Re: Historic black and white pictures - where were they taken? - 3.12.2025
In "The Lighter Side" [368978/31189/30]
Posted by grahame at 08:08, 5th December 2025
As promised (or threatened) here are my sources
https://www.facebook.com/photo?fbid=25624144567183377&set=gm.2641251962902897&idorvanity=711170475911065 - Sudbury Road and Harrow
https://www.facebook.com/groups/177808113032034/posts/2013784489434378/ - Leek - this one not identified by members
https://www.facebook.com/photo/?fbid=2919589211574696&set=gm.26196769553244142&idorvanity=1390742637606844 - Hunstanton
https://www.facebook.com/photo/?fbid=1307583721403990&set=a.602528495242853 - Denton
https://www.facebook.com/photo/?fbid=122163702326605836&set=gm.1930569121674440&idorvanity=440570830674284 - Crainlarich
https://www.facebook.com/photo/?fbid=10241723147399923&set=pcb.2013570269455800 - Masbury
https://www.facebook.com/groups/1730959503584733/?multi_permalinks=33823163800604220&hoisted_section_header_type=recently_seen - Melrose
https://www.facebook.com/photo/?fbid=2610935075926555&set=gm.33830088169911783&idorvanity=1730959503584733 - St Lawrence, Ramsgate
https://www.facebook.com/groups/410016829130481/?multi_permalinks=3386880974777370&hoisted_section_header_type=recently_seen - Mission, British Columbia
http://www.savethetrain.org.uk/melksham-goods-yard-undated.jpg - Melksham
Re: AQ - 5.12.25 - A year in the life
In "The Lighter Side" [368977/31211/30]
Posted by bradshaw at 08:08, 5th December 2025
1 Chetnole, month possibly May as the hawthorn is flowering
In "The Lighter Side" [368976/31211/30]
Posted by grahame at 07:53, 5th December 2025
Here are a dozen pictures I've taken this year - one in each month of the year.  Can you place them, and work out which month they were taken in?
1
2
3
4
5
6
7
8
9
10
11
12
Re: Cars getting bigger - is this a concern?
In "Buses and other ways to travel" [368975/31190/5]
Posted by CyclingSid at 07:49, 5th December 2025
Having been out on the bike early this frosty morning, I am reminded that most SUV drivers can't reach the whole of their windscreen to scrape the ice off. Reply on commenting on this to a member of the ambulance service, you don't have to tell us about this, unfortunately.
Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025
In "TransWilts line" [368974/29726/18]
Posted by grahame at 07:18, 5th December 2025
05:11 Gloucester to Southampton Central due 08:09
Facilities on the 05:11 Gloucester to Southampton Central due 08:09.
Toilet facilities are reduced.
Additional Facilities Information
No accessible toilet available.
In "TransWilts line" [368973/29726/18]
Posted by TaplowGreen at 06:25, 5th December 2025
14:18 Westbury to Swindon due 15:00
14:18 Westbury to Swindon due 15:00 will be cancelled.
This is due to a shortage of train crew
15:15 Swindon to Westbury due 15:59
15:15 Swindon to Westbury due 15:59 will be cancelled.
Re: AQ - Which is next in the sequence?
In "The Lighter Side" [368972/31198/30]
Posted by grahame at 23:35, 4th December 2025
5 is not the Route numbers but the stands they leave from in the bus station  U, V, W and X  so the next is Y from where the No 9 goes to Wroughton.
That's the sequence I found, but stop Y was not in those maps and lists, no doubt because they were produced by Swindon Bus Company. Route 9 is a Stagecoach one, so it only appears in maps made by the council. So you need a bit of local knowledge ...
Here is the display in one of the bus stops ... and my source ... been to the boulevard a number other times already.
As regards the two companies ... I have seen it worse, but still concerned at things like 2 buses from Swindon to Marlborough 5 minutes apart then an hour to wait for the next one.  Granted one went on to Tidworth and the other via Pewsey.  Saw that same doubling up on the way back.
In "The Lighter Side" [368971/31198/30]
Posted by stuving at 23:09, 4th December 2025
In "The Lighter Side" [368970/31198/30]
Posted by grahame at 22:55, 4th December 2025
I'm thinking we should put together an "Only Connect" team ...
In "The Lighter Side" [368969/31198/30]
Posted by stuving at 22:51, 4th December 2025
1.     Southampton Airport (and TransWilts links to it)
Wow, yes, you are correct. Why
Obviously these are forum threads - or topics, in technical terms. The last one if you look at it contains a post from Graham saying "I have just noticed - we have reached a milestone - this is topic number 25,000!". So that's a basis for a sequence, isn't it? And the topic numbers are 31,000 29,000 27,000 25,000 23,000.
The post also contains this: http://www.passenger.chat/25000. That syntax does provide a way of quickly finding a topic from its number. However, I did not spot that at first, and when I did it didn't work first time (I find it's rather hit and miss). Fortunately 23,000 happened to be on the board I looked on first!
In "The Lighter Side" [368968/31198/30]
Posted by ellendune at 22:39, 4th December 2025
In "The Lighter Side" [368967/31198/30]
Posted by ellendune at 22:37, 4th December 2025
5 something to do with Swindon bus routes?
That's what I worked out too. But the sequence of four that best matches the clues has no fifth member!
Yes I have been working on that if they are routes from the bus station
  ah yes its Wroughton
In "The Lighter Side" [368966/31198/30]
Posted by Oxonhutch at 22:34, 4th December 2025
2, 14, 1, 11, x
I have heard of platform zero, but not a bus.
In "The Lighter Side" [368965/31198/30]
Posted by stuving at 22:23, 4th December 2025
Re: Lengthy train, 03/12/2025
In "London to the Cotswolds" [368964/31194/14]
Posted by jmc85 at 22:23, 4th December 2025
I was on the 1757 PAD - WOF tonight and it was showing as 18 cars on RTT, but in reality it was only a normal 9 car train (GWR were correctly showing it though)
In "The Lighter Side" [368963/31198/30]
Posted by bradshaw at 22:04, 4th December 2025
In "TransWilts line" [368962/29726/18]
Posted by grahame at 21:54, 4th December 2025
I see GWR are advertising an additional 21 services for Bath Christmas Market on Saturday.......I wonder if this will impact the Transwilts service?
So do I ...
In "Buses and other ways to travel" [368961/31190/5]
Posted by Western Pathfinder at 21:52, 4th December 2025
Already liked by grahame, johnneyw, Oxonhutch, Timmer
One of the major problems with the increase in size we find ,is the lack of ability of the drivers to cope with the size of the dam things,
Ferry officer jailed over Jersey fatal fishing boat crash - December, 2022
In "The West - but NOT trains in the West" [368960/31210/31]
Posted by Chris from Nailsea at 21:26, 4th December 2025
Lewis Carr ignored flashing collision warnings on the radars 10 minutes before the crash
A ship's officer who was in charge of a ferry involved in a fatal collision with a fishing boat has been jailed for one year and eight months.
Lewis Carr, 30, was on duty on the bridge of the Commodore Goodwill when it collided with trawler L'Ecume II west of Jersey in December 2022, killing local fishermen Michael Michieli, Larry Simyunn and Jervis Baligat.
Carr was found guilty in September of breaching Jersey's shipping law. Jurors could not reach a verdict on three charges of gross negligence manslaughter against him.
The Royal Court was told the Goodwill was running behind schedule and Carr had ignored flashing collision warnings on the radars 10 minutes before the crash.
L'Ecume II crew members Michael Michieli, Jervis Baligat and Larry Simyunn died after a collision involving their boat and Condor's Commodore Goodwill
The prosecution highlighted what they called a catalogue of failings by Carr which proved fatal.
Crown Advocate Matthew Maletroit said: "Mr Carr failed to manage and communicate properly with the look out, Arthur Sevash Zade, about the collision danger."
Mr Sevash-Zade, 35, was found not guilty of gross negligence manslaughter and the jury could not reach a verdict on the shipping law charge.
The court heard how five minutes into Mr Sevash-Zade's shift, Carr asked him if wanted to go and have breakfast.
This meant Carr was on the look out bridge alone, which went against industry standards. Mr Maletroit said: "While it was not a cause of the collision, it demonstrates safety was not Mr Carr's paramount consideration... he was willing to take risks for convenience and saving time."
Another key area of focus for the prosecution was that Carr did not properly use the technology available to him. "If Mr Carr made proper use of radar functions, he wouldn't have made error of judgement that L'Ecume II would pass the ship," Mr Maletroit added.
The prosecution also spoke about how Carr had been distracted by non-urgent tasks when radar warning of a potential collision with L'Ecume II were flashing up on screen. Mr Maletroit said: "Mr Carr should have addressed collision risks before doing other duties."
The Crown prosecution called for Carr to be sentenced to 23 months in prison for discharging his duty in a manner likely to cause "death, destruction or injury".
Defence advocate Simon Thomas argued the sentence would be too harsh. Mr Thomas said, according to international regulations, "there was some responsibility on the crew of L'Ecume II to move their vessel out of the way of the Commodore Goodwill". He added Carr trying to alter course before the collision showed it was not a case of his client "simply doing nothing to prevent the collision".
In "The Lighter Side" [368959/31198/30]
Posted by grahame at 21:17, 4th December 2025
2 is indeed 'Avenger' - Warship names
3 is Sir Robert Reid - chairs of British Railways Board
4 - CM is a good answer as would be BY or KE - first and last letters of express stops out of Paddington
5 ??
6  Cannon Street - Gravesend or Maidstone West via Lewisham and Sidcup - head codes.   My understanding is that early southern units carried a set of stencils numbed 0 to 9 to make uo 2 digit head code so that the multiples of 11 were left out until the Hastings units came along ...
7 Peter West, OBE
In "The Lighter Side" [368958/31189/30]
Posted by WSW Frome at 20:35, 4th December 2025
Following the hint above. No 2 is Masbury. I think the layout of the buildings is quite characteristic even today. Date is pure guess but likely 1950's and the picture looks like a postcard perhaps illustrating the S & D summit!
Re: Passengers locked inside Hartlepool station
In "The Wider Picture in the United Kingdom" [368957/31200/51]
Posted by Chris from Nailsea at 18:39, 4th December 2025
To be fair, it wasn't the train crew who caused the problem: that was due to a security guard from a third-party contractor who locked up without checking the last train had arrived.
I suspect Northern will be having some stern words with their third party contractor.
In "TransWilts line" [368956/29726/18]
Posted by TaplowGreen at 18:12, 4th December 2025
In "The Wider Picture in the United Kingdom" [368955/31200/51]
Posted by TaplowGreen at 18:07, 4th December 2025
Yes, commendable actions from the train crew.
Always good to be able to pluck a diamond from a turd!
In "The Lighter Side" [368954/31198/30]
Posted by stuving at 17:57, 4th December 2025
In "The Lighter Side" [368953/31198/30]
Posted by bradshaw at 17:41, 4th December 2025
11, 22, 33, 44 so next is 55 (Cannon Street - Gravesend or Maidstone West via Lewisham and Sidcup)
1981
Plane crashed at Staverton in Gloucestershire after 3D-printed part collapsed
In "The West - but NOT trains in the West" [368952/31209/31]
Posted by Chris from Nailsea at 17:40, 4th December 2025
The sole crew member sustained minor injuries in the crash, which destroyed the light aircraft
A plane crashed after a 3D-printed part softened and collapsed, causing its engine to lose power, a report has found.
The Cozy Mk IV light aircraft was destroyed after its plastic air induction elbow, bought at an air show in North America, collapsed.
The aircraft crashed into a landing aid system at Gloucestershire Airport in Staverton on 18 March at 13:04 GMT, after its engine lost power. The sole occupant was taken to hospital with minor injuries.
The Air Accidents Investigation Branch (AAIB) said in a report that the induction elbow was made of "inappropriate material" and safety actions will be taken in future regarding 3D printed parts.
The part, which was 3D-printed, softened and collapsed
Following an "uneventful local flight", the AAIB report said the pilot advanced the throttle on the final approach to the runway, and realised the engine had suffered a complete loss of power.
"He managed to fly over a road and a line of bushes on the airfield boundary, but landed short and struck the instrument landing system before coming to rest at the side of the structure," the report read. It was revealed the part had been installed during a modification to the fuel system and collapsed due to its 3D-printed plastic material softening when exposed to heat from the engine.
The Light Aircraft Association (LAA) said it now intends to take safety actions in response to the accident, including a "LAA Alert" regarding the use of 3D-printed parts that will be sent to inspectors.
Gales to cause Friday Isle of Man ferry passenger disruption - December 2025
In "Buses and other ways to travel" [368951/31208/5]
Posted by Chris from Nailsea at 17:18, 4th December 2025
Two of Friday's planned sailing by flagship vessel the Manxman have been cancelled
Gales over the Irish Sea have led to disruption for ferry passengers due to travel between the Isle of Man and Lancashire on Friday.
The Isle of Man Steam Packet Company said, due to the expected adverse conditions, the Manxman's 14:30 GMT crossing from Heysham to Douglas had been cancelled.
The flagship vessel's evening return to the Lancashire port, scheduled to at depart 20:30, had also been called, the firm said.
Ronaldsway Met Office said gusts of up to 50mph (80km/h) were expected to hit the island on Friday afternoon.
The Steam Packet said passengers booked to travel on the affected sailings could amend their tickets online or by contacting the reservations desk.
Saturday's scheduled crossings, including the 03:00 sailing from Heysham to Douglas, are expected to depart as scheduled.
Re: ORR station usage data
In "Across the West" [368950/31203/26]
Posted by bobm at 17:11, 4th December 2025
Thanks - I had that heading too - but the data on the actual spreadsheet was headed last year.   It has updated in the last hour.
In "The Lighter Side" [368949/31198/30]
Posted by grahame at 16:33, 4th December 2025
Just 1. and 5. to go ... and 6 to finish off.
