for reconstruction works for 6 months from May. In "Buses and other ways to travel" [375347/31887/5] Posted by Mark A at 09:14, 22nd May 2026 | ![]() |
On the Manvers Street northbound stop - that useful one when leaving the train - the industry seems to be slowly removing its remaining bus services - starting with the 11 to Bathampton. The notice for that *does* have a map but it took me a moment to interpret it as it doesn't show the railway station. Possibly for good reason as the bus will now only stop at the far end of Dorchester Street, so, Number 11 bus passengers who've been on a train - "Welcome to Awkwardsville".
There's also, now, the 'Notice' version of that web page which is mapless - but in common with their web page on this forthcoming disruption, a map would illustrate the extent to which the bus network is disrupted and exactly how much walking people will need to do to make connections. (Both below...)
Stars of the show is Stagecoach's 620 bus, which continues to run to the bus station albeit via a diversion - and usefully stops at a couple of stops on the diversion too - as does the 700 that runs a very occasional service to the decidedly poor area surrounding Julian Road and also the prosperous part of the city up at Sion Hill.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 In "Across the West" [375346/31163/26] Posted by TaplowGreen at 09:11, 22nd May 2026 | ![]() |
Due to a fault with the signalling system between Newbury and Reading trains have to run at reduced speed on some lines.
Train services running to and from these stations may be cancelled or delayed by up to 25 minutes. Disruption is expected until 11:45 22/05.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 In "TransWilts line" [375344/31359/18] Posted by grahame at 08:22, 22nd May 2026 | ![]() |
07:45 Westbury to Swindon due 08:34
08:44 Swindon to Westbury due 09:26
08:44 Swindon to Westbury due 09:26 will be cancelled.
Confusion reigns! Industry open data feeds still report cancelled, but are giving actual times for it running
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 In "Across the West" [375342/31163/26] Posted by TaplowGreen at 07:31, 22nd May 2026 | ![]() |
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 10:15 22/05.
| Re: Manvers Street, Bath, disrupted for reconstruction works for 6 months from May. In "Buses and other ways to travel" [375340/31887/5] Posted by grahame at 06:07, 22nd May 2026 | ![]() |
This, now, from Travelwest.
https://travelwest.info/on-the-buses/closure-of-bridge-street-manvers-street-bath/
Ye gods they could do with a map and connection advice!
Waverley paddle steamer helps out passengers after CalMac ferry breaks down
The crew of a 79-year-old paddle steamer offered passengers a lift from Mull to Oban after their CalMac ferry was hit by a fault.
The Waverley was headed down the Sound of Mull when MV Isle of Mull broke down on Tuesday.
Another CalMac ferry, the MV Loch Frisa, was available but not all the passengers could be accommodated on a 18:40 sailing and the Waverley's crew asked if it could help out.
Some 42 foot passengers were picked up at Craignure and returned to Oban.
https://www.firstgreatwestern.info/coffeeshop/index.php?topic=27523
Something of a co-incidence, Mull comes up again (and indeed Craignure) "On this day" today with the first steam locomotive run on the island in May 1983
Your report, Chris, also brings back memories of a trip of my own on Waverley in - it must have been 1976 or 1977 - when we were sailing up the Clyde and one of the paddle boards came loose. A dreadful thump every time the paddle wheel turned and we dropped to a crawl, and tied up at the nearest emergency place we could which happened to be an oil terminal. A tiny figure of a security guard appeared on the jetty and shouted "You can't tied up here". Wanna bet - big ship, lots of people on a beautiful sunny evening.
TS Queen Mary - in her last year or 2 - was also coming up to Glasgow that evening, and she tied up alongside Waverley and all the passengers transferred across to complete our journey into Glasgow - a rescue story from many years ago. And the last two steam powered passenger boats on the Clyde tied up at - oops - the fuel depot. That was my final trip on Waverley in CalMac hands and I suspected it might have been my last ever. Little did I realise ...
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 In "TransWilts line" [375338/31359/18] Posted by grahame at 05:50, 22nd May 2026 | ![]() |
| Re: Manvers Street, Bath, disrupted for reconstruction works for 6 months from May. In "Buses and other ways to travel" [375337/31887/5] Posted by Mark A at 20:51, 21st May 2026 | ![]() |
| Re: Person hit by train, Taunton 24/10/2025 - Harry Basham, age 17, walking to work In "London to the West" [375335/30967/12] Posted by Chris from Nailsea at 18:06, 21st May 2026 | ![]() |
Teen's rail crossing death was accidental - coroner
The death of a teenager who was struck and killed by a train on a pedestrian railway crossing was an accident, a coroner has concluded.
Harry Basham, 17, was hit by the train in Taunton, Somerset, as he walked to work at about 07:00 BST on 24 October 2025.
Somerset senior coroner Samantha Marsh said there was no evidence he "intended to harm himself" but accepted why he was on the track remained "unanswered".
A Network Rail spokesperson said: "Our thoughts remain with Harry's family and friends and the local community following the tragic accident at the 5/13 railway crossing. We will continue our engagement with local authorities, stakeholders and the community on the future of the crossing."
| Re: Wokingham station - improvements, resignalling and siding - merged posts In "South Western services" [375334/11448/42] Posted by bobm at 18:04, 21st May 2026 Already liked by GBM | ![]() |
Or a second gang turn up intent on demolishing the box and find a pile of rubble.
| Re: New Oxford - Bristol direct service, ongoing developments and discussion In "Oxford, Didcot and Reading from the West" [375333/28355/22] Posted by bobm at 17:45, 21st May 2026 | ![]() |
Freight was held on the up line so reversible working was needed - which obviously does affect both lines.
| Re: Level crossing waiting times In "The Wider Picture in the United Kingdom" [375332/32049/51] Posted by John D at 17:45, 21st May 2026 Already liked by Mark A, Witham Bobby | ![]() |
When I used to live Kingston -Richmond borders occasionally used the level crossing by Sheen station. Have waited for 5 trains to pass.
Get a bit of late running and mix of stopper on Kingston loop, faster trains to Windsor or Reading trains can be just 2-4 minutes apart, get a train going other way between them and just insufficient time to put barriers up.
Before SWR thinned the timetable 6 years ago (and never fully restored it post covid), barriers could be down for around 35-40 minutes each hour in the peak
Someone was asking how these would show up on our disruption map ... yep, they do ...
13:09 Bristol Temple Meads to Oxford due 14:29
13:09 Bristol Temple Meads to Oxford due 14:29 is being delayed between Bath Spa and Swindon and is now expected to be 17 minutes late.
This is due to a late running freight train
13:03 Oxford to Bristol Temple Meads due 14:15
13:03 Oxford to Bristol Temple Meads due 14:15 is being delayed between Swindon and Chippenham and is now expected to be 32 minutes late.
This is due to a late running freight train.
Very odd in effecting trains in both directions - shunt movement at Royal Wootton Bassett?
| Re: Train hits tractor and trailer on level crossing, Leominster, 22 May 2025 In "The Wider Picture in the United Kingdom" [375330/30290/51] Posted by stuving at 14:02, 21st May 2026 | ![]() |
RAIB have published their report on this accident, with the main conclusions on the summary page. This says:
The accident happened because the signaller gave permission to the tractor’s driver to use the crossing, despite the proximity of the approaching train. The signaller had forgotten about the presence of the train when they gave permission and did not check signal box equipment which was indicating the presence of the train beforehand, as they had been trained to. The signaller’s actions may have been affected by an interruption to their established routine for giving users permission to use the crossing, an increase in their workload, distraction and the effects of fatigue.
As Nordan Farm level crossing is a passive user worked crossing, it has no engineered safeguards to warn or protect a crossing user of an approaching train and safe operation is solely reliant on the signaller’s decision as to whether it is safe to cross or not.
RAIB found that Network Rail’s level crossing risk assessment process did not effectively recognise nor control the higher risk present at some crossings during intensive seasonal use. This was an underlying factor. RAIB also found that Network Rail did not have a coherent process for deciding whether a vehicle using a user worked crossing should be considered as large, low or slow moving. This was a possible underlying factor.
The main recommendations are about Network rail's management processes, with some learning points for signallers and other staff too.
| Re: Wokingham station - improvements, resignalling and siding - merged posts In "South Western services" [375329/11448/42] Posted by stuving at 13:16, 21st May 2026 | ![]() |
I just got back from a shopping trip, and I found another missive from NR in the door. It's essentially the same as the first, but with a different background/frame and header "metadata". Both are from Basingstoke Campus, and both sign off as from Community Relations. The second adds Wessex Route to that, and in the heading it says "Ref: ELR: RDG2 62, 02ch / MW/OCT-Wokingham Signal Box". The first is vaguer about it origin, and it is headed "Ref No: RDG_62.0002_STN_WSX_22412 / 20/5/2026 1:00:00 am". Both in the footer invite you to sign up for information about future works, but for services with different names and URLs!
Doesn't that look like a case of the left hand not knowing what the next finger on the same hand is doing? And maybe it's a reminder that just being part of the same legal entity does not guarantee good communications within an organisation. I wonder if we will see more or less of this kind of thing as GBR coagulates.
| Re: Wokingham station - improvements, resignalling and siding - merged posts In "South Western services" [375328/11448/42] Posted by Mark A at 12:58, 21st May 2026 | ![]() |
Ah, and several more stills showing the crossing (as well as many more featuring suburban street scenes from the early 1960s) here:
https://www.reelstreets.com/films/wrong-arm-of-the-law-the/
| Re: Wokingham station - improvements, resignalling and siding - merged posts In "South Western services" [375327/11448/42] Posted by Mark A at 12:48, 21st May 2026 | ![]() |
A still from the film, showing the crossing, here:
https://railwaymoviedatabase.com/the-wrong-arm-of-the-law/
| Re: Wokingham station - improvements, resignalling and siding - merged posts In "South Western services" [375326/11448/42] Posted by Mark A at 12:45, 21st May 2026 | ![]() |
Yes - the site of the crossing actually in nearby Bushy Park Road, how it's been misnamed is lost in the mists etc etc.
| Re: Wokingham station - improvements, resignalling and siding - merged posts In "South Western services" [375325/11448/42] Posted by Witham Bobby at 11:22, 21st May 2026 | ![]() |
That put me in mind of what might have been a previous Feltham resignalling programme. I never noticed the box at Teddington, but, crossing the footbridge on the Kingston end of the station, the sight and sound of the pair, home and distant signal arms, fairly close to the bridge, implied its existence, and there was also the signalbox for the keeper who operated the crossing gates for Bushy Park Road some way towards Hampton Hill - for good measure, there were gasholders close at hand there too. Think it was 1973 that all the signalling in the area was replaced with the colour light variety, the crossing replaced by a footbridge, and later the gasholders went, the site eventually used for a care home and slightly gasholder-shaped blocks of flats.
Famously, the signalbox and level crossing that features in the 1963 Ealing film "The Wrong Arm of the Law" was at Fairfax Road, Teddington. Is that the one you mean? Closed in 1973
| Re: Five to nine… In "London to the Cotswolds" [375324/32053/14] Posted by Witham Bobby at 11:14, 21st May 2026 | ![]() |
Sounds like good news
Maybe 9-cars will more reliably get to Hereford than 5-cars
The down service seems often to suffer a long wait at Moreton Cutting, held for an up fast or two to pass by, before crossing to the Down Relief and on towards Oxford. Hit for four of five minutes there, and then loses time along the way. Sometimes I think ARS (Automatic Route Setting) has a lot to answer for!
