In "Shorter journeys in Plymouth and Cornwall" [376341/28556/25]
Posted by ChrisB at 11:31, 23rd June 2026
As a result, the service is running hourly as opposed to the usual hourly service. All trains will continue to serve Perranwell.
huh?
In "Shorter journeys in Plymouth and Cornwall" [376340/28556/25]
Posted by IndustryInsider at 11:13, 23rd June 2026
Just the two branches nixed today.............
Due to more trains than usual needing repairs at the same time between Liskeard and Looe all lines are blocked.
Due to more trains than usual needing repairs at the same time between Truro and Falmouth Docks fewer trains are able to run on some lines.
Dreadful grammar, does no one take O level (GCSE nowadays) in English anymore
Lines are blocked because more trains need repair, surely that should be nothing to do with a blockage, but depot can't cope with repairing trains allocated to it, so can't find any rolling stock.  Or does it mean a train has broken down blocking the line (and why all lines, not line, is there more than one)
Truro and Falmouth docks, again no explanation of why happens to between those stations, rather than other lines.   Also can be read as 1 of 2 trains isn't operating, so does that mean half fleet for that line is unrepaired.
Fewer trains are able to run on some lines, what does that mean, which lines, why are they unable rather than could if we had enough.
Homework mark about D+ for confused reasoning and inaccurate facts
Agreed, this style of messaging is incoherent and doesn't reflect well on the industry.
With the Looe branch, 150239 has been sent down on a VSTP schedule so the branch reopened with the 10:48 from Liskeard, so the first three trains ended up being cancelled.
As for the Falmouth branch, was this additional information for the Falmouth entry showing earlier today, but not quoted, TG?
Due to a train fault, one of the trains we had planned to run the Truro to Falmouth Docks service is out of action, with a spare not immediately available.
Customers can, if they prefer, use their tickets on local buses. Details below.
Go Cornwall Bus route 32A: Falmouth (The Moor), Penryn, Truro (Bus Station), Truro (Station), Go Cornwall Bus route 33, 33A: Falmouth (The Moor), Penryn (Station), Redruth (Station) and Go Cornwall Bus route 36: Truro (Bus Station), Perranwell (Station) are conveying passengers via any reasonable route until further notice. Arrangements have been made for Great Western Railway rail tickets to be accepted for these journeys.
Re: Weather updates from across the UK and implications for infrastructure - 2026
In "The Wider Picture in the United Kingdom" [376339/31355/51]
Posted by didcotdean at 11:00, 23rd June 2026
Puzzled by today's weather as the possibility of that downpour seems to have been missed by the forecasts. The satellite imagery of it shows that once it reached Bristol(ish) the cloud top expanded into a roughly circular patch covering a lot of south east England. It's the sort of event of which organisations much prefer to have advanced warning, perhaps the paid-for forecasts provided to and paid for by the likes of the railway included it.
The Met Office high resolution model UKV did show some potential for thunderstorms but the global models didn't have a sniff of them. Models specifically designed for thunderstorm potential also did reasonably well although those in the South East ended up a bit further north.
Re: Thunderstorms in the West Country - May and June 2026 - ongoing
In "Across the West" [376338/32078/26]
Posted by JohnM at 08:49, 23rd June 2026
We left Melksham for Downend (Bristol) yesterday evening at about 6.30, during the storm. It was chucking it down, with loads of water on the roads, and a small lake on the A4 just before the Bathford/Batheaston roundabout. There was a long queue coming the other way on the dual carriageway; there might have been something blocking the A363 down to Bradford as well.
Coming back just after 10.00 it was all clear.
In "Across the West" [376337/32078/26]
Posted by Mark A at 08:35, 23rd June 2026
Overview from Bath from last night is that there were a lot of instances of flash flooding, often in places you'd not expect to see it - in the roads and roundabout at the top of Wellsway wouldn't be the first place that would come to mind as susceptible, and downhill roads then vulnerable to water flows, and where it was already damaged, removing the road surface. Also, instances of water escaping from overstretched drainage and then bursting road surfaces from beneath, and flooding of properties from the flash flooding on the roads and from roof drainage that blocked. Not a good evening to have a valley gutter. Fallen trees too including one that injured someone. I've not been out and about but I expect there's a lot of clearing up to be done. If the railways escaped then so much the better, this unforecasted event probed vulnerabilities and found more than a few.
In "Shorter journeys in Plymouth and Cornwall" [376336/28556/25]
Posted by Mark A at 08:25, 23rd June 2026
Already liked by Andy
In "The Wider Picture in the United Kingdom" [376335/31355/51]
Posted by JohnM at 08:17, 23rd June 2026
National Rail 'incident' https://www.nationalrail.co.uk/service-disruptions/hot-weather-20260617/
Hot weather is forecast in England and Wales until at least Saturday 27 June; please only travel if absolutely necessary on 24 and 25 June
Re: Frome station - facilities, services, improvements, events and incidents - merged posts
In "Heart of Wessex" [376334/247/19]
Posted by rogerpatenall at 08:16, 23rd June 2026
Already liked by Witham Bobby
Running non-stop between Castle Cary and Bruton? That will be a special treat for the memory bank.
In "Across the West" [376333/31163/26]
Posted by TaplowGreen at 08:14, 23rd June 2026
Elizabeth Line has fallen over due to a points failure - so that options now gone for those travelling from Twyford/Maidenhead/Slough etc this morning if they wish to get to London.
No service between Heathrow Terminals 2&3 and Heathrow Terminal 4 due to flooding caused by heavy rain and SEVERE DELAYS on the rest of the line due to a points failure at Southall. Tickets are being accepted on London Underground via any reasonable route.
Update
Between London Paddington and Heathrow Terminals / Reading
Severe weather at Heathrow Terminal 4 means that all lines are blocked to / from this station. As a result, trains running to / from Heathrow Terminals may be cancelled, delayed or revised.
Lines have now reopened following an earlier points failure at Southall. Trains running between London Paddington and Reading may continue to be cancelled, delayed by up to to 25 minutes or revised.
In "The Wider Picture in the United Kingdom" [376332/31355/51]
Posted by ray951 at 08:03, 23rd June 2026
West Somerset Railway the same. All services cancelled 23rd-25th inclusive.
https://www.wsfp.co.uk/news/record-forecasted-temperatures-see-west-somerset-railway-halt-trains-for-three-days-919570
Surely they could run diesel services, if steam is considered too much of a fire risk .
Diesel's suffer in very hot weather, in BR days it was not uncommon for many of what are now heritage would fail in service, BR often took rad louvers off of some classes of locos.
Also I sure the GWSR were considering the volunteers who would have to work in the extreme heat.
During the recent steam gala at the GWSR a volunteer collapsed due to heat stroke, and the whole timetable had to be recast to allow for breaks and to ensure that there were no delays causing trains to be stationary for long periods of time in the sun.
In "Shorter journeys in Plymouth and Cornwall" [376331/28556/25]
Posted by John D at 07:53, 23rd June 2026
Re: How would YOU solve CrossCountry ?
In "Across the West" [376330/32138/26]
Posted by grahame at 07:32, 23rd June 2026
If I had a spare day or two (spoiler: I don't) I'd be very tempted to take the Origin/Destination Matrix data and map it onto CrossCountry route patterns.
In other words, of the journeys starting in (say) Reading, how many are heading for a destination that is best served by a CrossCountry service across Birmingham? I genuinely don't know the answer - I'm intrigued to see that there are more Reading–Banbury passengers than Reading–Manchester Piccadilly, for example, but then when you add Stockport…
I suspect you could get some interesting answers simply by matching up origins/destinations within certain polygons (e.g. the North-West to the South-West).
The ticket sales data is interesting - it tells a story of where people have travelled and not what the potential for travel is were it to be easier.    We have a Complete matrix for Reading in the Coffee Shop - showing 2400 different sources/destinations for tickets sold.
It is instructive to look at the history and see changing patterns with the arrival of the Elizabeth line - ticket sales to place like Stratford.    And, yes, re-analysing (I don't have the spare time either) the data in zones is interesting; I have in the past done that to look at Swindon / Chippenham to the Solent area ...
In "Across the West" [376329/31163/26]
Posted by TaplowGreen at 07:07, 23rd June 2026
In "Across the West" [376328/32138/26]
Posted by lbraine at 06:53, 23rd June 2026
I wish I had the spare time - and know how - to do such an analysis as I think it would be very revealing.
I understand the distaste for having to ‘make a connection’ when going by train (or any public transports for that matter) especially when the connection is not guaranteed - long gone are those days. And this maybe doubly so for the business traveller trying to maximise the company value from the time and expense, and minimise the impact of travelling on their personal lives.
But I think this raises the issue of what market is CC trying to serve. Is it a business market or is leisure market service ? If the former, then it’s more likely that the destination station (or the city business district it serves) is the actual final destination. But if its leisure it maybe more likely that the final destination is further afield than a city business district, and most likely necessitating a change of transport (mode) anyway ?
And, if the latter is valid, then surely an efficient inter-regional service running between regional ‘hubs’ would work well?
My own personal experience - admittedly limited to the south of Birmingham portion of the network - and based on the copious amounts of luggage seen being manhandled into every nock and cranny - I would argue CC is a leisure market service. Yes - I am sure there are folks reliant on the CC service to get to work every day - but this has to be a smaller number of people than those trying to get to or back from non-work related activities ? Otherwise why run a Reading to Manchester service - for example - that can’t be a commuter/business  service surely ?
In "The Wider Picture in the United Kingdom" [376327/31355/51]
Posted by Electric train at 06:41, 23rd June 2026
In "Shorter journeys in Plymouth and Cornwall" [376326/28556/25]
Posted by TaplowGreen at 06:38, 23rd June 2026
In "The Wider Picture in the United Kingdom" [376322/31355/51]
Posted by Mark A at 22:36, 22nd June 2026
Crumbs, just found that that storm knocked out Bristol airport.
[Edit] Back in operation this morning. The airport's web site: it lacks a 'Service status' page, difficult to tell that passengers scheduled to arrive yesterday evening may still be travelling from diversion airports or will not have yet left their origin points.
Re: Cancellations to services between Bournemouth & Southampton Central - ongoing incidents
In "South Western services" [376321/30445/42]
Posted by John D at 21:50, 22nd June 2026
Brockenhurst signalling problems have been on and for a week now, also a common occurrence over the past year or two. Any one know if it is just age of cables etc?
Brockenhurst signalling is from October 1978, when a small panel was installed in the newer signal box by the level crossing, and Brockenhurst B and Lymington Junction all closed.   The area had retained semaphores for 11-12 years after electrification.
Lymington Junction box was demolished within hours as it was in path of part of new dedicated branch track from station.
So yes, likely some cables are 48 years old
In "Across the West" [376320/32138/26]
Posted by Richard Fairhurst at 21:47, 22nd June 2026
In "The Wider Picture in the United Kingdom" [376319/31355/51]
Posted by Mark A at 21:25, 22nd June 2026
In "South Western services" [376318/30445/42]
Posted by Chris from Nailsea at 21:22, 22nd June 2026
Done that for you.
In "The Wider Picture in the United Kingdom" [376317/31355/51]
Posted by MVR S&T at 21:14, 22nd June 2026
Already liked by Mark A, PrestburyRoad
High temperatures play havoc with mechanical signalling, such as the point rods expanding, making points and FPLs fail, also signal pull wires, there is adjusters on the long pull signals, but only so much. rails expand over points and causes track circuit failures. And of course staff in various offices, they may have a coal fire...
In "TransWilts line - Swindon, Chippenham, Melksham, Trowbridge, Westbury, Salisbury" [376316/31359/18]
Posted by bobm at 21:10, 22nd June 2026
Both these ran in the end albeit with a delay of 25 minutes on the 18:37.
They, like most of the TransWilts services today, were operated by 158748 which was running with the windows open after the air cooling/conditioning failed.   I suspect it was not alone.
In "The Wider Picture in the United Kingdom" [376315/31355/51]
Posted by Chris from Nailsea at 21:08, 22nd June 2026
Thank you!
In "The Wider Picture in the United Kingdom" [376314/31355/51]
Posted by Oxonhutch at 20:59, 22nd June 2026
They're all going to sweat it out.
So the steam engines haven't been fired?
In "South Western services" [376313/30445/42]
Posted by MVR S&T at 20:57, 22nd June 2026
Just rename to 'from 11/07/xx' perhaps, as there may be more to come!
In "South Western services" [376312/30445/42]
Posted by Chris from Nailsea at 20:51, 22nd June 2026
Can a mod re name or move this please.
I can certainly do both - but to what, and to where?
