Re: Class 175s to Great Western Railway (GWR)
Posted by Bob_Blakey at 14:16, 17th March 2026
Out on the bike this morning passed 175002, immediately north of Starcross, exhibiting an impressive turn of speed. As above running to time on the 2C20 EXD > PNZ.
Posted by a-driver at 05:27, 16th March 2026
There is intention to add another 175 in to passenger service from 16 March to run Plymouth - Penzance - Exeter St Davids - Penzance - Plymouth as there are now 6 serviceable sets that can run in passenger service.  However 175006 broke down again today with a bogie fault and 5Z13 training run was cancelled as a result.
ETA, the diagram will be
2C00 05.33 Plymouth - Penzance
2E06 07.45 Penzance - Exeter St Davids
2C20 11.27 Exeter St Davids - Penzance
2P20 1515 Penzance - Plymouth
175002 on it this morning.
Posted by plymothian at 09:52, 10th March 2026
Posted by Pb_devon at 08:25, 4th March 2026
Long article in the latest Rail magazine 1056 of an interview with GWR Programme Director Barry Milsom about the 175 delays.
In summary, outside storage for years has caused damage requiring repair, plus other issues.
Posted by bobm at 15:48, 27th February 2026
Same with the 10:56 from Chippenham to London Paddington this morning.  Journeycheck suggested it was a 5 car rather than a 9.   I was in coach H.
Posted by IndustryInsider at 12:07, 27th February 2026
07:12 Plymouth to Penzance due 09:19
09:50 Penzance to Plymouth due 11:47
12:18 Plymouth to Penzance due 14:14
14:50 Penzance to Plymouth due 16:45
17:00 Plymouth to Liskeard due 17:37
All cancelled due to "more trains than usual needing repairs at the same time" - more problems with these "new" trains?
Booked for a 4-car Class 150.
Another spin of the famous JourneyCheck 'AM reality is PM fantasy' wheel - with the last three all now reinstated...using a 2-car 150.
Posted by grahame at 08:57, 27th February 2026
With Barnstaple, Okehampton and Exmouth all running again ... and I suspect this week that in these days of specialisation there are trains in Plymouth that need to get to Exeter for repair but can't because the line from Totnes to Plymouth is closed for engineering works, and the old alternative from Bere Alston to Okehampton has been closed for much longer.
Posted by GBM at 08:30, 27th February 2026
RTT not showing a 175, but 150'type.
Posted by TaplowGreen at 08:00, 27th February 2026
Posted by plymothian at 08:37, 25th February 2026
There are issues coupling more than 2 units together, therefore VSTP diagrams are splitting the moves to/from Laira into 2 separate ones, 5Z10 and 5Z11 this morning.
Posted by REVUpminster at 07:37, 25th February 2026
In other news 175002 visited Newquay yesterday.
And it's due to do so again today. 175001+175007 again working in tandem as well.
It's also reported the three units came out of Laira together although not supported by Realtime trains and were meant to go back together this evening although it did not seem to happen yesterday when both trains ended alongside each other in platform 7 and 8.
Posted by plymothian at 07:27, 25th February 2026
Posted by a-driver at 12:45, 23rd February 2026
5Z13 shows 175011 allocated from Par, and RTT has reports of it from Par to (so far) St Germans. How it got to Par, and why it's not showing on Traksy, is another matter.
It has just popped up at Wivelscombe on Traksy. But how it's already got past Saltash on camera, I have no idea.
Just to tidy up, and correct my mistakes:
-  REVUpminster's webcam of 175011picture was on 5Z33, 1100 Plymouth-Par, coming off the bridge at 11:13.
- so that answers my question about how it got to Par
- it was also seen in the Saltash webcam on 5Z13 at 12:51, on the way back to Plymouth (arr. 1259).
Which leaves outstanding the question of when it first got back from its enforced holiday at Liskeard to Plymouth. If I had to guess (which I don't, obviously) I'd say it was coupled to 175007, but not mentioned in despatches.
or did come back with 175002 and not mentioned.
An interesting signal problem is how. On London Underground signalling; as the points cannot be guaranteed, because a train is occupying the approach section, to be locked they would have to be scotched and clipped and hand signalled into the platform or the trains moved towards Liskard past signal LD20, the points on the branch scotched and clipped then the normal signal interlocking can take effect and the trains moved onto the main line.
All fully signalled with shunt signals. No need for anything to be clipped and scotched.
If fully signalled with shunt signals the points would be mechanically locked and presumably electronically locked and you would not be able to change the points on the main line.
On the undergound as some who might have to do it we were taught to say scotched and clipped as the scotch goes in first in case the points move as you try to put the clip on. The trainer would also say don't put the clip on over the rail. It's been done!
I'm not quite sure I get you!
if you go from Liskeard platform on the mainline towards the branch, you'd be signalled by a shunt signal - LD17.  Speed is 5mph.  Once the train drops in clear of LD20 on the branch, LD17 can be returned to danger and the points on the mainline can be returned to normal - mainline route.
Coming off the branch, the points will be reversed and LD20 can then be cleared in to the platform as far as LD11 which is Penzance end of the platform.
If you were to use another unit to rescue the failed sets, you could still clear LD17 from the platform but because you will not drop in clear of LD20 you would need authorisation from the signaller to change direction and return to the platform.  The points would remain locked in position.
The only time you wouldn't potentially need to clip and scotch the points is if the move was a passenger carrying move.
Posted by REVUpminster at 09:19, 23rd February 2026
If fully signalled with shunt signals the points would be mechanically locked and presumably electronically locked and you would not be able to change the points on the main line. On the undergound as some who might have to do it we were taught to say scotched and clipped as the scotch goes in first in case the points move as you try to put the clip on. The trainer would also say don't put the clip on over the rail. It's been done!
Posted by a-driver at 16:29, 22nd February 2026
Posted by REVUpminster at 17:10, 20th February 2026
Ely Mif 6:  175005/008, 175103/104/105/109 (175008 is in two halves)
Wolverton : 10 : 175004, 175102/106/107/108/110/111/113/115/116
Laira : 10:  175002/007/009, 175114; 175001/003/006/011, 175101/112 are refurbished
Long Rock : 1 : 175010
175002 and 175114 have been at Laira over a year.
175112 arrived at Laira from Wolverton today about 87 minutes early.
Updated 20 February 2026. I have had to correct a previous post but I think this is right.
175001+175007 are doing the Plymouth-Penzance-Plymouth run today together.
Posted by REVUpminster at 09:19, 14th February 2026
Posted by stuving at 22:26, 13th February 2026
Posted by Richard Fairhurst at 16:25, 13th February 2026
This hasn't aged very well.
A bit like the 175s...
Posted by TaplowGreen at 15:30, 13th February 2026
Looks like the 175s are coming to Laira plus the two simulators. The 158s at Exeter to go to Bristol.
GWR to get all the class 175s.  It be great to see them in service they are good units.
Posted by REVUpminster at 14:58, 13th February 2026
175011 is back at Laira somehow??
It is out an about and due to do the 1340 Plymouth - Penzance. I did a snip of the train at Saltash. It may not appear here.
I have a picture of 175011 using the snipping tool because you can turn the time back on the Saltash camera to 11.14 hrs. I just did it again to check.  I posted it on RailUK forums but it dosen't work here unless I put it on Flikr.
The 1340 was cancelled and only 175001 seems to be running round. GWR service gone to pot.
Posted by stuving at 12:46, 13th February 2026
Posted by REVUpminster at 11:45, 13th February 2026
Posted by REVUpminster at 18:21, 12th February 2026
After all that, what an anti-climax!
https://www.realtimetrains.co.uk/service/gb-nr:V75372/2026-02-12/detailed
Al sorted out in situ (by someone who knows about these things, apparently) and then scoot back to Plymouth in half an hour. Its buddy 011 was meant to follow an hour later (5Z15), but for some reason ... now what's happened there?
011 due to leave Liskeard as 5Z15 at 1945 using an existing path showing cancelled at the moment. It wasn't going to be sent via Penzance.
https://www.realtimetrains.co.uk/service/gb-nr:V75376/2026-02-12/detailed
Posted by stuving at 17:56, 12th February 2026
All sorted out in situ (by someone who knows about these things, apparently) and then scoot back to Plymouth in half an hour. Its buddy 011 was meant to follow an hour later (5Z15), but for some reason ... now what's happened there?
Posted by REVUpminster at 19:06, 11th February 2026
If they can separate the trains maybe 175011 can return faster?
This is a job for Saltash cams at 0208 if I can stay awake. Don't trust the timings.
175009 failed today out on the public run.
Recovering the trains was cancelled. Luckily I forgot and didn't stay up.
Posted by stuving at 11:41, 11th February 2026
ANother forum is saying 5mph.... those timings certainly look painful!
I assume the '33' is some code in the timing load – looks like RTT can't match it against its list of timing load tokens, so it's misreading as a speed, perhaps. Similar to when the IET timings first appeared - IIRC the code for Class 800 DMU didn't make sense to RTT (or to whatever source it uses) so it parsed it as diesel loco with 800t trailing load.
Pathing and planning speed are two separate parameters. Here, for example, is what RTT has for a goods working (not VSTP) which ran yesterday -
Pathed as Diesel locomotive, trailing load 600 tonnes
Planned for 60mph max
For most passenger stock at the moment the pathing information does not include a speed, that's implied by the class.
This is the text for the  planned recovery of the 175s tonight -
Pathed as Class 150/153/155/156 DMU
Planned for 33mph max
Obviously the scheduled timings were not derived from either the maximum speed for planning purposes or the pathing category!
That "33 mph" is common on RTT for VSTP (labelled VST) movements, for example this for a light loco running Bescot to Arpley yesterday -
The point, as I understand it, is that VSTPs are different. Everything else goes through standard processing to become part of the current timetable, at least at the start of each day. Details may be altered later (becoming VAR entries), but no new entries can be inserted into the timetable. VSTP items are provided separately so that they can be added to e.g. displayed outputs at a late stage in their production. The process that formats them for the industry data feed is separate from that for the main timetable.
So yes - that speed is provided in m/s, and should converted if required in mi/hr as 75. Other apps on line get it right, e.g. Liverail, or Live Train Times. The last divides the information differently, but for tonight's sick 175 movement includes:
Train Info
Operated By GWR
Timed For 75mph
Power Type DMU
Timing Load Sprinter
Posted by grahame at 10:06, 11th February 2026
Watch Journeycheck tomorrow morning - "this train has been delayed because of a slower train in front of it" for early services from Penzance to Plymouth.
Posted by Hafren at 00:12, 11th February 2026
Posted by stuving at 22:24, 10th February 2026
Plan to remove the failed units tomorrow night.
8X75. - Maximum speed 33 m.p.h.   23:20 at Liskeard to 04:15 at Laira.  On skids?  Man walking in front with red flag?
That would be too fast for skates, wouldn't it? But it's actually a "feature" of RTT's reporting of VSTP services: in the data the 33 is meant to be m/s but it hasn't been converted, which would give 75 mi/hr.
Posted by grahame at 21:38, 10th February 2026
Posted by REVUpminster at 20:54, 10th February 2026
https://www.realtimetrains.co.uk/service/gb-nr:53806/2026-02-11/detailed
Today has been a good day with 175001+175003 in tandem on training run to Newton Abbot-Penzance-Plymouth before 175001 made up the one passenger diagram to Penzance and back.
175009 also did a couple of training runs.
Posted by REVUpminster at 21:39, 6th February 2026
The move from Wolverton to Laira was cancelled for the second time which has been the norm.
175002 and 175011 are parked up on the Looe branch until they fix the problem.
Posted by JayMac at 21:39, 5th February 2026
172002 had brakes locked on at Liskeard. This fault a couple days after it had door interlock issues, also at Liskeard
Today the rescue unit sent wrong road from Plymouth was coupled up to 175002 and the brake problem transferred to the new unit.
Subsequent major disruption in Cornwall.
Posted by a-driver at 21:08, 5th February 2026
Failed 175 only recently disappeared from Traksy - not sure where the unit has gone.
Dumped in the Yard at Liskeard
Posted by Southernman at 20:45, 5th February 2026
Failed 175 only recently disappeared from Traksy - not sure where the unit has gone. The 17.50 Penzance - Paddington is formed of 150238 (2 car). Lost 30 minutes or so en-route to Plymouth but still going on! Lost no more time to Totnes. How far will it reach before being relieved of its long distance outing? Or maybe there was a swap of trains at Plymouth?
Presumably off the Falmouth branch shuttle but good bit of initiative!
Posted by GBM at 15:51, 5th February 2026
2C26 1340 Plymouth to Penzance (175002 to Liskeard) sat down at Liskeard and sulking.
Due to a broken down train at Liskeard disruption is expected until 16:00 05/02.
Train services between Plymouth and Penzance may be cancelled or delayed.
A train has broken down at Liskeard, blocking the line towards Penzance.
Our engineers are working with the crew on the train to find the cause of the fault. We are currently unable to run trains from Plymouth towards Penzance. This will also begin to affect services from Penzance towards Plymouth, as trains will not be in the right place.
2C27 1255 Exeter St Davids to Menheniot Signal Dm260 now sitting at said signal for an hour now.
Posted by REVUpminster at 20:53, 4th February 2026
https://www.realtimetrains.co.uk/service/gb-nr:K61700/2026-02-06/detailed
Another go from Wolverton. Very late in the day.
Posted by plymothian at 19:01, 4th February 2026
175007 was in public service today.
Posted by REVUpminster at 17:29, 30th January 2026
Planned 175004 and 175110 dragged to Wolverton today but the planned move from Wolverton to Laira was cancelled.
Wolverton : 11 : 175004, 175102/106/107/108/110/111/112/113/115/116
Laira : 8:  175002/007/009, 175114; 175001/003/006/011, 175101 are refurbished.
Updated 30 January 2026
https://www.youtube.com/watch?v=xOCFBzYBXjY
Posted by REVUpminster at 18:50, 26th January 2026
Have we got any green ones yet?
As these are a stop gap, very unlikely to be repainted and the future of regional liveries is up in the air with the possible new GBR livery.
Posted by Noggin at 11:04, 26th January 2026
Posted by REVUpminster at 09:14, 26th January 2026
175002 un-refurbished being used on a training run then to make up passenger 1340 to Penzance. 175001 refurbished also out training.
Posted by REVUpminster at 16:58, 24th January 2026
175101 yesterday stopping for no one at Newton Abbot. It is impressive.
https://www.youtube.com/shorts/WWT4932_b40
Passing West Drayton
https://www.youtube.com/watch?v=5X6ICpRYwlw
Posted by Chris from Nailsea at 22:58, 23rd January 2026
Did I see a 175 at Saltash this afternoon?
That, or you may need to update your medication.
Posted by REVUpminster at 22:43, 23rd January 2026
175001 been to Newton Abbot and Penzance
175007 had a couple of runs to Lostwithel and back first then Par and back
Posted by Red Squirrel at 20:35, 23rd January 2026
Posted by REVUpminster at 18:05, 23rd January 2026
The timings show how good this train is. Just needs to be able to carry passengers.
Ely Mif :8:  175004/005/008, 175103/104/105/109/110 (175008 is in two halves)
Wolverton : 9 : 175102/106/107/108/111/112/113/115/116
Laira : 9:  175002/007/009, 175114; 175001/003/006/011, 175101 are refurbished.
Updated 23 January 2026
Posted by TonyK at 17:12, 23rd January 2026
It made Tavistock Junction 94 early, but has either stopped there or delayed the announcement of its triumphal entry into Laira.
Posted by REVUpminster at 14:35, 23rd January 2026
A 3 car 175, maybe more, has left Wolverton. Hopefully catch it at Dawlishcam at 17.38 although is often early.
Reported as 175101
Running 49 minutes early! Maybe this will get to Laira.
If it does not stop at Taunton it will 100 minutes early. Green all the way.
Posted by a-driver at 13:35, 23rd January 2026
Reported as 175101
Posted by REVUpminster at 12:09, 23rd January 2026
Posted by John D at 12:07, 23rd January 2026
Delivery of a 175 (or maybe more than one unit coupled together) is currently happening, left Wolverton few minutes early
https://www.realtimetrains.co.uk/service/gb-nr:K60250/2026-01-23/detailed
Posted by TonyK at 17:14, 22nd January 2026
175001 (paired with 009), the only unit that can run in public traffic, was terminated on its training run at Liskeard as the windscreen spontaneously cracked in 2 places.
Liskeard and Saltash?
Posted by ChrisB at 16:53, 22nd January 2026
Can they seriously close with just two months notice?
Posted by bradshaw at 10:10, 22nd January 2026
Rumour on X that Papworth sidings, Ely are closing in March
https://x.com/trainlifegb/status/2014057725278212412?s=61&t=VlafMC5gF9tidw36b1Y8JQ
Posted by REVUpminster at 09:08, 22nd January 2026
Today, 175001 refurbished and 175007 unrefurbished out on training runs with 175001 expected to take up the passenger service at 1340. These two, out of eight, trains seem to be the only trains used in public service.
Posted by John D at 13:40, 21st January 2026
Looks like another unit (hopefully more than one unit) is scheduled from Wolverton to Laira on Friday.
Last couple of scheduled deliveries were cancelled, so will this one actually happen
Posted by REVUpminster at 15:59, 17th January 2026
175007 out in public use today on 2C49 12.42 Plymouth - Penzance and 2P24 15.15 Penzance - Plymouth
And it's an un-refurbished unit. On another site, water from the air condition unit coming down the windows inside.
Posted by plymothian at 13:26, 17th January 2026
Posted by John D at 17:27, 16th January 2026
Nothing from Wolverton in the past two hours. Maybe they have gone to get some clear cello tape. Perhaps the tide is in at Dawlish when the train is due?
Apparently cancelled due to signal failure (per real time trains)
Posted by REVUpminster at 13:40, 16th January 2026
Posted by plymothian at 10:03, 16th January 2026
Posted by Richard Fairhurst at 07:47, 16th January 2026
It does make you wonder how they were maintained towards the end of their time in Wales
I think that's reasonably well known - the maintenance contract was taken away from Alstom (who built the trains) and given to CAF (who built their replacements), and CAF were either uninterested or unknowledgeable. There was a series of Adelante-like fires in 2023.
Posted by Timmer at 07:36, 16th January 2026
Something seriously wrong with these trains.
Even by railway standards, the entry into service of these existing trains is happening at glacial pace. It does make you wonder how they were maintained towards the end of their time in Wales and the length of time they were stored outside has played a part.
Posted by Red Squirrel at 23:44, 15th January 2026
You may well be right, but let's hope not. When the 165/6's came to Bristol they were plagued with reliability issues while the local maintenance teams got the hang of them. Now they're  not too bad, given their age and unsuitability for short-stop metro-style services.
Posted by REVUpminster at 22:10, 15th January 2026
175003 did not run but 175001 took it's place. So a second of four has still not run in public service. Something seriously wrong with these trains.
See what tomorrows delivery from Wolverton is.
https://www.realtimetrains.co.uk/service/gb-nr:K60141/2026-01-16/detailed
Posted by REVUpminster at 09:40, 15th January 2026
Late start. Let's hope they are in condition for passenger service. Got the weekend to fix them. Yesterday 175001 ran a training run but was replaced by a 150 for the 1340 Plymouth- Penzance and back. Not one of the other three refurbished units at Laira has run in passenger service AFAIK.
It certainly feels like a slow (re)start of the class.  And January and February being the slow time of year, a 2 coach 150 on train from Penzance or 2 St Ives will have adequate capacity whereas come Easter, if the weather in nice, 2x158 or an IET or an HST would have been needed.
True, but today Paignton -Exmouth two short formed 150s. Barnstaple a two car 158. There are only 10 150s operating the Devon and Cornwall branches and thats's with St Ives and Looe operating with buses. The other 150s must be on the main line or defective.
Posted by REVUpminster at 09:34, 15th January 2026
175003, one of the refurbished, is planned to operate the 1340 Plymouth Penzance today.
Posted by grahame at 08:59, 15th January 2026
Posted by REVUpminster at 07:28, 15th January 2026
Posted by REVUpminster at 20:36, 13th January 2026
The seventeen hour drag from Ely to Long Rock took place today; reportedly 175010.
So I think this is the situation. 175001 is the only train in passenger service and that had a door failure that should have been fixable but it was taken out of service. Back working today.
Wolverton : 10 : 175101/102/106/107/108/111/112/113/115/116
Laira : 8:  175002/007/009, 175114; 175001/003/006/011 are refurbished.
Updated 13 January 2026
Posted by TonyK at 23:07, 12th January 2026
https://www.realtimetrains.co.uk/service/gb-nr:K49768/2026-01-09/detailed
175s coming from Wolverton today, hopefully. A 150  from Wolverton to Exeter was cancelled yesterday.
But will the trains be in serviceable condition. Of the four previous refurbished units; only 175001 has been used in passenger service.
The drag from Ely to Penzance is now scheduled for next week. Is it to do the work that Wolverton should be doing?
1945hrs Train did not run today
Still in Wolverton, I think, as of CoP 12 Jamuary.
Posted by REVUpminster at 10:56, 9th January 2026
Posted by REVUpminster at 15:10, 6th January 2026
175001 doing it's passenger run to Penzance and back. 1340 off Plymouth. It did a training run to Penzance coupled with 175009 beforehand. 175009 went back to Laira at 1340.
175001 seems to be the only train they trust in passenger service despite three other refurbished units at Laira. It was cancelled yesterday due to a fire alarm.
Today a planned drag from Ely to Penzance was cancelled due to locomotive failure. It was to be repaired at Longrock?
Stock shortages in the southwest are really bad this week with shortforms despite Looe and St Ives having a bus service this week.
Posted by Chris from Nailsea at 14:19, 18th December 2025
A couple of recent posts here have indeed been split off, moved and merged with our ongoing Portishead reopening topic.
See https://www.firstgreatwestern.info/coffeeshop/index.php?topic=231.msg369669#msg369669
Posted by Chris from Nailsea at 12:33, 17th December 2025
If this topic continues to drift towards Portishead, that's absolutely no problem.
I may simply split off a few of the more recent posts here and merge them with a specific topic we have elsewhere on the Coffee Shop forum on the subject of 'Portishead re-opening'.
That topic has been going for way more than 3 years, I can assure you!
Posted by IndustryInsider at 10:48, 17th December 2025
It will be a bit of a 'sticking plaster' for 5+ years until new units as part of Operation Churchward come on stream, but way better than nothing.
Probably closer to net nothing,  than a complete stopgap.
If you exclude the 3x4coach =12 Castle HSTs that were replaced,
the extra Newquay service (3-4 coach in summer),
a Portishead train 3 cars,
Extra 2 carriages for increased capacity for Oakhampton Interchange,
restoring short 3car to 4car on Cardiff-Portsmouth (8 vehicles),
Transfer of two 5car IETs from SW to Bristol-Oxford (10 vehicles),
Leaves less than 30 carriages extra, and based on some of the recent growth figures in South West in the ORR station usage (many are 5+% per year, with few nearer 8%), so could be 25-40% growth in 5 years.  Is the 175 fleet more a token effort than a real solution for at least 5 years.
I realise getting the 175s was a struggle, but when trying to secure them started (back in 2023 ?) DfT was still in post Covid mode.  Could argue it still is thinking like that rather than regional growth away from London.  But as we have such a start-stop train ordering policy I don't really know where any trains could actually come from if needed in 2-3 years time.
Yes, I guess we'll have to see how it all shakes out.
Though from the summer timetable change up to last weekend, two of the three Castle Class HST diagrams only had one return trip from Plymouth to Penzance on them.  The other one was closer to a 'full' diagram, but even that was out on passenger workings for less than 12 hours a day.  So, there's plenty of scope to tighten up and consolodate.
Portishead is still three years away.
Posted by REVUpminster at 09:57, 17th December 2025
3 car 175s to Okehampton. 50% increase in capacity which they will need with the opening of Okehampton Interchange.
5 car 175 (2 units) on the busiest train (workers and students) out of Barnstaple.
This releases the 158s to Bristol. 175s will not work there.
5 or 6 turbos will still need to come down from Bristol for the Devon Metro.
Newquay hourly service unlikely to see 175s which is to be done by 150s. An increase in passengers numbers which is very likely could change that.
175s will take over from the 800s between Exeter and Penzance. The split Cardiff- Penzance looks likely to be permanent with Cardiff-Taunton being extended to Exeter to call at Cullompton and Wellington when they open. This would free up space at Taunton for the 175s to reverse calling at Cullompton and Wellington.
Posted by John D at 07:24, 17th December 2025
From GWR.com
The first of Great Western Railway’s recommissioned Class 175 trains has entered into passenger service ahead of their phased rollout next year.
Oh early - that's good
But rather more serious, the winter lull in leisure holiday passenger numbers will give GWR the opportunity to get more of these into service and I don't suppose shortforms rather that MULTIPLE units on these trains will lead to too much overcrowding in January and February.  A window of opportunity.
Posted by IndustryInsider at 22:17, 16th December 2025
From GWR.com
Yes, good timing really as Cornwall/Devon go quieter than most routes over winter when compared with the summer rush.  A little bit of breathing space.
Hopefully there will be enough 175 units in service by next May to provide adequate summer capacity, including the release one for the extra Par<>Newquay services, and get some IETs released back to bolster the length of longer distance trips and new services such as Oxford<>Bristol.
Posted by grahame at 20:32, 16th December 2025
From GWR.com
Posted by bobm at 19:30, 16th December 2025
From GWR.com
https://news.gwr.com/news/first-of-great-western-railways-recommissioned-class-175-trains-enters-passenger-service
Yesterday’s 1340 Plymouth-Penzance service was operated by 175001. It then operated the 1552 return service.
GWR leased 26 Class 175 trains earlier this year as part of plans to rejuvenate its regional and suburban services.
The full fleet will be introduced throughout 2026, operating predominantly between Exeter St Davids and Penzance, as well as to Barnstaple and Okehampton.
In the early stages of the rollout, services operated by the 175s will vary to support wider training and maintenance needs.
It follows the retirement of GWR’s four remaining Castle Class sets on Saturday. The Class 43 locomotives and Mark 3 coaches, which operated on the Great Western network for almost 50 years, are due to be returned to their leasing companies in the new year.
Posted by REVUpminster at 07:41, 16th December 2025
175001 is due out at 1340 Plymouth-Penzance-Plymouth same as Monday
https://www.realtimetrains.co.uk/service/gb-nr:P22971/2025-12-16/detailed#allox_id=0
175003 is out now on a training run to Penzance and back.
https://www.realtimetrains.co.uk/service/gb-nr:V63761/2025-12-16/detailed#allox_id=1
Posted by TaplowGreen at 07:31, 16th December 2025
10:14 Plymouth to Penzance due 12:12
10:14 Plymouth to Penzance due 12:12 will be cancelled.
13:14 Penzance to Plymouth due 15:10
13:14 Penzance to Plymouth due 15:10 will be cancelled.
Looking good so far!
Posted by IndustryInsider at 16:37, 15th December 2025
If it's a case there isn't one 175 in passenger operation on Sunday or Monday then Mark Hopwood has presided over a complete fiasco.
In the nick of time then!
Posted by REVUpminster at 13:46, 15th December 2025
175001 has departed Plymouth for Penzance. It was sitting in the dock platform all morning.
Posted by REVUpminster at 07:15, 15th December 2025
How today is supposed to work; 2 units  come off Laira coupled, they carry out some ECS moves (presumably more crew training) then they split. One unit stays ECS and 175003 becomes 2C26 passenger to Penzance.
https://www.realtimetrains.co.uk/service/gb-nr:P22971/2025-12-15/detailed#allox_id=0
As at 1036. It is now 175001
Posted by old original at 08:16, 14th December 2025
Quite ironic that a HST had to stand-in for a unit that will probably have to cover the HST this week.....
Posted by REVUpminster at 21:45, 13th December 2025
The last HST is turning out to be 2P97 Newquay to Plymouth departing 14 late at 2136 standing in for a failed 150 since 1416hrs.
Posted by Timmer at 17:02, 13th December 2025
Scarcely credible, however it's reported elsewhere that fighting broke out amongst the spotters on one of the final HST runs this morning - turfed off at Truro apparently.
One would hope that no members of this esteemed forum were involved - whoever he was, he's certainly a cheeky boy!
https://x.com/themblades1889/status/1999819955705880721?s=20
Can only assume someone was sitting in his seat.
Seriously though, sad to see this happening on the last day of HST operations on GWR or at any time on a train.
Posted by TaplowGreen at 15:15, 13th December 2025
Posted by grahame at 08:37, 12th December 2025
It is reported ...
175 units to enter passenger service ... Monday 15th December to Friday  19th December
2C26 1340 Plymouth Penzance
2P21 1552 Penzance Plymouth will be a pair of 2 car 175 units.
and
The other 2 Castle Class HST diagrams will be covered by other DMU's.
One of former the Castle Class HST diagrams will be covered by using the DMU of Looe branch which is shut due to a week long engineering block
I can't help feeling that in passenger facilities and comfort, a 150 is a step down from an HST, though for sure it is cheaper to run.
Posted by REVUpminster at 18:36, 10th December 2025
Ely Mif :9:  175004/005/008/010 175103/104/105/109/110 (175008 is in two halves)
Laira : 8:  175002/007/009 175114; 175001/003/006/011 are refurbished.
Updated 10 December 2025
Posted by REVUpminster at 16:13, 10th December 2025
Two 2 car units just gone through Dawlish 45 minutes early. Reported elsewhere as 175006+175011.
Posted by John D at 06:46, 10th December 2025
There is a move from Wolverton to Laira today (which has been activated), due to wait Bath goods loop from about 14:15 to 15:00 (see link)
Some units moved from Ely to Wolverton back in the summer, so have had months to work on them.
Wonder if today's move will be a single unit (again) or number coupled together to be ready to replace the Castle HSTs
https://www.realtimetrains.co.uk/service/gb-nr:K48565/2025-12-10/detailed
Posted by TonyK at 21:41, 9th December 2025
The 175 move Wolverton to Laira was cancelled today. Maybe another go next week? It will be 4 weeks since the last move.
175002 and 175114 have been at Laira for a year!!
So surely they at least are not in a terrible state.  What happened to them in Wolverton - wipe the windows, check the oil, dollar gas?
Well at least they ain't wastin' time no more - they're southbound. But enough of my ramblin', man.
I knew I could rely on you, and they weren't just wasted words!
Posted by John D at 17:20, 6th December 2025
Another path for a move Wolverton-Laira has been added for 10th December.
This time it appears to wait at Bath goods loop from 14:18 until 15:00, rather than waiting at Taunton
Posted by Red Squirrel at 15:34, 30th November 2025
Posted by TonyK at 15:05, 29th November 2025
