| Re: Ryanair - routes, schedules, incidents and issues (merged posts) In "The Wider Picture in the United Kingdom" [378277/29076/51] Posted by Chris from Nailsea at 00:48, 15th August 2026 | ![]() |
Ryanair.
Enough said.
| Kings Lynn - Ely Track circuit failure 14th August 2026 In "The Wider Picture in the United Kingdom" [378276/32368/51] Posted by Trowres at 23:32, 14th August 2026 | ![]() |
The following headline appeared on National Rail at 14:22:
No trains between Ely and Kings Lynn until the end of the day
However at 19:38:
Trains are returning to normal following an earlier fault with the signalling system between Ely and Kings Lynn.
As services recover, trains may still be cancelled or revised.
Customer advice:
Trains can now run between Ely and Kings Lynn again. You can now travel on your booked route.
Customer advice:
First southbound train from Kings Lynn was about 21:40 - using a headcode not recognised by RTT.
First northbound arrival was from Kings Cross; scheduled at 20:12 but actually arriving at 22:01.
I have no idea what info was available on the trains or stations. Great Northern doesn't seem to do individual train reporting on its own equivalent to Journeycheck, but their live departures and arrivals seemed to alternate between showing trains and a "no trains found" sort of message.
Edit to add this excerpt from the supporting text of the incident:
your journey may take up to at least 45 minutes longer than usual
| Re: Derailment, Lewes, 13 Aug 2026 In "The Wider Picture in the United Kingdom" [378275/32362/51] Posted by Trowres at 23:09, 14th August 2026 | ![]() |
The fault seems to affect only the eastbound line between Polegate and Hampden Park?
An excursion returning to Derby from Eastbourne traversed the westbound track at about 17:35; seemingly, the only train to run on this line for quite some time.
| Re: Air conditioning on trains - apparently excessive sometimes - if working at all? In "Introductions and chat" [378274/32367/1] Posted by eightonedee at 22:07, 14th August 2026 | ![]() |
I've had to move seats on a double-deck train in the Netherlands due to the frigid wind concentrated on my original location.
If it's one of the type with a rounded roof, so that those on the upper deck sit (effectively) under a glass dome. I have roasted there on a sunny but cold day in February when there was still some snow on the ground outside. They must be a nightmare to cool effectively inside in the kind of weather we are currently experiencing.
| Re: Air conditioning on trains - apparently excessive sometimes - if working at all? In "Introductions and chat" [378273/32367/1] Posted by Chris from Nailsea at 21:32, 14th August 2026 | ![]() |
... due to the frigid wind concentrated on my original location.
Your GP may be able to prescribe something to help with that, Trowres.
| Re: Derailment, Lewes, 13 Aug 2026 In "The Wider Picture in the United Kingdom" [378272/32362/51] Posted by grahame at 21:30, 14th August 2026 | ![]() |
https://www.nationalrail.co.uk/service-disruptions/polegate-20260814/
A safety inspection of the track between Lewes and Eastbourne means that all lines are closed.
As a result, trains are unable to operate between these stations.
This is expected until the end of the day.
Customer advice:
No trains can run between Lewes and Eastbourne until further notice. You will need to use an alternative route to reach your destination.
You should allow at least an additional 60 minutes to complete your journey today.
Please talk to station staff, look at the information boards or check your journey planner for the most recent information.
How are Southern changing their service?
While this disruption is ongoing, Southern will be making the following changes to services:
Trains that normally run between Ore and Brighton will now run between Ore and Eastbourne.
Trains that normally run between Eastbourne and Brighton will now terminate at Polegate and restart back to Brighton.
Customer advice:
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 In "Across the West" [378271/31163/26] Posted by Marlburian at 21:09, 14th August 2026 | ![]() |
From National Rail - Elizabeth Line suspended between Paddington-Heathrow-Reading (again)
Elizabeth line between Abbey Wood and Heathrow Terminal 4 / Reading, and also between Shenfield and Heathrow Terminal 5
Great Western Railway between London Paddington and Didcot Parkway
Heathrow Express between London Paddington and Heathrow Airport
A failure of the electricity supply between London Paddington and Heathrow Airport / Reading means some lines are blocked. As a result, trains may be cancelled, delayed by up to 30 minutes or revised.
Disruption is expected until 16:00.
This afternoon I took a friend down to Tilehurst Station to catch the 1526 to Paddington and found a CrossCountry service with very few passengers on board blocking the line serving Platform 4. There were 25 or so people on the platform itself - four times as many as I would normally expect to see at that time of day - I did vaguely wonder if they had got off the CrossCountry for some reason, but I couldn't think of one (the preceding 1455 had departed at 1512). The CrossCountry finally departed, with the 1526 coming in around 1535 and leaving at 1542.
My friend usually wonders whether or not to stay on the semi-fast service to Paddington. Today she decided to, but ironically it terminated at Reading and she had to squeeze on to a crowded fast train.
| Re: Air conditioning on trains - apparently excessive sometimes - if working at all? In "Introductions and chat" [378270/32367/1] Posted by Trowres at 20:59, 14th August 2026 | ![]() |
Bearing in mind that people (well, most) dress for the weather, it would make sense for the interior temperature of the train to partially track the outside temperature - so that it's (say) 21C much of the year, but 25C when outside is 30C.
Apart from being more comfortable, it would also reduce energy consumption and wear on the A/C system.
A related issue is the diffusion (or not) of the cooled air supplied to the passenger saloon. I've had to move seats on a double-deck train in the Netherlands due to the frigid wind concentrated on my original location.
| Re: Imber Bus Day - merged topics, ongoing events and discussion here In "Buses and other ways to travel" [378269/17260/5] Posted by TaplowGreen at 20:44, 14th August 2026 | ![]() |
One can only hope that there are no crew shortages, and that there are not more buses than usual requiring repairs at the same time.
It's rather reminiscent of the 'Portishead Line reopening for passengers', which has been 'just three years away' - for the past 30 years.
| Air conditioning on trains - apparently excessive sometimes - if working at all? In "Introductions and chat" [378267/32367/1] Posted by Chris from Nailsea at 19:45, 14th August 2026 | ![]() |
I am posting here on behalf of SWMBO, who travelled by train from Exeter back to home in Nailsea this afternoon, on something like the second hottest day of the year yet recorded.
Apparently, the train's air conditioning was working - so much so that several other passengers complained to the train manager that it was 'too cold'. He ruefully explained to them that he couldn't moderate it: the air conditioning was either 'on' or 'off'.
I have no way of verifying the veracity of this anecdotal experience, but it did amuze me.
| Re: New station at North Filton - now named as 'Bristol Brabazon' - ongoing discussion In "Bristol and Bath (WECA, now WEMCA)" [378266/24927/21] Posted by XPT at 19:19, 14th August 2026 | ![]() |
Wonder when this station will actually open. Hope we get news of an actual definite opening date sometime soon. So far we've been given an update of sometime in the autumn. Autumn ends on 30th November. On Realtimetrains it's showing the new Bristol Temple Meads-Bristol Brabazon services starting on Sunday 13th December with the 0908 service to Bristol Brabazon. That's the date when the new winter timetable starts. Hopefully the station and the new services actually ends up starting a bit before then.
| Re: Imber Bus Day - merged topics, ongoing events and discussion here In "Buses and other ways to travel" [378265/17260/5] Posted by Chris from Nailsea at 19:08, 14th August 2026 | ![]() |
Will there be any dinosaur fridge magnets available?
| Re: Imber Bus Day - merged topics, ongoing events and discussion here In "Buses and other ways to travel" [378264/17260/5] Posted by grahame at 19:01, 14th August 2026 Already liked by Mark A | ![]() |
If you are bringing younger family members and / or partners tomorrow:
Warminster has become Roarminster, with a dinosaur takeover.
Warminster Town Council and the Warminster Business Network (WBN) has created a fun dinosaur trail, transforming the town with six dinosaur models installed at five locations until Saturday 5th September.
Visitors and residents will be encouraged to explore the town, find and learn about the different dinosaurs, enter a prize draw and take part in fun activities with a full programme of dinosaur events planned throughout the summer holidays.
| Two people dead after light aircraft crash - Gwynedd, 14 August 2026 In "The Wider Picture in the United Kingdom" [378263/32366/51] Posted by Chris from Nailsea at 18:59, 14th August 2026 | ![]() |
Two people have died following a light aircraft crash in north Wales.
The aircraft was found in a remote location close to Trawsfynydd, near Porthmadog, Gwynedd, with the two people on board pronounced dead at the scene, North Wales Police said.
The force received reports shortly after 12:00 BST that a light aircraft travelling from an airfield in England had not arrived at Caernarfon Airport as scheduled.
Multi-agency air and ground searches were carried out until the aircraft was found.
A team of investigators have since been deployed by the Air Accidents Investigations Branch (AAIB).
Ch Supt Owain Llewellyn said it has been a "challenging search operation".
"Our thoughts are with the families and friends of those involved in this tragic incident," he said.
He added that his force would support the AAIB in its investigation to "ensure the circumstances leading to this incident are fully understood".
He added: "I am grateful to all of the agencies involved for their professionalism and dedication."
| Re: Derailment, Wickford,14th August 2026 In "The Wider Picture in the United Kingdom" [378262/32365/51] Posted by Chris from Nailsea at 18:50, 14th August 2026 | ![]() |
From the BBC live:
'The train swung wildly,' says passenger on board derailed service in Essex
Summary
A passenger on board a derailed train in Essex tells the BBC it "swung wildly for about 10 seconds"
Emergency services are responding at the scene after a London-bound train carrying up to 45 passengers partially came off the tracks in Wickford - what we know so far
British Transport Police says "the rear carriages of a train derailed in an upright position" at 14:12 BST, adding there are no reported injuries - its statement in full
National Rail says major disruption is expected "until further notice"
It comes a day after a separate train derailment in Lewes, Sussex - the cause of that incident is still being investigated
Responding to the derailment, the Department for Transport says Britain's railways are "amongst the safest in the world"
Summary
| Re: Derailment, Wickford,14th August 2026 In "The Wider Picture in the United Kingdom" [378261/32365/51] Posted by stuving at 18:35, 14th August 2026 | ![]() |
Also one at Clapham this morning.......perhaps these things come in threes?
But there was also a derailment on the Volks Electric Railway yesterday ...
(currently at https://x.com/imjustbrighton_)
| Re: Derailment, Wickford,14th August 2026 In "The Wider Picture in the United Kingdom" [378260/32365/51] Posted by TaplowGreen at 18:22, 14th August 2026 | ![]() |
| Re: To the Furthest Corner of Europe - By Interrail In "The Wider Picture Overseas" [378259/32319/52] Posted by Chris from Nailsea at 17:40, 14th August 2026 Already liked by eXPassenger, eightonedee | ![]() |
WSW Frome,
May I thank you, on behalf of all our Coffee Shop forum members, for your detailed, informative and authoritative posts in this topic.
| To the Furthest Corner of Europe - By Interrail In "The Wider Picture Overseas" [378258/32319/52] Posted by WSW Frome at 17:04, 14th August 2026 Already liked by eightonedee, Oxonhutch | ![]() |
For anyone contemplating the rail trip to Istanbul, it can be accomplished (avoiding Sofia) from London or Northern France in minimum 4 days with 3 overnight trains and 1 hotel night in Bucharest. There are various route options for the northern parts which may extend the itinerary. To get such a precise itinerary may require some quite advance bookings in the more peak seasons. However, it does make sense to go more slowly and take in the atmosphere along the way.
Interrail – I selected without too much thought 7 days in 1 month, first class. At the Senior Rate and in the December sale this works out at around £45 pd. Seems astonishing value. Whilst I had originally thought about going further into Turkey, I decided against at least partly because the scenic journeys get block booked by travel agents.
When I planned the Istanbul trip in detail it started to become clear that I really only needed Interrail for Travel Day 1 (and?2). Fares in Eastern Europe are cheap and services may be only second class. So paying outright may be beneficial. See my comments about reservations above and planning well ahead may overcome that problem. So to consume extra days I took a return trip from Copenhagen to Stockholm. The full fare for that seems to have been around £400 so I did get my monies worth on that alone. (Original plan was to return to UK by rail but fully booked became a problem. Separately - Eurostar from Amsterdam seems to have an additional Interrail allocation than from Brussels even on the same train.) It was at this point dawn lifted and I recalled that the 7 days were within the month and not the 11 months of the full pass!! So, a swifter departure for Istanbul. I used 3 days in Scandinavia, 1 trivial domestic trip to PMH (1st class SAL to SOU mind), and 2 days towards Istanbul.
The main Interrail advice points (if planning a specific point to point journey – pref. well ahead) are:
1. Do you need First class? Not an expensive upgrade and may be necessary for single occupation sleepers. Overnight trips only count as one day.
2. How many days do you actually need? Constructing a trip from individual tickets might prove cheaper although less flexible. Advance fares are available in some countries which reduces the cost further. All the operators I used have internet booking platforms – some will not permit online reservation only.
3. Do make use of the Interrail sales, typically held 3 or 4 times per year. Maximum discount of 25% is usual in December. Various periods available. Overall Pass is valid for 11 months but typically must be used within the 1 or 2 months specified.
I had entitled this thread “To the Furthest Corner of Europe - By Interrail.” Now we Westerners do tend to think of Istanbul as the southeast corner of Europe. This is wildly incorrect so that the thread title is also misleading. The geographic definitions of Europe are variable, but the extremities certainly lie much further east. The most established definitions usually involve the Caucasus Mountains and the River Ural. So which cities lie on the NE and SE corners? The common answers are the Russian cities of Salekhard (on the Arctic Circle, east of Vorkuta – famed for its gulags!) and Derbent (at the end of the Caucasus range and on the Caspian Sea western shore).
So if in a calmer future anyone wishes to travel by rail to these extremities, both locations have regular passenger services from Moscow. Salekhard is served from Labytnangi Station (on the other side of the River Ob). Derbent would also have been served by the Baku to Moscow service, but Azerbaijan has largely closed its land borders since Covid. Azerbaijan has only recently resumed the Tbilisi (Georgia) to Baku train service but only for those who need no visa. Again, in the sometime future it will be possible to travel by rail from Turkey through to Baku using the new link to Georgia currently under construction.
As it happens I have visited both the wider regions mentioned above in my previous professional work, but never these actual locations and always travelling by air, sometimes in quite “interesting” aircraft and helicopters.
So this can be a bucket list adventure for some influencer in future. I doubt Interrail ever covered the Soviet Union but who knows about the future. EU and many other European countries are members of Interrail currently. Seemingly citizens of EU countries with no rail network are not eligible to buy Interrail tickets!
That is the conclusion of Chapter 5 and the end of the saga. I planned to add two photos (non-rail) to prove I got there but I do not know how. Enjoy the read.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 In "Across the West" [378257/31163/26] Posted by TaplowGreen at 17:02, 14th August 2026 | ![]() |
Huge fire next to Slough Station, Windsor line is closed and it sounds as if Slough Station may be closing soon, message is stay away.
Looks like it was brought under control before it caused thousands of pounds worth of improvements.
Ironically it's being reported that it was the Network Rail depot.
I have e-mailed a link to that post to Andy Burnham MP, Heidi Alexander MP and Peter, Baron Hendy of Richmond Hill.
Let's see where that gets us.
| Re: Derailment, Wickford,14th August 2026 In "The Wider Picture in the United Kingdom" [378255/32365/51] Posted by IndustryInsider at 16:41, 14th August 2026 Already liked by Mark A | ![]() |
Minor derailment apparently. Train has stayed upright.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 In "Across the West" [378254/31163/26] Posted by TaplowGreen at 15:37, 14th August 2026 | ![]() |
| Derailment, Wickford,14th August 2026 In "The Wider Picture in the United Kingdom" [378253/32365/51] Posted by grahame at 15:33, 14th August 2026 | ![]() |
BBC Live feed
Train derails near Wickford in Essex
published at 15:11
15:11
BREAKING
A Greater Anglia train has derailed near Wickford in Essex, the BBC understands.
We'll bring you more as we get it.
published at 15:11
15:11
BREAKING
Train has derailed, Network Rail confirms
published at 15:30
15:30
BREAKING
Network Rail has just confirmed to us that a train has derailed.
"We are dealing with a derailment incident in Anglia, [region] and we are working quickly to understand the situation and to provide assistance where needed," a spokesperson says.
"We will provide further information in due course.”
published at 15:30
15:30
BREAKING
| Re: Friday 28th February 2020 - Greta Thunberg in Bristol. In "Looking forward - the next 2, 5, 10 and 20 years" [378252/22947/40] Posted by TaplowGreen at 14:24, 14th August 2026 | ![]() |
My how she's changed!
| Re: The Adelante fleet - what if they had remained in the South West? In "Across the West" [378251/32364/26] Posted by Richard Fairhurst at 13:59, 14th August 2026 Already liked by rogerw | ![]() |
Given the Adelantes' propensity to self-combust, I suspect in this weather, the answer to "where would we/they be today" is "firmly locked inside the depot"...
But despite their well publicised troubles, Old Oak Common did a remarkable job of getting them to behave. I wonder whether the introduction of the 175s might have been a bit smoother if a team of engineers with experience on their sister units was still on hand.
| Re: Derailment, Lewes, 13 Aug 2026 In "The Wider Picture in the United Kingdom" [378250/32362/51] Posted by ChrisB at 13:40, 14th August 2026 | ![]() |
He was only allowed around 60 seconds to grab that footage before the Police enforced a no-fly zone.
| Re: Six-hour train services between London and Stirling running with no toilets In "The Wider Picture in the United Kingdom" [378249/32334/51] Posted by Western Pathfinder at 13:36, 14th August 2026 | ![]() |
It would seem that the toilets were not involved in any of the refurbishment works carried out!..
| Re: Six-hour train services between London and Stirling running with no toilets In "The Wider Picture in the United Kingdom" [378248/32334/51] Posted by ChrisB at 13:36, 14th August 2026 | ![]() |
It does not appear to have been made clear that Lumo have stated categorically that none of their Stirling trains enter service without at least some working WC's and the issue seems to be one of 'mid-journey' failure.
And that's rubbish anyway! Their early morning 0615? to Stirling left London with NO working toilets the other day - Lumo even tweeted the news themselves & indicated extra-long toilet stops were going to happen.
