Train GraphicClick on the map to explore geographics
I need help
FAQ
Emergency
About .
No recent travel & transport from BBC stories as at 08:35 02 May 2025
Read about the forum [here].
Register [here] - it's free.
What do I gain from registering? [here]
 tomorrow - Walk to Pilning
10/05/25 - BRTA Westbury
10/05/25 - Model Railway Show, Calne
13/05/25 - Melksham TUG / AGM
On this day
2nd May (1859)
Wilton South station opened
Train RunningCancelled
07:59 Gatwick Airport to Reading
Short Run
07:00 Worcester Shrub Hill to Didcot Parkway
07:12 London Paddington to Cardiff Central
08:45 Swindon to Westbury
09:21 Carmarthen to London Paddington
09:49 Cardiff Central to London Paddington
Abbreviation pageAcronymns and abbreviations
Stn ComparatorStation Comparator
Rail newsNews Now - live rail news feed
Site Style 1 2 3 4
Next departures • Bristol Temple MeadsBath SpaChippenhamSwindonDidcot ParkwayReadingLondon PaddingtonMelksham
Exeter St DavidsTauntonWestburyTrowbridgeBristol ParkwayCardiff CentralOxfordCheltenham SpaBirmingham New Street
May 02, 2025, 08:51:10 *
Welcome, Guest. Please login or register.
Login with username, password and session length
Forgotten your username or password? - get a reminder
Most recently liked subjects
[100] In memory of the Weymouth Harbour Tramway on the anniversary o...
[88] A very easy riddle
[76] Steam excursion - except there's much more diesel than steam!
[68] Low passenger numbers due to train unreliability
[36] Warmest day of year as UK temperature hits 24.9C - April 2025
[35] Spain / Portugal power outage
News: A forum for passengers ... with input from rail professionals welcomed too
   Home   Help Search Calendar Login Register
Pages: [1]
  Print
Author Topic: GWRF2020-08 Direct (through train) service provision  (Read 2349 times)
grahame
Administrator
Hero Member
View Profile WWW Email
« on: November 30, 2017, 08:26:22 »
Consultation Question 8
a) Which direct services such as those described above should be preserved in the next franchise?
Why?
b) Are there any other stations between which you feel direct services should be provided?
Why?
c) At which locations should connections between different services be improved? Why?
Explanatory text
Whilst passengers value being able to make direct journeys, some direct journeys may be provided more for operational reasons than because an identified market exists, e.g. linking of services together across Bristol between Great Malvern, Cardiff, Gloucester, Westbury, Weston-super-Mare, Taunton and Weymouth. In these cases, we are unlikely to perpetuate such cross-city linkages, and allowing the next franchisee flexibility to modify service patterns could be important in supporting future service improvements and efficient operations.
However, we recognise that there may be aspirations for a wider range of direct journey opportunities, particularly to and from London, and could require the franchisee to develop proposals for these for possible implementation in the franchise from 2022.
Where it not feasible to provide direct services, we will expect the franchisee to consider providing suitable connections between their own services where possible, e.g. between main line and branch line services in Devon and Cornwall. Where connections may be between different operators, we propose to build on the approach used in recent franchise competitions to seek greater collaboration with other operators and local stakeholders to identify the connections that matter most to passengers, and to coordinate their timetables where practicable to provide convenient connections.
See http://www.firstgreatwestern.info/coffeeshop/index.php?topic=19037 for the background to this topic
Logged
Coffee Shop Admin, Chair of Melksham Rail User Group, TravelWatch SouthWest Board Member
grahame
Administrator
Hero Member
« Reply #1 on: December 28, 2017, 06:19:49 »
A flexibility across the city of Bristol (allowing service to terminate there rather than be through such was Weymouth to Worcester) makes sense. However though journeys within the Bristol travel-to-work area that are cross city do benefit from being available without a change of train at Bristol Temple Meads.   For example, passengers from Yatton, Nailsea, Keynsham and Trowbridge (and other stations on those lines) commute in significant numbers to Filton Abbey Wood.
Should though services at peaks be retained across Bristol at least to Bristol Parkway, and if so is it reasonable to ask that this be done at the expense of timing improvements elsewhere in the area?
In Exeter, both St Davids and Central are key commute destinations, with passengers from all directions headed to both of them.   Doesn't it make sense to join up the services so that trains arriving  into Central from the Exmouth and Yeovil Junction lines carry on to St David's, and carry on further from there via Dawlish and via Crediton?
Logged
ellendune
Transport Scholar
Hero Member
View Profile
« Reply #2 on: December 28, 2017, 09:08:14 »
How about continuing some Paddington to the South West services via Bristol?  At least as far as Exeter!
Apart from being a useful service it would retain route knowledge for diversions.
Logged
Do you have something you would like to add to this thread, or would you like to raise a new question at the Coffee Shop? Please [register] (it is free) if you have not done so before, or login (at the top of this page) if you already have an account - we would love to read what you have to say!
You can find out more about how this forum works [here] - that will link you to a copy of the forum agreement that you can read before you join, and tell you very much more about how we operate. We are an independent forum, provided and run by customers of Great Western Railway, for customers of Great Western Railway and we welcome railway professionals as members too, in either a personal or official capacity. Views expressed in posts are not necessarily the views of the operators of the forum.
As well as posting messages onto existing threads, and starting new subjects, members can communicate with each other through personal messages if they wish. And once members have made a certain number of posts, they will automatically be admitted to the "frequent posters club", where subjects not-for-public-domain are discussed; anything from the occasional rant to meetups we may be having ...
Pages: [1]
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.2 | SMF © 2006-2007, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
This forum is provided by customers of Great Western Railway (formerly First Great Western), and the views expressed are those of the individual posters concerned. Visit www.gwr.com for the official Great Western Railway website. Please contact the administrators of this site if you feel that the content provided by one of our posters contravenes our posting rules via admin@railcustomer.info. Full legal statement (here).
Jump to top of pageJump to Forum Home Page
