Rail trail proposals in Gloucestershire
6.8.2025 (Wednesday) 16:12 - All running AOK
Posted by Richard Fairhurst at 11:57, 11th June 2025
Two interesting current proposals for cycle routes/greenways on former GWR lines in Gloucestershire.
The first is for a greenway from Kingham to Bourton-on-the-Water along the former Banbury & Cheltenham Direct Railway. Sustrans has done a series of studies and there's a very brief summary here: https://www.cotswold.gov.uk/media/jsqoexxc/sustrans-kingham-to-bourton-on-the-water-greenway-design-summary.pdf
The second is along the former branch line from Kemble to Cirencester. Designs are being taken forward in two stages, one from Kemble to a new estate on the edge of Cirencester, the other from there into the town centre. Both have received funding for design work: https://meetings.cotswold.gov.uk/mgConvert2PDF.aspx?ID=10855
Still some way off construction but interesting projects nonetheless.
Re: Rail trail proposals in Gloucestershire
Posted by grahame at 18:08, 11th June 2025
Interesting indeed - what does this do for very light rail proposals from Kemble to Cirencester?
Posted by johnneyw at 18:30, 11th June 2025
Is there room for both if the VLR is a single track shuttle service or with a passing loop?
Posted by Chris from Nailsea at 19:35, 11th June 2025
I don't think so.
I am a great fan of the historic Kemble to Cirencester Line, but we have to be practical.  That line was, probably, never really financially viable as a railway, and particularly towards the Cirencester end, the trackbed has been chopped and changed.
However, I can see the possibilities for a 'green way' cycle and footpath.  Several overbridges would have to be replaced, and a load of vegetation would have to be pruned - but that could be done.
Posted by Richard Fairhurst at 10:16, 12th June 2025
The new estate will be about 3 miles from Kemble so absolutely prime territory for cycling. But I wonder if the Coventry VLR trials will tip the balance in future (insert usual gadgetbahn disclaimer here).
Posted by Red Squirrel at 15:10, 12th June 2025
Kemble is the railhead for Cirencester and Tetbury, and (without researching this) I’d bet a fiver that part of the justification for closing both lines was that a bus could do the job. But the 882 - which looks like the modern incarnation of that substitute bus - does not integrate with the hourly train service at Kemble, so an onward connection is hit-and-miss.
So before committing to any kind of rail-based connection to Kemble, maybe it would be good to market a bus service from Tetbury to Cirencester via Kemble which connected to the trains, similar to the Bodmin and Okehampton services?
